175MD
175MD
    MUELLERELECTRIC
    可编程(多功能) 延时继电器 SPDT(1 Form C) 0 秒 ~ 9.59 小时 延时 8A @ 250VAC DIN 轨道
175MD 数据手册
Setting: ±0.1% of set time of ±50mSec Repeat: ±0.1% RESET Reset time < 100 msec, Front Key, Interruption of Power OUTPUT CONTACT SPDT (1 C/O) CONTACT RATING 8A @ 250V AC MODES On delay (A) Interval (B) Asymmetrical cyclic OFF first (C) Asymmetrical cyclic ON first (D) Cyclic equal OFF first (E) Cyclic equal ON first (F) Pulse output (H) Delay on break (J) Delay on make/break (K) Interval after break (L) Single shot (P) Retriggerable Single shot (Q) Latching relay (R) Delay with Totalise (t) Interval with Totalise (U) TIME RANGES 0 - 99.9 sec/min/hr 0 - 999 sec/min/hr 0 - 9:59 min:sec 0 - 9:59 hr:min SUPPLY VOLTAGE 20-240V AC/DC AC : (50 / 60 Hz) E55826 Multi-Function Timer "With Display" NEW PRODUCTS ACCURACY 175MD Series SPECIFICATIONS • 15 Functions • 8 Time Ranges • Front Key Pad Setting • Universal supply voltage • Slim, Space Saving Design • DIN Rail Mount DIMENSIONS (MILLIMETERS) 44mm 45mm POWER 4 VA max CONSUMPTION 67.5mm 35.3 mm HUMIDITY 95% RH (NON-CONDENSING) 90 mm TEMPERATURE Operating: 0 to 50°C (32 to 122°F) Storage: -20 to 75°C (-4 to 167°F) 17.5 mm WEIGHT 0.163 lbs. PROTECTION LEVEL IP40 for Casing IP20 for Terminals Symmetrical 35mm Din Rail (EN50022) Mounting 60 mm TERMINAL CONNECTIONS + ~– A1 A2 ORDERING INFORMATION PART NO. 175MD Control Contact Y1 SUPPLY VOLTAGE 20-240V AC/DC AC: 50/60Hz 15 25 16 18 NC NO COM Cable Size (AWG): 16 ; Tightening Torque (Lb-inch): 4.5 Cable Size (mm2): 1.5 ; Tightening Torque (N-m): 0.5 Automatic Timing & Controls 800.727.5646 automatictiming.com 5 6 NEW PRODUCTS 175MD Series TIMING DIAGRAMS
175MD 价格&库存
很抱歉,暂时无法提供与“175MD”相匹配的价格&库存,您可以联系我们找货
