305E Series
Noted for its circuit flexibility, the 305 also provides the highest
accuracy among analog timers. Available for either ON-Delay or OFFDelay operation.
The 305 provides delay, interval or pulse timing function for up to
7 load circuits through two instantaneous and two delayed switches.
It features a plug-in design and cycle progress indication.
E24305
PLUG-IN AND DUST-TIGHT DESIGN: By virtue of its true plug-in design,
the body of a 305 can be replaced in seconds without disturbing the
housing or disconnecting the wiring. Its gasketed dial assembly forms a
dust-tight seal against the housing, whether panel or surface-mounted.
FASTEST RESET: All 305 timers reset to a full-scale setting within 0.1
second, proportionately faster for shorter settings.
Motor-Driven Analog Reset Timer
CIRCUIT FLEXIBILITY: All the contacts of its two instantaneous and two
delayed load switches are externally accessible at a 14 point terminal
block.
LONGEST LIFE: With an average mechanical life expectancy of over
5,000,000 o perations before the first failure, the 305 is the leader in
its class.
PILOT LIGHT: A built-in pilot light indicates that the timer is running.
ON DELAY
Timing Sequence**
SWITCH
CONTACTS
Before
Start
During
Cycle *
End of
Cycle *
Instantaneous 14-9/6-8
14-10/6-7
OPERATION
The 305 is a synchronous motor-driven timer with an
electrically-operated clutch equipped either for ON-Delay or OFF-Delay
operation.
ON-DELAY: When power is applied (start signal on), the clutch solenoid
is energized. Two things happen immediately and simultaneously, the
instantaneous switches transfer from one set of contacts to the other,
and the motor begins to drive the cycle progress pointer toward zero.
At the end of the timed period, the pointer trips one of the delayed
switches, a brief time later (about 1/2% of full scale), the other delayed
switch is tripped, stopping the timer motor but leaving the clutch engaged. The timer does not reset until power to the clutch is removed.
OFF-DELAY: Timing starts when power is removed (start signal off),
from the spring-loaded, normally engaged clutch. The timer is reset
when power is restored to the clutch solenoid; simultaneously, the
instantaneous contacts are tripped. Action of the delayed contacts is the
same as with ON-Delay timers. A power outage stops the motor but does
not reset the OFF-Delay 305E.
ELECTROMECHANICAL TIMER
HIGHEST ACCURACY: Because of its exclusive infinite engagement
clutch, the 305 has a repeat accuracy of 0.2%, highest of any timer in
its class.
Delayed (D2) 11-12
11-13
Delayed (D1) 4-5
4-3
* D2 trips approximately 1/2% of range after end of cycle.
** Assumes a sustained closed start signal (i.e. longer than the
dial set time).
OFF DELAY
Timing Sequence**
SWITCH
CONTACTS Before During
Start
Cycle *
End of
Cycle *
14-10/6-7
Delayed (D2) 11-12
11-13
Delayed (D1) 4-5
4-3
* D2 trips approximately 1/2% to 5% of range after end of cycle.
dial set time).
BLACK
Circuit Closed
Automatic Timing & Controls
800.727.5646
GRAY
Circuit Open
automatictiming.com
15
(INCHES/MILLIMETERS)
RANGES (AC)
13 standard ranges, from 6 SEC to 60 HRS at
60 Hz.
REPEAT ACCURACY AC MODELS: – 0.2% of full scale (For ranges of
60 SEC or less, it may be necessary to run timer
motor before start to achieve related accuracy)
RESET TIME
0.1 SEC, full scale
MIN. SETTING
1/60th of range (all models except 0.3 SEC for
6 SEC model)
DIAL DIVISIONS
6 SEC, 60 SEC, 120 SEC, 240 SEC,
60 MIN, 240 MIN, 6 HR, and
60 HR =120 Dial Divisions
30 SEC, 15 MIN, 30 MIN, 15 HR.,
and 30 HR =150 Dial Divisions
LIFE EXPECTANCY MECHANICAL: over 5,000,000 operations
CONTACTS: 3,000,000 operations under
resistive or inductive load of 1A
TIMING MOTOR
Synchronous, permanently lubricated
TIMING
Single cycle interval or delay
LOAD SWITCHES INSTANTANEOUS: two, each SPDT; self cleaning,
heavy-duty silver contacts.
DELAYED:
two, each SPDT; precision
type, silver contacts
CONTACT RATING (non-inductive):
10 amps, 120 VAC
5 amps, 240 VAC
WIRING
AC WIRING
TERMINAL WIRING
16
SPECIFICATIONS
MODELS ON-Delay
OFF-Delay
305E Series
DIMENSIONS
PILOT LIGHT
Wired in parallel with motor.
TERMINALS
14 screw terminals accessible at rear;
integral wiring diagram on timer housing.
HOUSING
Plug-in design; completely gasketed,
dust-tight when surface or panel-mounted
POWER
REQUIREMENTS
AC MODELS: 120, 60Hz (all ranges),
(– 10%, - 10%)
AC MODELS: running current 0.128 A (115 VAC)
inrush current 0.628 A (115 VAC)
TEMPERATURE
RATING
32° to 140°F (0° to 60°C)
WEIGHT
NET: 2 lb., 6 oz. SHIPPING: 2 lb., 12 oz.
MOUNTING
STANDARD: Hardware is provided to mount timer
ACCESSORIES
so that it is dust-tight from front of
panel.
OPTIONAL: Surface mounting with rear-facing
terminals. (See Accessories)
800.727.5646
automatictiming.com
MODEL NUMBER
305E 0
RANGE
VOLTAGE & FREQUENCY
ARRANGEMENTS
ON-DELAY (reset on power interruption)
1
OFF-DELAY (non-reset on power interruption) 2
Special
VOLTAGE
FREQUENCY
120/60 A
SETTING
Knob
FEATURES
Basic plug-in timer
P
Standard Timer X
Basic standard unit
X
Special
K
ACCESSORIES:
Surface mounting bracket rear facing terminals
0305-263-64-00
TYPICAL INSTALLATIONS
SUSTAINED START (ON DELAY)
CLUTCH SOLENOID
MOTOR
INDEPENDENT LOADS
DEPENDENT LOADS
MOMENTARY STARTING
CONTACT
SUSTAINED STARTING
CONTACT
LOAD ENERGIZED
LOAD DE-ENERGIZED
All timers shown in “before start”
position. Diagrams shown with
power off unless otherwise marked.
Maximum load current through any
load carrying contact is 10 amperes.
DELAYED CONTACTS
Switch 4-5-3 transfers
at dial “0.” Switch
11-12-13 transfers
1% later.
INSTANTANEOUS CONTACTS
Contacts are transferred when clutch
is energized; transferred back, as
shown when de-energized.
MOMENTARY START (ON DELAY)
800.727.5646
RANGE-60 CYCLES 120 VAC
6 SEC
101
30 SEC
006
60 SEC
007
120 SEC
008
240 SEC
011
15 MIN
015
30 MIN
016
60 MIN
017
240 MIN
019
6 HR
030
15 HR
021
30 HR
022
305E Series
MODEL NUMBER
ON-DELAY - Reset on power failure.
OFF-DELAY - Non-reset on power
failure.
OFF DELAY
automatictiming.com
17
