354C-350-Q-30-PX
354C-350-Q-30-PX
    MUELLERELECTRIC
    计时器 120VAC DIN 轨道
354C-350-Q-30-PX 数据手册
EASY TO SET AT ALL TIMES: The Shawnee counter is easily and accurately set even with work gloves on. Push any of its four toggle levers in any sequence until the number you want appears above it. You can decrease as well as increase each number by pushing the levers up or down. You can change the setting at any time, even during a cycle. NOISE IMMUNITY: The 354 does not have to be shielded: its transformer power supply, full-wave bridges, buffered logic and other design characteristics render it immune to the electrical noise that is sometimes encountered in industrial environments thus eliminating false starts and reset due to voltage spikes. PLUG-IN AND DUST-TIGHT: All 354 counters feature true plug-in design and are dust-tight from the front of panel. 100% ACCURATE AND BOUNCE-PROOF: The repeat accuracy of the Shawnee 354 is 100% at all rated speeds, even in the presence of contact bounce. The 354 has two selectable levels of bounce suppression: a normal level which eliminates false counts at speeds up to 500 per second with reed switch inputs, and 5,000 per second with DC voltage pulses; and a high level, for speeds up to 80 per second with high-bounce contact closures (relays, precision switches, etc.). HOUSING, IT OCCUPIES 40% LESS: Packaged in a 72mm2 DIN size housing, the 354 occupies 40% less panel space than previous IC counters. Modern production and assembly techniques have substantially reduced manufacturing costs resulting in a 45% cost saving. CONTROL VERSATILITY: The 354 operates either as a repeat cycle pulse generator or in single-cycle interval or delayed mode. You choose the kind of control action you want by installing jumpers on the terminal block. It also provides a choice of control output, a standard plug-in SPDT relay or an optional SPST solid-state switch module...plus an independent and separate DC output signal at Terminal 6. E48329 Shawnee II High Speed Counter MODEL NUMBER MODEL NUMBER 354C 30 P RANGE 9,999 Counts 350 99,990 Counts (units digit blind) 353 Special 000 VOLTAGE & FREQUENCY 120 VAC 50-60 Hz 240 VAC, 50-60 Hz Q R ARRANGEMENT With Display (On-Delay) 30 FEATURES Basic plug-in unit P Standard unit X Special K ACCESSORIES Surface mounting bracket kit Retrofit kit PREDETERMINING COUNTERS CYCLE PROGRESS INDICATION: The Shawnee 354 indicating counter provides cycle progress indication on a four-digit display located immediately above the digital setting number wheels. While the nonindicating 354C Series The solid-state 354 is manufactured from a series of computer-tested plug-in circuit boards and assembled virtually without hand wiring. Because it has no moving parts in its logic circuits, its life expectancy is practically unlimited. Even the load relay—the 354’s only significant mechanical component—has a life expectancy of 100,000,000 operations (no load), while the optional solid-state switch module has a virtually unlimited life expectancy. As a result, the 354 achieves an overall reliability that surpasses even the high level achieved by previous Shawnee counters. 0353-260-27-00 0305-265-61-70 DIMENSIONS (INCHES/MILLIMETERS) OPERATION The Shawnee 354 operates on a digital logic circuit with three main elements: input circuits which allow it to count various types of DC pulses; a read-only-memory (ROM) whose output is set by the counter’s digital setting number wheels; and a comparator that continuously examines the outputs of the input circuit and ROM. When the start (ready/reset) signal is on, the input circuit begins to count incoming pulses, feeding the total count continuously to the comparator. When input circuit output exactly equals ROM output, the 354 counts out. At that instant, the input circuit automatically turns itself off even if the start signal remains on; it is therefore not necessary to turn off the pulses externally. At the same instant, the 354 provides one of three load control actions depending on how it is wired (see Typical Applications). When the 354 is wired for interval operation, the counter’s output device (either the standard SPDT relay or the optional SPST switch module) is energized from the start to the end of the count cycle; so is the DC output at terminal 6. Automatic Timing & Controls 800.727.5646 The 354C Directly Replaces 354B & 354A. automatictiming.com 115 354C Series PREDETERMINING COUNTERS SPECIFICATIONS START Voltage Requirements (READY/RESET) Positive Polarity ready at 4.5V MIN SIGNAL reset at 1.0V max. RANGE 1 to 9999 counts or 10 to 99,990, presettable Max. Continuous Input 40V in 10 count increments. Ripple Voltage must not go below MIN req. PULSE INPUTS Isolated Contact Input (Dry) Input Impedance 5K ohms Min. Open Resistance 1 megohm Ready-to-Count Time 0.5 mSEC max (after applica- Max. Closed Resistance 20K ohms. tion of voltage to Terminal 7) Switch Requirements 10mA, 30V Circuit Reset 1 mSEC max. Count Rate and Bounce Immunity Ready-To-Dropout 20 mSEC max. With normal bounce immunity–for Reed Start Switch Requirements (isolated contact) Switches (Terminal 9 jumpered to 13) Switch Rating 10mA, 30V Max. Count Rate 500/SEC Min. Open Resistance 1 megohm Min. Closed Time 100 μSEC Max. Closed Resistance 20K ohms Min. Open Time 1 mSEC Latching Mode Operation (interval only) Max. Open Time for 0.3 mSEC Min. Duration 50 μSEC Any Single Bounce Start Signal Count Rate and Bounce Immunity with maximum Max. Duration continuous bounce immunity–for Precision Switches Start Signal (Terminal 9 jumpered to 10 and 11) Reset when signal is removed after Max. Count Rate 80/ SEC count-out. Min. Closed Time 30 μSEC LOAD RELAY LIFE 100,000,000 operations Min. Open Time 6 mSEC (no load) Max. Open Time for 2.5 mSEC Contact Rating 5 A at 120 VAC, 3 A at Any Single Bounce 28 VDC 1/20 HP at 120 VAC VOLTAGE Positive Polarity On at 4.5V min. 5A @ 120 VAC Resistive, INPUTS Off at 1.0V max 5A, 30 VDC Resistive Negative Polarity On at 3.0V min. SOLID-STATE Switches external DC voltage supply of positive Off at 1.0V max. SWITCH polarity, 4 to 30V, 50 mA max.; factory-wired to Max. Continuous Input 40V. MODULE Terminals 3 and 5 (detailed description of operation Ripple Voltage Must not go below min. req. (OPTIONAL) in Installation Instruction) Input Impedance 5K ohms DC OUTPUT Voltage ON– -24V+10% Min. ON Time 60 μSEC (TERMINAL 6) OFF– -1V or less Min. OFF Time 100 μSEC Current with relay –5mA max. Count Rate 5K Hz max. without relay –40mA max. Rise and Fall Time Req. none. Impedance on– 10 ohms max., off–10K ohms. DELAYED MODE Relay Operate Time 20 mSEC max. CYCLE PROGRESS Indicating model only–digit, 0.3 inch, high INDICATOR intensity, blue display (after coincidence) Relay Release Mode INTERVAL MODE Relay Operate Time Relay Release Time (after coincidence) DC POWER Voltage 24V+10% SUPPLY OUTPUT Current 40mA max (TERMINAL 8) 20 mSEC max. 15 mSEC max. 25 mSEC max. AUTOMATIC Pulse On time (with relay) RECYCLE MODE 80 mSEC, + 20 mSEC (may be shortened or lengthened by installing a resistor or capacitor, respectively, across Terminals 12 and 14; see Application section for details) When the 354 is wired for delayed control, the output device is energized at the end of the cycle and remains on until the counter is reset; so is the DC output. POWER 120V REQUIREMENTS 240V TEMPERATURE 32° to 140°F (0 to 60°C) RATING MOUNTING Standard Hardware is provided to mount counter so that it is dust-tight from front of panel. Optional Surface mounting with front facing terminals When the 354 is wired as a repeat cycle pulse generator, the output WEIGHT NET: 1 lb., 7 oz. device and the DC signal are both off until the end of the count cycle, at which time they are both on for about 80 mSEC From the instant that the output pulse comes on, the 354 stops counting for 500 μSEC while it resets; it automatically begins a new cycle and starts counting pulses again immediately after reset. The duration of the pulse generated by the 354 can be easily lengthened or shortened by wiring a capacitor or resistor across terminals 12 and 14 (see Typical Applications). 116 Automatic Timing & Controls 95 to 132V, 50/60 Hz inrush–0. 4A running–0.04A. 190 to 264V, 50/60 Hz inrush–0.2A running–0.02A. 800.727.5646 SHIPPING: 2 lbs. automatictiming.com 354C Series WIRING TERMINAL WIRING SOLID STATE OUTPUT MODULE The 354 can be used for delayed or interval control or as a repeat cycle pulse generator. Here again, decide which mode you want, then consult the appropriate wiring diagram. Note that the 354 counts on the break of a contact or decrease of a voltage signal when an external jumper is installed between Terminals 12 and 16, as shown in the diagrams in this step. It can also be programmed to count on make simply by leaving the jumper off. The Shawnee 354 has a readily accessible 16-point terminal which allows its use with a variety of start circuits and input pulses and to program it for the desired load action. To wire the 354C so as to suit a particular application is a relatively simple matter that is easily accomplished by selecting one of the examples in each of the following four steps. Combine the four examples for your wiring diagram. A. DELAYED MODE. The SPDT relay provides one delayed closing and one delayed opening circuit, and the 354 generates a DC signal at Terminal 6 at the end of the cycle. STEP 1 - START CIRCUITS The 354 accommodates three types of start signals. To wire the counter properly to your start signal, first determine which of the three types applies, then consult the appropriate wiring diagram. NOTE: AC line connections are always made to Terminals 1 and 2. DELAYED MODE A. ISOLATED CONTACT (sustained start signal) The external dry start switch must be closed throughout the count cycle. The 354 is ready to count whenever the switch is closed; it resets when the switch is opened. B. INTERVAL MODE. The SPDT relay provides one interval opening and one interval closing circuit, and the 354 provides a - 24VDC signal at terminal 6 during cycle. ISOLATED CONTACT START— (EXTERNAL START SWITCH PREDETERMINING COUNTERS STEP 2 - PROGRAMMING TYPICAL APPLICATIONS INTERVAL MODE *Jumper for momentary start in interval mode.) B. DC VOLTAGE (sustained start signal) The start voltage must be on throughout the count cycle. The 354 is ready to count whenever the voltage reaches +4.5 or -3V DC; it resets when the voltage drops to +1 or -1V DC. C. NEGATIVE DC VOLTAGE (momentary* or sustained start signal.) The start signal may be momentary or sustained. The 354 is ready to count whenever the start voltage reaches -3V DC. It resets at the end of the cycle, when the start voltage is momentary; or as soon after count-out as the start voltage drops between -1 and 0V DC, when the start signal is sustained. D. REPEAT CYCLE PULSE GENERATOR. In this mode, the 354 generates an output of 80 ms (±20 ms) at the end of the count cycle; the length of the output pulse can be adjusted as follows: DC VOLTAGE START (SUSTAINED START) To shorten the pulse, install a fixed or variable resistor between Terminals 12 and 14, sizing it according to this formula: 2.2t – 26.4 = R 80-t NEGATIVE DC VOLTAGE (MOMENTARY* OR SUSTAINED START) Automatic Timing & Controls Where: t = time in ms (±25%) R = resistance in megohms To lengthen the pulse, install a capacitor between Terminals 12 and 14 (if a polarized capacitor, install + to 12, - to 14) and size it according to the formua: T – 0.08 = C 1.6 800.727.5646 Where: T = time in sec (±25%) C = capacitance in microfarads. automatictiming.com 117 354C Series A. DELAYED MODE. The load action in this mode is always the same regardless of the kind of start circuit selected in Step 1; but the start signal must remain on during the entire count cycle, as the counter resets when the start signal is removed. STEP 3 - PULSE INPUTS The 354 can count from low or high-speed contacts or, by virtue of its built-in pulse shaper, from DC voltage pulses of positive or negative polarity. Choose the wiring diagram that suits your application. DELAY MODE LOW SPEED CONTACTS Before Start During Timing End of Cycle Start SW LOAD A LOAD B Reset to Before Start -241/-27 VDC at Term 6 B. INTERVAL MODE WITH SUSTAINED START. In this mode also, the counter resets when the start signal is removed. PREDETERMINING COUNTERS A. LOW-SPEED CONTACTS. The 354 counts input pulses from precision switches, relays, limit switches, etc., at speeds up to 80/SEC. B. HIGH-SPEED CONTACTS. Input pulses from low-bounce contacts, reed switches, etc., can be counted at speeds up to 500/SEC. In this circuit only, the 354 counts on the break of the pulse switch as received; to count on make, install a jumper between Terminals 12 and 16; this is the reverse of the situation that applies to all other 354B circuits. INTERVAL MODE–SUSTAINED START Before Start During Timing End of Cycle Start SW Reset to Before Start LOAD A LOAD B HIGH SPEED CONTACTS -241/-27 VDC at Term 6 C. INTERVAL MODE WITH MOMENTARY START. Because of the 354’s electronic latch capability, it can provide interval control with a momentary negative DC voltage start signal, in which event the 354 resets at the end of cycle. But the counter will also operate with a sustained start signal, in which case it resets when the start signal goes off, as described above. INTERVAL–MOMENTARY OR SUSTAINED START C. DC VOLTAGE PULSES. In this circuit, the 354 counts when the voltage decreases from above +4.5V to below +1V, or from above – 3V to below –1V, with a jumper installed between Terminals 12 and 16 as shown in Section 2; to reverse the action, simply remove the jumper. COUNT DC VOLTAGE PULSES STEP 4 -LOAD ACTION The load action of the 354 depends on the choice of start circuit and programming mode. Loads are always wired to the 354 in the following manner: Before During Start Timing End of Cycle Start SW LOAD A LOAD B -241/-27 VDC at Term 6 D. REPEAT CYCLE PULSE GENERATOR. When this mode is selected, the start signal must remain on continuously. The 354 generates an output pulse at the end of each count cycle, then resets and repeats automatically. At least 500 μs is required for resetting, between the last count of one cycle and the first count of the next. Count pulses can be of unequal length – long and short as shown in the diagram – provided that they meet the minimum requirements listed in the SPECIFICATIONS. REPEAT CYCLE GENERATOR DURING CYCLE Before Start C C C C Reset Start SW LOAD A LOAD B If the 354 is equipped with the optional SPST solid-state switch module, its contacts are always available at Terminals 3 and 5, and its load action is the same as for Load B in the drawings right. -24/-27 VDC At Term 6 PULSE SW C=COUNT CYCLE=DIAL SETTING =TIMED PULSE OUTPUT 118 Automatic Timing & Controls 800.727.5646 BLACK– CIRCUIT CLOSED GRAY– CIRCUIT OPEN automatictiming.com
354C-350-Q-30-PX 价格&库存
很抱歉,暂时无法提供与“354C-350-Q-30-PX”相匹配的价格&库存,您可以联系我们找货
