356C-350-Q-30-PX
356C-350-Q-30-PX
    MUELLERELECTRIC
    计时器 120VAC DIN 轨道
356C-350-Q-30-PX 数据手册
356C Series SAVE 40% IN PANEL SPACE AND COST: Packaged in a 72mm2 DINsize housing, the 356 occupies 40% less panel space than previous IC timers. Modern production and assembly techniques have substantially reduced manufacturing costs resulted in a 45% cost saving. LOW INVENTORY COSTS: Each Shawnee 356 covers the active count range of 1 to 9,999, easily satisfying the vast majority of industrial requirements and thus greatly reducing inventory. E48329 DIMENSIONS (INCHES/MILLIMETERS) A compact version of the 336 counter, the ATC 356 is its exact functional duplicate. Packaged in a 72mm2 DIN-size housing, it occupies 40% less panel space and costs proportionately less. Modern production and assembly techniques have all but eliminated hand wiring, enhancing the reliability and life expectancy of the 356. FAST, ACCURATE AND BOUNCE-PROOF: The repeat accuracy of the 356 is 100%. It maintains full accuracy even at pulse rates up to 4,000/minute, even with pulses that are as brief as 1 millisecond, and even in the face of severe contact bounce, which it ignores by virtue of an extremely effective anti-bounce circuit. EASY TO SET AT ALL TIMES: The Shawnee counter is easily and accurately set even with work gloves on. Push any of its four toggle levers in any sequence until the number you want appears above it. You can decrease as well as increase each number by pushing the levers up or down. You can change the setting at any time, even during a cycle. MODEL NUMBER MODEL NUMBER 356C 30 P PLUG-IN AND DUST-TIGHT: All 356 counters feature true plug-in design and can be replaced in seconds without disturbing the housing or disconnecting the wiring. The dial assembly is gasketed so that the counter body is dust-tight from the front of panel. RANGE 9,999 Counts 350 99,990 Counts (units digit blind) 353 Special 000 VOLTAGE & FREQUENCY 120 VAC 50-60 Hz 240 VAC, 50-60 Hz Q R ARRANGEMENT With Display (On-Delay) 30 FEATURES Basic plug-in unit P Standard unit X Special K ACCESSORIES Surface mounting bracket kit Retrofit kit 0353-260-27-00 0305-265-61-70 The 356C Directly Replaces 356B & 356A. Automatic Timing & Controls PREDETERMINING COUNTERS Shawnee II Digital Counter CYCLE PROGRESS INDICATION: The Shawnee 356 indicating counter provides cycle progress indication on the four-digit display located immediately above the digital setting number wheels. When the counter is in the reset condition, the VFD display is blank. During the cycle, the display counts up from 0, thus always indicating the number of counts that have elapsed since the start of cycle. At countout, the display shows the total elapsed count and thus equals the numbers on the digital setting wheels. COMPUTER-TESTED RELIABILITY: The solid-state 356 is manufactured from a series of computer-tested plug-in circuit boards and assembled virtually without hand wiring. Because it has no moving parts in its logic circuits, its life expectancy is practically unlimited. Even the load relay – the 356’s only significant mechanical component – has a life expectancy of 10,000,000 operations (no load). As a result the 356 achieves an overall reliability that surpasses even that achieved by previous Shawnee counters. NOISE IMMUNITY: The 356 does not have to be shielded: its transformer power supply, full-wave bridges, buffered logic and other design characteristics render it immune to the electrical noise that is sometimes encountered in industrial environments thus eliminating false starts and reset due to voltage spikes. 800.727.5646 automatictiming.com 119 356C Series PREDETERMINING COUNTERS OPERATION SPECIFICATIONS The Shawnee 356 operates on a digital logic circuit with three main elements: a pulse circuit; a read-only-memory (ROM) whose output is set by the counter’s digital setting number wheels; and a comparator that continuously examines the outputs of the pulse circuit and ROM. RANGE milliseconds or more. The 356 operates in the on-delay mode only, always resetting whenever there is a power outage and starting a new cycle when power is restored. RESET TIME 75 mSEC minimum MINIMUM SETTING 1 count 1 to 9999 counts or 10 to 99,990, presettable in 10 count increments. COUNT INPUT 2300/MIN with 1:1 on-off time 4000/MIN with 1 mSEC on: 13 mSEC off 500/MIN with 20 mSEC on and 100 mSEC off When power is applied (start signal on), two things happen Wired for count and repeat operation simultaneously; the instantaneous DPDT relay is energized Min. Pulse ON Time: 1 mSEC transferring both sets of contacts, and the pulse circuit begins to Min. Pulse OFF Time: 13 mSEC count each input pulse whose duration is at least 1 millisecond. The Ready-To-Count 10 mSEC after application of pulse circuit accumulates the count and feeds the total continuously Time power to terminals 1 and 2 to the comparator. When pulse circuit output exactly equals the output Bounce Immunity 6 mSEC of the ROM, the comparator causes the 356 to count out. (max. bounce open time) At this point, (1) the DPDT delay relay is energized, immediately Pulse Contact Req. 30mA (at line voltage) transferring both sets of contacts and (2) the pulse circuit turns itself CYCLE PROGRESS 4 digit, 0.3 inch, high intensity, blue display. off automatically. Since the pulse circuit stops counting even if the start signal remains on, it is not necessary to tie up one of the 356’s INDICATOR delayed contacts to do this job. REPEAT 100% To reset the 356, power must be removed from terminal 1 (L1) for 75 ACCURACY Switching Sequence* RELAY CONTACTS Before Start During Timing End of Cycle Instantaneous 14-9/6-8 14-10/6-7 Delayed (D2) 11-12/4-5 11-13/4-3 *Assumes a sustained closed start signal (i.e. longer than the setting on the digital display) BLACK– CIRCUIT CLOSED GRAY– CIRCUIT OPEN WIRING COUNT Single Cycle CONTROL MODES Repeat Cycle interval or delayed pulses LOAD RELAYS Number Operate Time Release Time Contact Rating Life two, one instantaneous and one delayed; both plug-in, DPDT 20 mSEC max. instantaneous –20 mSEC, max. delayed–75 mSEC, max. 5A at 120 VAC. 2A at 240 VAC, 0.1A at 125 VDC 100 million operations (no load.) TEMPERATURE 32° to 140°F (0° to 60°C) RATING POWER 120V 95-132V at 50 or 60 Hz REQUIREMENTS inrush -0.4A running —0.08A 240V 190-264V at 50 or 60Hz inrush - 0.2A running—0.04A TERMINALS 16 screw terminals accessible at rear; integral wiring diagram on housing. HOUSING Plug-in design; completely gasketed, dust-tight when panel-mounted. TERMINAL WIRING: INDICATING MODEL 120 Automatic Timing & Controls MOUNTING Standard ACCESSORIES See Accessory section of catalog Optional Hardware is provided to mount timer so that it is dust-tight from front of panel. Surface mounting without and with front-facing terminals. WEIGHT SHIPPING: 2 lbs 800.727.5646 NET: 1 lb., 7 oz. automatictiming.com POWER SUPPLY PULSE INPUT INDEPENDENT LOADS DEPENDENT LOADS MOMENTARY STARTING CONTACT SUSTAINED STARTING CONTACT NORMALLY CLOSED RESET CONTACT LOAD DE-ENERGIZED LOAD ENERGIZED DELAYED CONTACTS Contacts transfer simultaneously when unit “times out” and all digits are zero. All timers shown in “before start” position. Diagrams shown with power off unless otherwise marked. Maximum load current through any load carrying contact is 5 amperes. Pilot light leads are brought out to terminal block. Pilot light can be wired to show practically any desired function; unit energized, cycle running, instantaneous or delayed switch closed, etc. ON DELAY–Reset on power failure. 356C Series TYPICAL INSTALLATIONS INSTANTANEOUS CONTACTS Contacts are transferred when power supply is energized; transferred back, as shown when de-energized. PREDETERMINING COUNTERS SUSTAINED START MOMENTARY START/SUSTAINED START COUNT, PULSE AND REPEAT CYCLE Automatic Timing & Controls 800.727.5646 automatictiming.com 121
356C-350-Q-30-PX 价格&库存
很抱歉,暂时无法提供与“356C-350-Q-30-PX”相匹配的价格&库存,您可以联系我们找货
