365C-300-Q-30-PX
365C-300-Q-30-PX
    MUELLERELECTRIC
    间隔,打开延迟 延时继电器 DPDT(2 Form C) 0 秒 ~ 999 小时 延时 7A @ 120VAC DIN 轨道
365C-300-Q-30-PX 数据手册
E48329 POSITIVE RESET TIME AND PULSE LENGTH: Digitally clocked by the microcomputer, the 365’s reset time is consistently of the same duration, regardless of variations in line voltage, power supply, or time cycle. As a result, the 365 is not subject to false reset from momentary power interruptions (less than 30 mSEC). When the 365 operates in repeat-cycle mode, the output pulse is also digitally clocked so that both its occurrence and duration are consistent. WIDE RANGE: Each 365 Long-Ranger covers the overall span of 0.01 SEC to 999 HR, in nine switch-selected ranges of 0 to 9.99, 99.9 or 999 SEC, MIN or HR. The timer can be optimized within any selected range simply by removing appropriate selector knobs (e.g. with the timer in the 9.99 SEC range, you can obtain a tamper-proof span of 0.99 by setting the left selector at 0 and removing the knob). LONG-RANGER Timer DIMENSIONS (INCHES/MILLIMETERS) PROGRAMMABLE DISPLAY: Depending on the position of an internal jumper, the 365’s three-digit cycle progress display will time UP to or DOWN from the set point; after time-out, it will either STOP or GO (i.e. display the time elapsed after time-out). To the right of the three-digit display, a timing bar “ ” blinks once per second during the timing cycle and rapidly after timeout. At left, a marker “ ” turns on when the delayed relay is energized. PANEL MOUNTED DIGITAL TIMERS COMPUTATION: Through its internal microcomputer, the 365 keeps track of the set point throughout the time cycle. Whenever there is a change in set point, even during a cycle, it instantly re-computes the time remaining and accurately determines time-out. This unique capability is especially valuable in the time-down modes as it allows you to shorten a cycle without loss of accuracy. 365C Series The ATC 365 is the latest generation in the popular long-ranger timer series. The microprocessor-based digital timer is equipped with three rotary knobs for setting and adjustment of the Preset. The Preset can be any three-digit value from .01 SEC to 999 HR. The Decimal and Range are switch selectable. The high-intensity blue vacuum fluorescent display is DIP switch selectable to Timeup or Timedown. Two heavy-duty 7A DPDT relays provide instantaneous, interval or delayed output control. Plug-in panel mounting allows easy replacement without the removal of field wiring. NOISE IMMUNITY: The 365 has formidable defenses against noise: transformer power supply, full-wave bridges, buffered logic. Furthermore its microcomputer detects; and rejects; noise pulses that manage to penetrate its defenses. No industrial timer has ever offered greater noise immunity. RELIABILITY AND RUGGEDNESS: ATC firmly believes that no industrial timer has ever achieved a higher level of reliability and ruggedness. The 365’s electronic components have no moving parts and are assembled, virtually without hand wiring, from computer-tested circuit boards. Its few mechanical components have been selected for reliable service; the two load relays have a life expectancy of 100,000,000 operations and heavy-duty contacts rated at 7 amps; and the three rotary set point selector switches exhibit extremely low wear. COMPACT, PLUG-IN AND DUST-TIGHT: Packaged in a 72mm2 DIN housing, the 365 occupies 40% less panel space than conventional timers. It is a true plugin timer that can be replaced in seconds without disturbing housing or wiring. The 365 is also fully gasketed and O-ring sealed to be dust tight. SELF DIAGNOSTICS: The time will display "FAIL" anytime there is a problem or the knobs are in between digits. Automatic Timing & Controls 800.727.5646 The 365C Directly Replaces 365A & 365B automatictiming.com 97 365C Series SPECIFICATIONS MODELS Arrangement “30,” with digital display available for On-Delay operation at 120, 240 or 24 VAC; and 24 VDC RANGES Switch-selectable ranges of 0-9.99, 0-99.9 and 0-999 SEC, MIN or HR POWER 120 VAC REQUIREMENTS 240 VAC 24 VAC 24 VDC TIMING Single Cycle interval or delayed MODES Repeat Cycle pulse-clocked at 50 to 80 mSEC (will be constant for a given unit) PANEL MOUNTED DIGITAL TIMERS RESET TIME Clocked at 60 mSEC DISPLAY CYCLE 3 digit display, 0.3 inch, high-intensity, blue PROGRESS programmable: DOWN and STOP, DOWN and GO, UP and STOP or UP and GO TIME-OUT display (left); energized at time-out. TIMING BAR display (right); blinks once per second during cycle, rapidly after time-out. CLOCK INPUT (terminal 15) VOLTAGE MODEL 120VAC 95-132VAC, 10mA max. current at Model 120V 240VAC 190-264VAC, 10 mA max. current at Model 240V 24VAC 19.2-26.4VAC, 20 mA max. current Model at 24V 24VDC 19.2-26.4VDC (5% ripple), 5 mA Model max. current at 24V LOAD RELAY Number one instantaneous and one delayed Type DPDT, Form C. Operate Time P 13 mSEC, max. Release Time 10 mSEC, max. Contact Ratings 7A at 120, 240 or 24 VAC 1/6 HP Life 100 million operations (no load) ± .001% ± .010 SEC of setting SETTING ACCURACY ±.01% + .030 SEC of setting TERMINALS 16 screw terminals accessible at rear WEIGHT MODEL NUMBER REPEAT ACCURACY HOUSING 72mm2 DIN size; plug-in design; fully gasketed, dust and water-tight in panel mounted installations Standard hardware is provided for front-of-panel mounting. Optional Surface-mounting brackets with front-facing terminals. TEMPERATURE 32 to 122°F (0 to 50°C) RATING MODEL NUMBER 365C NET: AC 1 lb., 6 oz. Shipping: AC 2 lbs. DC 14 oz. DC 1 lb., 8 oz. P RANGE 0 to 9.99, or 99.9 or 999 SEC, 300 MIN, or HR Special 000 VOLTAGE & FREQUENCY 24 VDC 120 VAC 50-60 Hz 240 VAC, 50-60 Hz 24 VAC, 50-60 Hz Special 95-132 VAC, 50 or 60 Hz. Inrush — .3A. Running 0.06A at 120 VAC 216-264 VAC, 50 or 60 Hz. Inrush — .15A. Running — 0.03A at 240 VAC 19.2-26.4 VAC, 50 or 60 Hz Inrush — 1A. Running — 0.25A at 24 VAC 19.2-26.4 VDC, 5% ripple Running — .120A AT 24 VDC WIRING N Q R T K ARRANGEMENT With display, ON-delay/Time up or 30 down and stop (reset on power failure) Time up or down and go 50 FEATURES Basic plug-in unit P Standard unit X Special K ACCESSORIES: Surface mounting bracket kit Retrofit kit 98 TERMINAL WIRING 353-260-27-00 305-265-61-70 Automatic Timing & Controls 800.727.5646 automatictiming.com As soon as power is applied to terminals 1 & 2 of the timer, the instantaneous relay is energized and changes the states of its associated contacts (8-6-7 & 9-14-10). The timer then looks for terminal 15 (the clock terminal) to receive power. When terminal 15 is powered, the internal clock circuit is enabled and the timer starts to time. When the internal clock time equals the time set on the front face, the delayed relay energizes and changes the states of its associated contacts (3-4-5 & 13-11-12). The timer is reset by removing power from terminal 1 for at least 60 msec. At reset, both relays revert back to their shelf (without power) state. POWER SUPPLY CLOCK INDEPENDENT LOADS DEPENDENT LOADS MOMENTARY STARTING CONTACT SUSTAINED STARTING CONTACT LOAD ENERGIZED LOAD DE-ENERGIZED All timers shown in "before start" position. Diagrams shown with power off unless otherwise marked. Maximum load current through any load carrying contact is 5 amperes. Pilot lights leads are brought out to terminal block. Pilot light can be wired to show practically any desired function timer energized, cycle running instantaneous or delayed switch closed. etc. SPECIAL NOTE FOR UNITS WITHOUT DISPLAYS: On nondisplay units, terminals 1 & 15 are jumpered together internally. As soon as power is applied, the instantaneous relay energizes and the timer starts to time immediately. DELAYED CONTACTS Contacts transfer simultaneously when unit "times out" and all digits are zero. INSTANTANEOUS CONTACTS Contacts are transferred when power supply is energized, transferred back as shown when de-energized. KEY SYMBOLS DISPLAY INFORMATION: The digital display can be set to time up or down by simply moving a DIP switch on the circuit board. MODE: • 30PX STOP (Time up/down to time set, transfer delayed relay, and stop timing). SUSTAINED START • 50PX GO (Time up/down to time set, transfer delayed relay, and continue timing until unit is reset). 365C Series TYPICAL INSTALLATIONS PANEL MOUNTED DIGITAL TIMERS OPERATION MOMENTARY START REPEAT CYCLE PULSE Automatic Timing & Controls 800.727.5646 automatictiming.com 99
365C-300-Q-30-PX 价格&库存
很抱歉,暂时无法提供与“365C-300-Q-30-PX”相匹配的价格&库存,您可以联系我们找货
