405AR-100-S5T-X
405AR-100-S5T-X
    MUELLERELECTRIC
    间隔,打开延迟 延时继电器 DPDT(2 Form C) 1 秒 ~ 30 小时 延时 10A @ 230VAC/24VDC DIN 轨道
405AR-100-S5T-X 数据手册
405AR Series ON DELAY / TIMING MODES: The 405AR has a selectable ON-Delay or Interval Mode of operation. The unit has a DPDT 10A contact output. When in the On-Delay mode, the contacts transfer at time out. When in the Interval mode, the contacts transfer when power is applied and released at time out. 1/16 DIN HOUSING: The 48mm2 housing is compact and IP40 rated front cover. The 405AR100SZX is mounted in an 8-pin round socket (PF083A or OT08). The 405AR100S5TX is a terminal unit (no socket required). The 405AR can also be panel mounted. E339488 1/16 DIN TIMERS 1/16 DIN ON Delay/Interval Timer • ON Delay / Interval Mode of Operation The MODE/Range select dip switches are located on the front under a clear cover. UNIVERSAL POWER: The 405AR is universal powered and can be powered by 20 to 240 VAC or 12 to 240 VDC, greatly reducing inventory management of replacement units. • 12 Timing Ranges DIMENSIONS (MILLIMETERS) • Universal Supply Voltage Plug type Terminal type • LED Status Indicator Power ON, Relay ON • Compact Size 45 46 48 • Face Plate IP40 Panel cutout 70.5 7 SPECIFICATIONS 79 OPERATING MODE OUTPUT CONTACT DPDT DELAY MODES ON Delay / Interval TIME RANGES 1 / 3 / 10 / 30 SEC / MIN / HR RELAY RATING Model S2X 10A @ 230 VAC/24 VDC, resistive Model S5TX 5A @ 230 VAC/24 VDC, resistive ACCURACY Setting: ± 5% of full scale. Repeat: ±0.5% or 50 msec (whichever is greater). RESET On interruption of power. OPERATING TEMPERATURE 32° to 122°F (0° to 50°C) STORAGE TEMPERATURE -4° to 167°F (-20° to 75°C) 000-825-90-00 MODE AND RANGE SELECTION MODE AND RANGE SELECTION Dip switch settings for time range selection Back Connections Socket RANGE SW 1 SW 2 SW 3 1 SEC OFF OFF OFF OFF 3 SEC OFF ON OFF OFF SW 4 10 SEC ON OFF OFF OFF 30 SEC ON ON OFF OFF 1 MIN OFF OFF OFF ON 3 MIN OFF ON OFF ON ON 10 MIN ON OFF OFF 30 MIN ON ON OFF 1 HR OFF OFF ON ON OFF/ON 3 HR OFF ON ON OFF/ON 10 HR ON OFF ON OFF/ON 30 HR ON ON ON OFF/ON Dip switch settings for mode selection LOAD CONNECTIONS 8-PIN PLUG-IN TYPE NC1 3 6 2 7 COM1 1 LN 24 NC2 5 8 1 NC1 2 3 11 OFF INTERVAL ON ON 5 NO1 NC2 COM2 COM1 NO2 4 SW 5 Switch setting example: TERMINAL TYPE NO2 Range: 30sec Mode :On delay Sw1 Sw2 Sw3 Sw4 Mode ORDERING CODE 12 MODEL NUMBER COM2 6 L + NO1 4 MODE ON DELAY 7 -N 8 9 10 Automatic Timing & Controls DESCRIPTION 405AR100S2X 8-PIN socket with 10 amp relay 405AR100S5TX Terminal with 5 amp relay 800.727.5646 automatictiming.com 46
405AR-100-S5T-X 价格&库存
很抱歉,暂时无法提供与“405AR-100-S5T-X”相匹配的价格&库存,您可以联系我们找货
