417B-500-F-2-X
417B-500-F-2-X
    MUELLERELECTRIC
    关 - 延迟 延时继电器 DPDT(2 Form C) 固定,5 秒,0.5 分 ~ 5 分 延时 10A @ 250VAC 可插
417B-500-F-2-X 数据手册
417B Series The 417 True Off-Delay Timer is designed for the most rugged industrial environments. It offers exceptional electrical noise immunity, with excellent ­setting and repeat accuracy. Each 417 can be powered from 24 VAC to 240 VAC and 24 VDC, greatly simplifying ordering and inventory management. The 48mm2 (1/16 DIN) housing is compact. The 417 is mounted in an 8-pin octal or 11-pin round socket. The 417 can be panel-mounted with an optional mounting clip. E48329 A large time-setting knob is provided for easy adjustment by operator. The range select switch is located on the side of the unit; t­herefore, once panel-mounted, the switch is not accessible to the operator. This ­tamper-proof feature prevents unauthorized or hazardous changes to the timing range. The 417’s high intensity LED turns on when power is applied to the timer and turns off during timing. • True Off-Delay mode of operation SPECIFICATIONS MODELS Choice of eight multi-range units. Each model has three timing ranges. RANGE Model 417B100 (10 SEC, 1 MIN, 10 MIN) Model 417B500 (5 SEC, 0.5 MIN, 5 MIN) • Output contacts rated 10A at 120/240 VAC • Three timing ranges in a single unit: 10 SEC, 1 MIN, 10 MIN 5 SEC, 0.5 MIN, 5 MIN CONTACT RATING 10 AMPS (Resistive @ 250 VAC) 1/6 HP @ 120 VAC 1/3 HP @ 240 VAC • Universal power operation: 24 VAC to 240 VAC & 24 VDC TEMPERATURE RATING 0° to 104°F (-18° to 40°C) • 8-Pin or 11-Pin mounting. NOISE IMMUNITY Showering Arc per NEMA 2-230, the 417 will withstand a voltage surge of 4500 volts for 50 µsec without damage. • Remote reset models. MOUNTING Plug in base available in 8-Pin Octal or 11-Pin Round Base. Options: Surface mounting socket DIN rail mounting socket Panel mounting adapter kit Plug-in socket kit POWER REQUIREMENTS • 48mm2 DIN standard housing • Range selection is tamper-proof when panel-mounted. TYPICAL APPLICATIONS Whenever main power is interrupted, the 417 (adjustable from 0.1 SEC to 10 MIN), enables an emergency backup power source. 24 to 240 VAC & 24 VDC, 50 or 60 Hz, (+10%, -20%) 24 to 240 VAC. (+20%, -20%) 24 VDC DC MAXIMUM RIPPLE AT 60 Hz -5% LOAD RELAY TYPE LIFE REPEAT ACCURACY 1/16 DIN TIMERS True OFF-Delay Timer DPDT, Standard Models SPDT, Remote Reset Models 10,000,000 operations (no load 100,000 operations with 5 AMPS at 30 VDC (or less) or 5 AMPS at 250 VAC (or less) ± 5%* *Variation from average actual time. Controlled by a PLC, the 417 timing cycle can be aborted by using the remote reset terminal. MINIMUM SETTING 2% of range SETTING ACCURACY ± 10% REMOTE RESET 50 mSEC minimum (remote reset models) POWER ON TIME 1.0 SEC minimum INDICATOR Power on LED HOUSING 48mm2 (1/16 DIN) WEIGHT The 417B Directly Replaces 417A 5 oz. (140 g) Automatic Timing & Controls 800.727.5646 automatictiming.com 33 417B Series DIMENSIONS MODEL NUMBER (INCHES/MILLIMETERS) MODEL NUMBER 417B F RANGE 10 SEC, 1 MIN, 10 MIN 5 SEC, 0.5 MIN, 5 MIN HOLD DOWN CLIP ATC P/N 407-026-13-00 100 500 VOLTAGE & FREQUENCY 24 to 240 VAC & 24 VDC F ARRANGEMENT 8-Pin Base 11-Pin Base 2 4 1/16 DIN TIMERS FEATURES Standard X Remote R Special K PANEL MOUNTING BRACKET ATC P/N 406-320-02-00 PANEL MOUNTING (UP TO 0188 THICK) OPERATIONS When power is applied to the timer, the relay energizes and the ­indicating LED turns on. Timing starts when power is removed, and the LED turns off. The output relay remains energized until the end of the cycle, or by ­connecting terminals 1 to 4 when using the Remote Reset Model. During time delay, power on will RESET Delay Time. ACCESSORIES 8-PIN 8-Pin surface/DIN rail socket Hold down for above socket (Requires two per unit) Panel mounting bracket Plug-in socket kit (8-pin) 8-Pin panel socket w/rear facing terminals ACCESSORIES 11-PIN 11-Pin surface/DIN rail socket Hold down for above socket (Requires two per unit) Panel mounting bracket Plug-in socket kit (11-pin) 000-825-85-00 407-025-13-00 405-320-02-00 319-261-45-00 000-825-90-00 000-825-86-00 407-025-13-00 405-320-02-00 319-260-07-00 MODEL 417...F.X Standard unit with DPDT relay contacts WIRING TERMINAL WIRING MODEL 417...F.R Same as standard unit except with SPDT relay contacts and ability to reset from an externally located remote reset switch SETTING THE RANGE Refer to the drawing. Using a small screwdriver inserted into the adjusting slot as shown (fig. 1), rotate the range switch. The selected range will appear through the window of the dial face. 34 Automatic Timing & Controls 800.727.5646 automatictiming.com
417B-500-F-2-X 价格&库存
很抱歉,暂时无法提供与“417B-500-F-2-X”相匹配的价格&库存,您可以联系我们找货
