422AR-100-S5T-X
422AR-100-S5T-X
    MUELLERELECTRIC
    重复周期 延时继电器 DPDT(2 Form C) 1 秒 ~ 10 小时 延时 10A @ 250VAC DIN 轨道
422AR-100-S5T-X 数据手册
422AR Series The 422AR Flip-Flop timer is available with Repeat Cycle operations. During Repeat Cycle operation the 422AR cycle ON and OFF repeatedly, allowing periodic cycling of a load. Two knobs are available to individually adjust the ON-time and the OFF-time. The 422AR can be configured with either the relay being energized during the first timing period or de-energized during the first timing period. The 422AR have 6 selectable timing ranges available for both ON-time and OFF-time periods. The ranges are 1 and 10 SEC/MIN/HRS dip switch selectable. Having this flexibility allows for a load to be energized for a brief time over a cycle that lasts up to 10 hours. This is ideal for lubrication or other maintenance functions that must occur each shift or day during a plant operation. E339488 1/16 DIN Flip-Flop Timer The 422AR is universal powered by 20 to 240 VAC or 12 to 240 VDC operation voltage. • Six Selectable Ranges: 1 and 10 SEC/MIN/HRS The output of the 422AR has a DPDT mechanical relay which is rated for 10 amps @ 250 VAC resistive. The 422AR can be ordered in a terminal option which is available with 5 amp Relay output. • Individual adjustable ON-time and OFF-time The 422's have individual LED indicators for ON time and OFF time. These LED's provide a unique and effective method of cycle progress indication. SPECIFICATIONS SUPPLY VOLTAGE 20 to 240 VAC,12 to 240 VDC. (AC: 50/60 Hz) OUTPUT CONTACT DPDT DELAY MODES Cyclic ON first or OFF first (selectable by DIP switches) TIME RANGES 1 / 10 SEC/ MIN / HR for both On & Off time (selectable by DIP switches) RELAY RATING Model S0X Model S5TX 10A @ 230 VAC, resistive 5A @ 230 VAC/24 VDC, resistive POWER CONSUMPTION • Cycle can begin with relay energized or de-energized • Relay rated 10A @ 250 VAC Resistive • Compact Size (1/16 DIN) • DPDT Relay Output 1/16 DIN TIMERS The 422AR 1/16 DIN housing is compact, and designed for panel mounting. The timer is mounted in an 8-pin round socket. The front of the 422AR features 2 knobs. One knob is used to set the ON-time and the other knob is used to set the OFF-time for the timer's cycle. • Power: 20VAC to 240VAC 12VDC to 240VDC • LED Indicator for Power and Relay energized output • Can be DIN Rail mounted with DIN RAIL socket • Faceplate IP40 2 VA max. ACCURACY Setting: ± 5% of full scale. Repeat: ±0.5% or 50 msec (whichever is greater). LED INDICATION Power ON, Relay ON RESET On interruption of power RESET TIME Less than 100 mSEC. HOUSING Flame retardant plastic. HUMIDITY Up to 95% RH. OPERATING TEMPERATURE 32° to 122°F (0° to 50°C) STORAGE TEMPERATURE -4° to 167°F (-20° to 75°C) MOUNTING Panel mounting WEIGHT 115 gms Automatic Timing & Controls 800.727.5646 automatictiming.com 35 422AR Series DIMENSIONS (MILLIMETERS) Plug type Terminal type Panel cutout 45 46 48 70.5 7 46 79 1/16 DIN TIMERS WIRING 8-PIN PLUG-IN TYPE NC1 4 NO1 NC2 5 3 6 NO2 7 2 1 COM1 8 TERMINAL TYPE COM2 LN 1 NC1 1 sec SWITCH SETTING Sw2 Sw3 OFF OFF ON RANGE 1 SEC SWITCH SETTING Sw6 Sw7 Sw8 OFF OFF ON 1 min ON OFF ON 1 MIN ON OFF ON 1 hr OFF ON ON 1 HR OFF ON ON 10 sec OFF OFF OFF 10 SEC OFF OFF OFF 10 min ON OFF OFF 10 MIN ON OFF OFF 10 hr OFF ON OFF 10 HR OFF ON OFF Dip switch settings for mode selection Sw4 Sw5 OFF First ON OFF ON First OFF ON Mode 6 2 3 4 5 MIN HR X1 OFF ON NO2 12 7 8 9 10 – N MODEL NUMBER 422AR 100 DPDT VOLTAGE 20-240 VAC 12-240 VDC O FEATURES Standard Unit 6 7 8 MIN HR X1 SEC SEC X10 (Switch is Black Mark) 36 S CYCLE Repeat Cycle ON SEC SEC X10 S O X X Note: Terminal connection model available as 422AR100S5TX with 5 amp relay only. Switch setting example: Off time range: 1sec On time range: 10min Mode :Cyclic off first 1 5 MODEL NUMBER ON TIME Sw1 4 NO1 NC2 COM2 11 L + Dip switch settings for time range selection RANGE 3 COM1 DIP SWITCH SETTINGS OFF TIME 2 Automatic Timing & Controls 800.727.5646 automatictiming.com
422AR-100-S5T-X 价格&库存
很抱歉,暂时无法提供与“422AR-100-S5T-X”相匹配的价格&库存,您可以联系我们找货
