500 Series
CONTROL 1
Contact Rating (SPST):
OUTPUT
5a @ 230VAC / 30VDC resistive
SPECIFICATIONS SSR Drive (Voltage Pulse):
18VDC 20ma
Current:
0/4 to 20ma dc (loop impedence 500 ohms max
Voltage:
0 to 5/10 VDC (load resistance 10K ohms min)
ALARM 2
OUTPUT
SPECIFICATION
SSR DRIVE: 12VDC 20ma
FUNCTIONAL
SPECIFICATION
Control Action: PID, On-Off
Proportional Band (P): 0.0 to 400.0 deg
Integral Time (I): 0 to 3600 sec
Derivative Time (D): 0 to 200 sec
Cycle Time: 0.1 to 100.0 sec
Hysteresis Width: 0.1 to 99.9 deg
Manual Reset Value: -99.9 to 99.9 deg
HEAT COOL PID
Control Action: PID
Cycle Time: 0.1 to 100 sec
Proportional Gain: 0.0 to 400.0 deg
Deadband: Programmable from setpoint low limit
to setpoint high limit
ALARMS
Modes: Deviation high/low,
Absolute high/low, band, sensor break
Hysterisis: 0.1 to 99.9 deg
RAMP SOAK
Ramp Rage: 1 to 9999 deg/hr.
Soak Time: 0 to 1440 min
Soft Start Time: 0 to 999 min.
SUPPLY VOLTAGE
85 to 270V AC/DC (50/60 Hz)
RETRANSMISSION Current:
0/4 to 20ma DC
(loop impedence 500 ohms max)
Voltage:
0 to 5/10V DC
(load resistance 10k ohms min)
Update Rate: 100msec
SERIAL
COMMUNICATION
Interface Standard: RS485
Communication Address:
1 to 99, maximum of 32 units per line
Transmission mode: Half duplex
Transmission protocol: MODBUS RTU
Transmission distance: 500 m maximum
Transmission speed: 9600, 4800, 1200,
600, 300 bits/sec.
TEMPERATURE
Operating: 0 to 50°C (32 to 122°F)
Storage: -20 to 75°C (-4 to 167°F)
HUMIDITY
95% RH
(NON CONDENSING)
WEIGHT:
6.4 oz.
PROTECTION
LEVEL
IP65 for faceplate
Automatic Timing & Controls
1/16 DIN Advanced, Full Featured
PID Temperature Controller
• Dual Display, 4 digit, 7 segment LED • Heat Cool PID
• TC/RTD Input, Analog Input
• Ramp Soak
• ON/OFF, PID, PID Autotune
• Soft Start
• C/F degrees selectable
• 1/16 DIN (48 x 48 mm)
SPECIFICATIONS
DIGITS
4 digit, 7 segment LED Dual Display
Height of Upper display: 0.3785"
Height of Lower display: 0.2720"
LED INDICATIONS Relay On, Alarm, Manual Mode, Tune
INPUTS
Thermocouple (J,K,T,R,S,C,E,B,N,L,U,W)
Platinel II, RTD (Pt100)
DC Analog Inputs (-5 to 56mv, 0 to 10v, 0 to 20 ma)
SAMPLING TIME
200 ms
PID/TEMPERATURE CONTROLLERS
POWER
6VA max @ 230 VAC
CONSUMPTION
E339488
INPUT FILTER (FTC) 0.2 to 10.0 sec
RESOLUTION
1/0.1 deg for TC/RTD only
Fixed 1 deg resolution for R&S Type TC)
Decimal point position selectable:
1/0.1/0.01/0.001 for analog input
TEMPERATURE
UNIT:
C/F deg selectable
INDICATION ACC:
For TC inputs 0.25% of F.S. ± 1°
R&S type TC inputs 0.5% of F.S. ± 2 deg
(20 min of warm up time for TC inputs)
For RTD inputs 0.1% of F.S. ± 1 deg
For Analog Input ± 0.5%, ± 1 digit
(F.S. = Full Scale)
800.727.5646
automatictiming.com
129
500 Series
COMPLIANCE
IEC/EN 61326 (EMI/EMC)
IEC/EN 61010 Revision 3 2010 Edition (Safety)
UL 61010 Revision 3 2010 Edition (Safety)
DIMENSIONS
10mm
48mm
46mm
45mm
48mm
46mm
100mm
CURus Cable Size (AWG): 16-13
Tightening Torque (lb-inch): 7
TERMINAL CONNECTIONS
1
CT /
RS485
+ 2
COM2
3
NO2
+ 4
– 5
COM1
SSR2
NO2
11
6
– 12
7
13
8
+ 14
9
NO3
SSR3
L (+)
SSR1/0-5 V/
0-10 V/4 -20mA
Stud Hole for Lug (inch): 0.137
(-) N
TC+ /RTD1
ANA IP+
TC– /RTD2
ANA IP–
RTD3
– 15 10
COM3
ORDERING INFORMATION
PART NO.
OUTPUT 1
OUTPUT 2
OUTPUT 3
COMMUNICATION
SUPPLY
(RS485) VOLTAGE
ATC500000100
Relay
Relay
Relay
85-270V AC/DC
ATC500000400
Relay
Relay
Relay
Yes
85-270V AC/DC
ATC500010500
Relay
12V DC SSR
12V DC SSR
Yes
85-270V AC/DC
ATC500200100
4-20ma
Relay
Relay
85-270V AC/DC
ATC500200400
4-20ma
Relay
Relay
85-270V AC/DC
ATC500300100
0-10V
Relay
Relay
85-270V AC/DC
ATC500300400
0-10v
Relay
Relay
85-270V AC/DC
Yes
Yes
Note: Other models, options and accessories available. Please consult factory.
130
800.727.5646
automatictiming.com
很抱歉,暂时无法提供与“ATC500-2001-00”相匹配的价格&库存,您可以联系我们找货
