ATC500-0001-00
ATC500-0001-00
    MUELLERELECTRIC
    温度控制器(RTD,型 B,C,E,J,K,L,N,R,S,T,U,W) 85 ~ 270VAC/DC 面板安装
ATC500-0001-00 数据手册
500 Series CONTROL 1 Contact Rating (SPST): OUTPUT 5a @ 230VAC / 30VDC resistive SPECIFICATIONS SSR Drive (Voltage Pulse): 18VDC 20ma Current: 0/4 to 20ma dc (loop impedence 500 ohms max Voltage: 0 to 5/10 VDC (load resistance 10K ohms min) ALARM 2 OUTPUT SPECIFICATION Contact Rating (SPST): 5a @ 230VAC / 30VDC resistive SSR DRIVE: 12VDC 20ma FUNCTIONAL SPECIFICATION Control Action: PID, On-Off Proportional Band (P): 0.0 to 400.0 deg Integral Time (I): 0 to 3600 sec Derivative Time (D): 0 to 200 sec Cycle Time: 0.1 to 100.0 sec Hysteresis Width: 0.1 to 99.9 deg Manual Reset Value: -99.9 to 99.9 deg HEAT COOL PID Control Action: PID Cycle Time: 0.1 to 100 sec Proportional Gain: 0.0 to 400.0 deg Deadband: Programmable from setpoint low limit to setpoint high limit ALARMS Modes: Deviation high/low, Absolute high/low, band, sensor break Hysterisis: 0.1 to 99.9 deg RAMP SOAK Ramp Rage: 1 to 9999 deg/hr. Soak Time: 0 to 1440 min Soft Start Time: 0 to 999 min. SUPPLY VOLTAGE 85 to 270V AC/DC (50/60 Hz) RETRANSMISSION Current: 0/4 to 20ma DC (loop impedence 500 ohms max) Voltage: 0 to 5/10V DC (load resistance 10k ohms min) Update Rate: 100msec SERIAL COMMUNICATION Interface Standard: RS485 Communication Address: 1 to 99, maximum of 32 units per line Transmission mode: Half duplex Transmission protocol: MODBUS RTU Transmission distance: 500 m maximum Transmission speed: 9600, 4800, 1200, 600, 300 bits/sec. TEMPERATURE Operating: 0 to 50°C (32 to 122°F) Storage: -20 to 75°C (-4 to 167°F) HUMIDITY 95% RH (NON CONDENSING) WEIGHT: 6.4 oz. PROTECTION LEVEL IP65 for faceplate Automatic Timing & Controls 1/16 DIN Advanced, Full Featured PID Temperature Controller • Dual Display, 4 digit, 7 segment LED • Heat Cool PID • TC/RTD Input, Analog Input • Ramp Soak • ON/OFF, PID, PID Autotune • Soft Start • C/F degrees selectable • 1/16 DIN (48 x 48 mm) SPECIFICATIONS DIGITS 4 digit, 7 segment LED Dual Display Height of Upper display: 0.3785" Height of Lower display: 0.2720" LED INDICATIONS Relay On, Alarm, Manual Mode, Tune INPUTS Thermocouple (J,K,T,R,S,C,E,B,N,L,U,W) Platinel II, RTD (Pt100) DC Analog Inputs (-5 to 56mv, 0 to 10v, 0 to 20 ma) SAMPLING TIME 200 ms PID/TEMPERATURE CONTROLLERS POWER 6VA max @ 230 VAC CONSUMPTION E339488 INPUT FILTER (FTC) 0.2 to 10.0 sec RESOLUTION 1/0.1 deg for TC/RTD only Fixed 1 deg resolution for R&S Type TC) Decimal point position selectable: 1/0.1/0.01/0.001 for analog input TEMPERATURE UNIT: C/F deg selectable INDICATION ACC: For TC inputs 0.25% of F.S. ± 1° R&S type TC inputs 0.5% of F.S. ± 2 deg (20 min of warm up time for TC inputs) For RTD inputs 0.1% of F.S. ± 1 deg For Analog Input ± 0.5%, ± 1 digit (F.S. = Full Scale) 800.727.5646 automatictiming.com 129 500 Series COMPLIANCE IEC/EN 61326 (EMI/EMC) IEC/EN 61010 Revision 3 2010 Edition (Safety) UL 61010 Revision 3 2010 Edition (Safety) DIMENSIONS 10mm 48mm 46mm 45mm 48mm 46mm 100mm CURus Cable Size (AWG): 16-13 Tightening Torque (lb-inch): 7 TERMINAL CONNECTIONS + 1 CT / RS485 + 2 – COM2 3 NO2 + 4 – 5 COM1 SSR2 NO2 11 6 – 12 7 13 8 + 14 9 NO3 SSR3 L (+) SSR1/0-5 V/ 0-10 V/4 -20mA PID/TEMPERATURE CONTROLLERS Stud Hole for Lug (inch): 0.137 (-) N TC+ /RTD1 ANA IP+ TC– /RTD2 ANA IP– RTD3 – 15 10 COM3 ORDERING INFORMATION PART NO. OUTPUT 1 OUTPUT 2 OUTPUT 3 COMMUNICATION SUPPLY (RS485) VOLTAGE ATC500000100 Relay Relay Relay 85-270V AC/DC ATC500000400 Relay Relay Relay Yes 85-270V AC/DC ATC500010500 Relay 12V DC SSR 12V DC SSR Yes 85-270V AC/DC ATC500200100 4-20ma Relay Relay 85-270V AC/DC ATC500200400 4-20ma Relay Relay 85-270V AC/DC ATC500300100 0-10V Relay Relay 85-270V AC/DC ATC500300400 0-10v Relay Relay 85-270V AC/DC Yes Yes Note: Other models, options and accessories available. Please consult factory. 130 Automatic Timing & Controls 800.727.5646 automatictiming.com
ATC500-0001-00 价格&库存
很抱歉,暂时无法提供与“ATC500-0001-00”相匹配的价格&库存,您可以联系我们找货
