ATC550-S00000
ATC550-S00000
    MUELLERELECTRIC
    温度控制器(RTD,型 J,K,R,S,T) 85 ~ 270VAC/DC 面板安装
ATC550-S00000 数据手册
SETTINGS FOR ALARM OUTPUT Modes Hysteresis Deviation, Absolute 0.1 to 99.9° E339488 1/16 DIN Temperature Controller SUPPLY VOLTAGE 85 to 270V AC/DC (50/60 Hz) • Dual Display, 4 digit, 7 segment LED • °C/°F selectable POWER CONSUMPTION 6 VA max @ 230V AC • TC/RTD TEMPERATURE Operating: 0 to 50°C Storage: -20 to 75°C • PID ON/OFF Control • Field selectable Control Output (Relay or SSR) • 2 Setpoints • Auxiliary Output: Relay / SSR • Easy to Use HUMIDITY 95% RH (NON CONDENSING) WEIGHT 5 Oz. PROTECTION LEVEL IP65 for faceplate COMPLIANCE IEC/EN 61326 (EMI/EMC) IEC/EN 61010 Revision 3 2010 Edition (Safety) UL 61010 Revision 3 2010 Edition (Safety) SPECIFICATIONS DIGITS 4 digit, 7 segment LED Dual Display Height of Upper display: 0.3785" Height of Lower display: 0.2720" LED INDICATIONS Relay On, Tune, Soak Time INPUTS Thermocouple (J,K,T,R,S) / RTD (Pt100) SAMPLING TIME 250ms PID/TEMPERATURE CONTROLLERS HEAT-COOL Control Action PID (with auto-tuning) Proportional Band-Cool 0.0 to 400.0° Cycle Time-Cool 0.1 to 99.9 sec. Dead Band Programmable from setpoint low limit to setpoint high limit. 550 Series FUNCTIONAL SPECIFICATIONS Control Action 1) PID 2) ON-OFF Proportional Band (P) 1.0 to 400.0° Intergral Time (I) 0 to 9999 sec. Derivative time (D) 0 to 9999 sec. Cycle Time 0.1 to 99.9 sec. Hysteresis Width 0.1 to 99.9° Manual Reset Value -19.9 to 19.9° INPUT FILTER (FTC) 0.2 to 10.0 sec RESOLUTIION 0.1/1 (Fixed 1° for R & S type TC input) TEMPERATURE UNIT °C / °F selectable INDICATION ACCURACY For J, K, & T inputs: 0.25% of F.S. ±1° For R & S inputs: 0.5% of F.S. ±2° (20 min of warm up time for TC inputs) For RTD inputs: 0.1% of F.S. ±1° (F.S. = Full Scale) OUTPUT SPECIFICATIONS Automatic Timing & Controls CONTROL 1 Contact Rating: 5A @250V AC / 30V DC, resistive SSR Drive (Voltage Pulse): 12V DC ±10%,m50mA ALARM 1 Contact Rating: 5A @ 230V AC / 30V DC, resistive SSR Drive 12V DC (50mA) 800.727.5646 automatictiming.com 131 550 Series DIMENSIONS 1 T 2 S 4mm 52 mm N (–) 2 NO2 3 + – COM2 NO1 + 4 INPUT RANGES (TABLE 1) 6 11 SSR1 – SSR2 + PID/TEMPERATURE CONTROLLERS 1 5 + 7 8 SSR1 12 Panel Cutout 94 mm TERMINAL CONNECTIONS L (+) 46mm 45mm 52 mm 46mm – FOR RTD TC+ /RTD1 Input Ranges TC– /RTD2 Resolution 1 0.1 RTD3 Pt100 °C -150 to 850 -150 to 850 °F -238 to 1562 -199 to 999 9 10 COM1 FOR THERMOCOUPLE – COM1 Input Ranges Resolution 1 0.1 J °C -199 to 750 -199 to 750 °F -328 to 1382 -199 to 999 °C -199 to 1350 -199 to 999 °F -328 to 2462 -199 to 999 °C -199 to 400 -199 to 400 °F -328 to 750 -199 to 750 °C 0 to 1750 N/A °F 32 to 3182 N/A K T R&S ORDERING INFORMATION PART NO. CONTROL OUTPUT AUXILARY OUTPUT SUPPLY VOLTAGE ATC550S00000 Relay 12V DC SSR Relay 85-270V AC/DC ATC550S10000 Relay 12V DC SSR 12V DC SSR 85-270V AC/DC Note: Other models, options and accessories available. Please consult factory. 132 Automatic Timing & Controls 800.727.5646 automatictiming.com
ATC550-S00000 价格&库存
很抱歉,暂时无法提供与“ATC550-S00000”相匹配的价格&库存,您可以联系我们找货
