5708A
5708A
    MUELLERELECTRIC
    HOUR METER
5708A 数据手册
5708A Series The 5708A model is an all in one unit that can be used as a timer, counter, frequency meter, and a tachometer. This unit contains 23 functions (15 timer, 6 counter, frequency meter, & tachometer), which are selectable through the set up menu. Engineered with a unique battery cover design for easy battery replacement, this unit needs no external power source. • Functions as a Timer, Counter, Frequency Meter or Tachometer • 8-digit High Resolution LCDI • Front IP66 Water Protection • 15 Selectable Display Options • Battery Operated TIMER Display Unit day/hour/min/sec 15 Display functions(Selectable) COUNTER Frequency Response is programmable for elimination of outside Switch key-bounce, and edge trigger. RESET Front Panel / Remote
5708A 价格&库存
很抱歉,暂时无法提供与“5708A”相匹配的价格&库存,您可以联系我们找货
