ARA, ARB Series
The Duplexor is used in control panels where two loads are required to
alternate to provide equal run time on the loads. The alternating action is initiated
by a control switch, which is common with one side of the control voltage. The
output contacts will change states each time the control switch is opened, thus
alternating the two loads. The LED indicators show the position of the output
relay.
The ARA Series is the standard Duplexor providing automatic alternating
sequence. The ARB has the automatic sequencing feature plus the option of
locking it into one sequence. A three position switch permits the field selection of
normal duplexing action, locking in the A-B sequence, or B-A sequence.
E55826
SPECIFICATIONS
CONTROL VOLTAGE 24, 120 VAC/DC, 208, 240, 50/60Hz,
CONTROL SWITCH 1 mA
CURRENT
Duplexor
POWER REQUIRED 3 VA (Approximately)
ALTERNATING RELAYS & CONTROLLERS
DIMENSIONS (INCHES)
DUTY CYCLE
Continuous
LIFE EXPECTANCY
Mechanical 10,000,000 Operations (Minimum)
Electrical 100,000 Operations @ Rated Load
INDICATORS
LED Shows Output Position
TEMPERATURES
RATING
Operate
Storage
-4° to 131°F (-20° to +55°C)
-40° to 185°F (-40° to +85°C)
CONTACT RATING 10 Amps @ 240 VAC, Resistive 1/8 hp @ 120 VAC
1/4 hp @ 240 VAC Inductive, 360 VA @ 240 VAC,
Inductive
ENCLOSURE
“A” Lexan® Dust Cover
TERMINATIONS
Industrial Plug-in
WEIGHT
4.5 oz.
MODEL NUMBER
MODEL NUMBER
WIRING
AR A A
TYPE OF ALTERNATING RELAY
Standard Duplexor
Special Function Duplexor
A
B
CONTROL VOLTAGE
24 VAC/DC
120 VAC/DC
208 VAC
240 VAC
24
120
208
240
TYPE OF VOLTAGE
VAC or VAC/DC
A
CONTACT CONFIGURATION
SPDT
B
DPDT (Cross Wired)
C
DPDT
D
DPDT (Cross Wired)
E
ENCLOSURE STYLE
A
190
Diversified Electronics
800.727.5646
atcdiversified.com
很抱歉,暂时无法提供与“ARB-120-ABA”相匹配的价格&库存,您可以联系我们找货
