CLB-120-ALE-5
CLB-120-ALE-5
    MUELLERELECTRIC
    电流变送器 输入 10A 输出 120VAC 底座安装
CLB-120-ALE-5 数据手册
CLB Series OPERATION The CLB Series is designed to protect three phase equipment against CURRENT UNBALANCE and OVER CURRENT conditions. The control voltage is continuously applied to supply the sensing circuitry and the internal relay. When the current of any phase approximately 20% above the maximum operating current, the inrush delay begins. This delay disables the over current sensors while high inrush currents are present. Any time the currents are outside the preset limits after completion of the inrush delay, the internal relay will de-energize (Drop-out). A 2% differential (hysteresis) between Pick-up and Drop-out is incorporated to prevent chattering when operated in the automatic reset mode and the current is at the trip point. 3-Phase Current Unbalance & Over Current Monitor The reset mode is selected as follows: AUTOMATIC: Place a jumper between pins ten (10) and eleven (11). MANUAL: Place a normally open switch between pins ten (10) and eleven (11). When there is a loss and reapplication of the control voltage, the external switch must be closed before the circuit will again become operative. CURRENT MONITORS SPECIFICATIONS OPERATING VOLTAGE 3-Phase, 50/60 Hz, 600 V max CONTROL VOLTAGE 120 VAC, 50/60 Hz OVER CURRENT See Table for Adjustable Ranges UNBALANCE RANGE 5% to 25%, Adjustable INRUSH DELAY 0.1 To 10 SEC, Adjustable; Initiated When Current of Any Phase rises 20% Above the Max. Operating Current OUTPUT SPDT, 10 amp @ 240 VAC Resistive HYSTERESIS 2% of Unbalance Setting RESPONSE TIME Operate Release INDICATOR LED Glow When All Conditions Are Normal RESET Automatic or Manual TEMPERATURE RATING Operate Storage WEIGHT 13 oz. DIMENSIONS (INCHES) 1 Second, Max. 100 mSEC 32° to 131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) WIRING MODEL NUMBER CONTROL RANGE CLB-120-ALE-5 120 VAC CLB-120-ALE-10 120 VAC 178 OVER CURRENT RANGE 1.0 to 5.0 amps, Adjustable 2.0 to 10 amps, Adjustable Diversified Electronics 800.727.5646 atcdiversified.com
CLB-120-ALE-5 价格&库存
很抱歉,暂时无法提供与“CLB-120-ALE-5”相匹配的价格&库存,您可以联系我们找货
