CT Series
OPERATION
The CT Current Transformers are of the inserted primary type with
the secondary toroidally wound over a core of oriented electrical steel.
The windings are carefully insulated. The entire transformer is then
dipped in PVC insulation compound which insures maximum protection
against moisture, acids, alkaline, oils and abrasive particles. The
securely fastened 24” 14 AWG leads are identified to the extent that
the secondary current leaving the CT through the white lead is in
phase with the primary current when the primary conductor enters
the CT from the side identified by the black dot. To prevent shock and
transformer damage, it is important that the secondary leads always
form a continuous circuit when the current is flowing in the primary.
An External CT may be used to extend the range of the AC Current
Monitors.
DIMENSIONS (INCHES)
• 600 Volt Insulation
• 25 - 400 Hz Operation
• 25/5 to 2500/5 Amperes
• Optional Mounting Bracket (Add Suffix-B to part number)
SPECIFICATIONS
CT-25/5
CT-50/5
CT-100/5
CT-200/5
CT-500/5
CT-1000/5
CT-2500/5
25/5
50/5
100/5
200/5
500/5
1000/5
2500/5
2 V.A.
6.00%
2 V.A.
6.00%
2 V.A.
3.00%
2 V.A.
1.50%
2 V.A. .60%
2 V.A. .30%
5 V.A. .10%
1
2
3
3
3
4
5
3 lb. 5 oz.
1lb. 6 oz.
1lb. 4.5 oz.
15 oz.
1 lb. 1 oz.
3 lb.
3 lb. 4 oz.
NOTES:
GROUP
SIZE
1
2
3
4
5
A
B
C
I
1-1/4
1-1/4
1-1/4
1-7/8
3-3/8
3-3/4
3-7/8
3-1/2
4
6-1/2
2-3/4
1-1/4
1-1/4
1-1/4
1-11/16
5-1/4
4-1/2
4-1/2
4-1/2
7-7/8
II
III
IV
4 2-1/8 0.281 x 0.5
3-7/8 7/8 0.250 x 0.375
6-1/2 1-1/8 0.281 x .5
1. The current ratio in the table is the ratio of current in the primary/
secondary with one turn on the primary. The ratio can be increased by
adding turns on the primary.
2. The transformers may be installed at some distance from the load.
However, the interconnecting conductor resistance must not cause the
VA rating of the transformer to be exceeded.
CURRENT MONITORS
MODEL RATIO CAPACITY ACCURACY GROUP WEIGHT
3. CTs should not be operated at twice the rated currents. For example,
CT-25/5 should not operate above 50/10 amps. With current too high
overheating will occur.
WIRING
Diversified Electronics
800.727.5646
atcdiversified.com
187
THREE PHASE CURRENT UNBALANCE
Example:
Balanced or matched currents on a three phase system are difficult
to maintain because of the many varying factors involved such as,
unequal single phase loading, poor connections and cabling and/or
dirty or burnt starter contacts.
Although these varying factors can be controlled to maintain as close
as possible a balanced line, the unseen conditions such as overheated
motor windings, burnt bearings, low voltage, high voltage and single
phasing need to be constantly monitored to protect your valuable
equipment.
Measure the current on each leg.
Assume
A = 10 amps
B = 12 amps
C = 9 amps
2.
Find Average 10 + 12 + 9 = 31
31
= 10.33
3
The CLB Series Three Phase Current Unbalance and Over Current
Monitor (page 176) offers this protection.
To determine the condition of your three phase line and to properly
select the CLB Series percent unbalance setting a simple calculation
formula is needed as follows:
1.
(I max - I avg)
x 100
I max
I max = 12
I avg = 10.33
Apply formula 12 - 10.33 = 1.67
3.
1.67
= .139 x 100 = 13.9% unbalance
12
CURRENT MONITORS
EXTERNAL CURRENT TRANSFORMERS
The load or burden that can be connected to the secondary of the
Current Transformer is usually specified in VA. The rated accuracy of
the Current Transformer is guaranteed only when the sum of the VA
ratings of all devices (ampmeters, wattmeters, current monitors, etc.)
connected to the secondary windings does not exceed the specified
VA rating.
If the only load on the Current Transformer is a DE Current Monitor,
its VA rating (approx. 0.15 VA) is small compared to the Current
Transformer rating and can be neglected. This means that the resistance of the wiring can be 80 milliohms max. for the 2 VA units and
200 milliohms max for the 5 V A unit.
Gauge
Ohms per 1000'
Milliohms per foot
The interconnecting conductor resistance must also be considered,
especially when the Transformer is installed at some distance from the
Current Monitor or other load.
AWG 14
2.5
2.5
AWG 16
4.0
4.0
For the wiring, the VA can be calculated using Ohm’s Law:
AWG 18
6.4
6.4
VA = E x I = (I x R) x I = I2R
AWG 20
10.0
10.0
Where I = 5 Amps and R is the DC resistance of the wire.
Example:
All of the standard DE Current Transformers have a rating of 2 VA
except the 2500/5 version which has a 5 VA rating.
For a 2 VA Current Transformer, the length of AWG 16 wire would be:
From the above formula we can also calculate the maximum resistance
that can be connected to the secondary of a Current Transformer:
VA=I R, Hence R = VA
I2
2
Example:
VA = 2
VA = 5
188
Rmax = VA = 2 = 0.08 Ohms = 80 milliohms
I2
(5)2
Rmax = VA = 5 = 0.2 Ohms = 200 milliohms
I2
(5)2
80 milliohms
4.0 milliohms/ft
= 20'
Because we are dealing with a pair of wires, the maximum distance
from the Current Transformer to the Current Monitor can be only 10
ft.
As we can see, it is important to keep the wire length to minimum,
use heavy wire, and keep all connections clean and tight.
800.727.5646
atcdiversified.com
ALTERNATING CONTROLLERS
ATC-Diversified Electronics offers a wide variety of models for various
staging requirements. The different models available are: Duplexors,
Triplexors, Quadraplexors, Special Function, and Expandable
Alternating Relays.
The Alternating Relay is used in multiple load installations to assure
equal run time on all loads. They also allow for the addition of more
capacity in the event of excess load requirements. The Alternating
Relay provides equal run time on two or more loads by alternating
the sequence in which the loads are allowed to start up. In each case,
the alternating action is initiated each time the control switch across
designated terminal opens. The control switch may be a float, a
thermostat, a pressure switch, or a timer contact.
The ARM Series, Alternating Controllers, are used in multiple
load installations to assure equal run time on all loads. They also
allow for the addition of more capacity in the event of excess load
requirements. The Alternating Controllers provide equal run time on
two or more loads by alternating the sequence in which the loads are
All ARM models feature intrinsically safe inputs and logic that
allows the outputs to operate even if one of the inputs fails to open
or close. For example: if the off switch fails to close, the lead load will
not energize until both the lead and the lag switches close. An inrush
delay on all models reduces line sags by preventing multiple loads
from energizing simultaneously.
ARA, ARM Series
ALTERNATING RELAYS
ARM-XXX-ABEP
ARA-XXX-AGE
ARM-XXX-ACE
ARA-120-AHE
ARM-XXX-ACEP
ARA-120-AJE
ARM-XXX-ADE
ARA-120-AME
ARM-XXX-ADEP
ARA-120-ANE
ARM-XXX-AFE
ARB-XXX-ABA
ARM-XXX-AFEP
ARB-XXX-ACA
ARM-XXX-AGE
ARB-XXX-ADA
ARM-XXX-AGEP
ARB-XXX-AEA
ARM-XXX-AHE
ARC-XXX-AAA
ARM-XXX-AHEP
ARD-XXX-AAA
AUC-XXX-AAA
PUMP & LEVEL CONTROLS
ARA-XXX-AFE
UL LISTED 913
ARM-XXX-ABE
LEAD SELECT
ARA-XXX-AEA
OMIT
ARM-XXX-AAEP
OUTPUT LOGIC (FOSO)
ARA-XXX-ADA
4
OUTPUT LOGIC (SOSO)
ARM-XXX-AAE
3
SELECTABLE SEQUENCING
ARA-XXX-ACA
2
AUTOMATIC ALTERNATING
Model Number
PANEL MOUNT
ARA-XXX-ABA
STYLE SURFACE MOUNT
CSA CERTIFIED
NUMBER OF LOADS
SEQUENCED
FEATURE MATRIX
UL LISTED
E
UL/CANADIAN UL RECOGNIZED
A
FIELD SELECTABLE SEQUENCING
4
3
EXTERNAL CLOCKING
2
EXPANDABLE
Model Number
ENCLOSURE STYLE
NUMBER OF LOADS
SEQUENCED
FEATURE MATRIX
AUD-XXX-AAA
800.727.5646
atcdiversified.com
189
很抱歉,暂时无法提供与“CT-1000/5”相匹配的价格&库存,您可以联系我们找货
