MAR Series
OPERATION
The MAR series provides automatic restart to a motor by
bypassing the start switch to re-energize M1 starter coil following
a momentary drop or interruption of the control voltage. When
control voltage drops below the under voltage trip point while
the motor is running, the under voltage delay begins. If control
voltage returns above the restart voltage point before the under
voltage delay expires, the adjustable restart delay begins. Upon
expiration of the restart delay, the internal relay energizes for
the duration of the output interval providing restart. If control
voltage fils for longer than the under voltage time delay or the
motor was not initially running when control voltage failed, the
unit will not restart the motor after restoration of poser. Instead
a manual restart is required. This relay distinguishes between
control voltage failures and stop pushbutton operations. A
stop pushbutton operation de-energizes the output relay and
terminates the timing sequences preventing an automatic restart.
E55826
MOTOR AUTO-RESTART RELAY
Motor Auto-Restart Relay
SPECIFICATIONS
CONTROL VOLTAGE
INPUT
SPECIFICATIONS
120 VAC 50/60 Hz
Under Voltage: 92 VAC Factor Preset
(70-100 VAC Internal Adjust)
Restart Voltage: 102 VAC Factor Preset
(10 VAC ±10% Above U.V.)
OUTPUT
SPDT Relay, Pilot Duty B150, 360 VA
10 Amps @ 120 VAC Resistive
30,000 Operations Electrical @ Full Load
3 VA Max
Operate: 0°C to 55°C
Storage: -45°C to 85°C
Style Extended "A" LEXAN® Dust Cover
8 Pin Plug-in (Model AAA)
8 Pin Plug-in with OL Relay
L2 Disconnect Feature (Model ABA)
11 Pin Plug-in (Model ACA)
11 Pin Plug-in with OL Relay
L2 Disconnect Feature (Model ADA)
POWER REQUIRED
TEMPERATURES
ENCLOSURE
TERMINATIONS/
FUNCTION
170
DIMENSIONS
Diversified Electronics
800.727.5646
.15” max.
3.60”
atcdiversified.com
.15” max.
3.60”
START
STOP
START
STOP
M1
STOP
M1
M1
START
STOP
M1
START
MAR Series
WIRING
M1
4
AAA
M1
5
4
5
7
1
2
8
1
M1
11
CONTROL
VOLTAGE
ABA
STOP
M1
6
8
2
11
CONTROL
VOLTAGE
CONTROL
AAA
M1
5
OL
L1 VOLTAGE L2
L1 VOLTAGE L2
START
6
8
2
8
REACCEL
AVAIL
CONTROL
STOP
5
7
REACCEL
AVAIL
START
ABA
M1
2
STOP
M1
OL
ACA
ADA
STOP
START
M1
START
M1
M1
5
7
2
1
8
REACCEL
AVAIL
CONTROL
L1 VOLTAGE L2
AAA
4
5
2
OL
M1
ACA
6
5
M1
5
OL
8
6
ADA
8
7
1
2
8
2
11
CONTROL
VOLTAGE
REACCEL
AVAIL
11
Note: Wiring must be exactly as
shown for proper operation
CONTROL
VOLTAGE
CONTROL
L1 VOLTAGE L2
ABA
ACA
ADA
ORDERING INFORMATION
MODEL NUMBER
CONTROL VOLTAGE
Delay Range
MAR 120
120 VAC 50/60 HZ
120
TERMINATIONS/FUNCTION
8 Pin Plug-in
AAA
D
ABA
D
11 Pin Plug-in
ACA
A or C
ADA
B
DELAY RANGE DESCRIPTIONS
4
A — U.V. 0.2 to 6.0 sec, Restart Delay 0.2 to 60 sec.
Restart Output Interval - Continuous
B — U.V. 0.2 to 6.0 sec, Restart Delay 0.2 to 60 sec.
Restart Output Interval - 5.0 sec (fixed)
C — U.V. 0.2 to 10.0 sec, Restart Delay 0.2 to 60 sec.
Restart Output Interval - 1.0 sec (fixed)
D — U.V. 4.0 sec (fixed), Restart Delay 2.0 to 120 sec.
Under voltage screwdriver adjustable ranges ± 10%
Restart delay screwdriver adjustable ranges ± 10%
Under voltage and restart output interval fixed ranges ± 10%
800.727.5646
atcdiversified.com
171
很抱歉,暂时无法提供与“MAR-120-AAA-D”相匹配的价格&库存,您可以联系我们找货
