PBD-120-ALE
PBD-120-ALE
    MUELLERELECTRIC
    电压感测 AC,相序 120VAC
PBD-120-ALE 数据手册
OPERATION IND. CONT. EQ 496Y With normal operating voltages applied in the proper ABC sequence, the internal relay will energize (PICK-UP). When the voltages on any or all phases fall outside the preset Over/Under trip points for longer than the Adjustable Release delay, the relay will de-energize (DROPOUT). When line conditions return to normal, the PBD Series Monitor automatically resets and the internal relay energizes. PBD Series The PBD Series offers protection to three-phase sequence sensitive equipment that is required to operate between two voltage limits. All three phases are monitored individually for a pre-selected UNDER and OVER VOLTAGE limit, with adjustable release delay. Both Delta and Wye systems may be monitored. In Wye systems, connections to neutral are not required. The LED fault indicators aid in set up and system troubleshooting, and glow on fault condition. The LED indicators have an immediate response to voltage conditions and operate independently of the relay. In a phase reversal condition the LED responds to voltage conditions but the relay will NOT energize. DIMENSIONS (INCHES) PHASE VOLTAGE MONITORS The Adjustable Release Delay is provided to ignore momentary voltage fluctuations that cause nuisance tripping. 3 Phase Sequence & Voltage Band Monitor/Relays The HYSTERESIS in each unit provides a differential of 4% between the PICK-UP and DROP-OUT trip points. The PBD Series is UL Listed under UL File Number E55826. SPECIFICATIONS OUTPUT RATING DPDT, 10Amps @ 240 VAC, Resistive; 360 VA @ 600 VAC, Inductive; 1/2 hp POWER REQUIRED Models Up to 300 VAC Models Over 300 VAC 7 VA, Max 6 VA, Max RESET Automatic PHASE SEQUENCE ABC (Will Not Operate CBA) HYSTERESIS 4% REPEAT ACCURACY 0.1% @ Fixed Condition INDICATORS LED Glows On Fault; (1) For Over, (1) For Under RESPONSE TIMES Operate Release 100 mSEC 0.1 to 30 SEC, Adjustable TEMPERATURE RATING Operate Storage 32° to +104°F (0° to +40°C) -49° to 185°F (-45° to +85°C) WEIGHT 19 oz. MODEL NUMBER MAXIMUM VOLTAGE WIRING ADJUSTABLE RANGES UNDER OVER PBD-120-ALE 155 VAC 90-120 120-150 PBD-230-ALE 275 VAC 185-240 208-265 PBD-400-ALE 485 VAC 325-385 415-475 PBD-440-ALE 550 VAC 390-480 440-540 PBD-480-ALE 570 VAC 400-490 460-560 PBD-575-ALE 700 VAC 500-610 540-690 All voltages referenced on this page are phase-to-phase. Diversified Electronics 800.727.5646 atcdiversified.com 157
PBD-120-ALE 价格&库存
很抱歉,暂时无法提供与“PBD-120-ALE”相匹配的价格&库存,您可以联系我们找货
