MAR-120-ABA-D
MAR-120-ABA-D
    MUELLERELECTRIC
    电压检测 AC 120VAC
MAR-120-ABA-D 数据手册
MAR Series OPERATION The MAR series provides automatic restart to a motor by bypassing the start switch to re-energize M1 starter coil following a momentary drop or interruption of the control voltage. When control voltage drops below the under voltage trip point while the motor is running, the under voltage delay begins. If control voltage returns above the restart voltage point before the under voltage delay expires, the adjustable restart delay begins. Upon expiration of the restart delay, the internal relay energizes for the duration of the output interval providing restart. If control voltage fils for longer than the under voltage time delay or the motor was not initially running when control voltage failed, the unit will not restart the motor after restoration of poser. Instead a manual restart is required. This relay distinguishes between control voltage failures and stop pushbutton operations. A stop pushbutton operation de-energizes the output relay and terminates the timing sequences preventing an automatic restart. E55826 MOTOR AUTO-RESTART RELAY Motor Auto-Restart Relay SPECIFICATIONS CONTROL VOLTAGE INPUT SPECIFICATIONS 120 VAC 50/60 Hz Under Voltage: 92 VAC Factor Preset (70-100 VAC Internal Adjust) Restart Voltage: 102 VAC Factor Preset (10 VAC ±10% Above U.V.) OUTPUT SPDT Relay, Pilot Duty B150, 360 VA 10 Amps @ 120 VAC Resistive 30,000 Operations Electrical @ Full Load 3 VA Max Operate: 0°C to 55°C Storage: -45°C to 85°C Style Extended "A" LEXAN® Dust Cover 8 Pin Plug-in (Model AAA) 8 Pin Plug-in with OL Relay L2 Disconnect Feature (Model ABA) 11 Pin Plug-in (Model ACA) 11 Pin Plug-in with OL Relay L2 Disconnect Feature (Model ADA) POWER REQUIRED TEMPERATURES ENCLOSURE TERMINATIONS/ FUNCTION 170 DIMENSIONS Diversified Electronics 800.727.5646 .15” max. 3.60” atcdiversified.com .15” max. 3.60” START STOP START STOP M1 STOP M1 M1 START STOP M1 START MAR Series WIRING M1 4 AAA M1 5 4 5 7 1 2 8 1 M1 11 CONTROL VOLTAGE ABA STOP M1 6 8 2 11 CONTROL VOLTAGE CONTROL AAA M1 5 OL L1 VOLTAGE L2 L1 VOLTAGE L2 START 6 8 2 8 REACCEL AVAIL CONTROL STOP 5 7 REACCEL AVAIL START ABA M1 2 STOP M1 OL ACA ADA STOP START M1 START M1 M1 5 7 2 1 8 REACCEL AVAIL CONTROL L1 VOLTAGE L2 AAA 4 5 2 OL M1 ACA 6 5 M1 5 OL 8 6 ADA 8 7 1 2 8 2 11 CONTROL VOLTAGE REACCEL AVAIL 11 Note: Wiring must be exactly as shown for proper operation CONTROL VOLTAGE CONTROL L1 VOLTAGE L2 ABA ACA ADA ORDERING INFORMATION MODEL NUMBER CONTROL VOLTAGE Delay Range MAR 120 120 VAC 50/60 HZ 120 TERMINATIONS/FUNCTION 8 Pin Plug-in AAA D 8 Pin Plug-in with OL Relay L2 Disconnect Feature ABA D 11 Pin Plug-in ACA A or C ADA B 11 Pin Plug-in with OL Relay L2 Disconnect Feature DELAY RANGE DESCRIPTIONS MOTOR AUTO-RESTART RELAY 4 A — U.V. 0.2 to 6.0 sec, Restart Delay 0.2 to 60 sec. Restart Output Interval - Continuous B — U.V. 0.2 to 6.0 sec, Restart Delay 0.2 to 60 sec. Restart Output Interval - 5.0 sec (fixed) C — U.V. 0.2 to 10.0 sec, Restart Delay 0.2 to 60 sec. Restart Output Interval - 1.0 sec (fixed) D — U.V. 4.0 sec (fixed), Restart Delay 2.0 to 120 sec. Restart Output Interval - 5.0 sec (fixed) Under voltage screwdriver adjustable ranges ± 10% Restart delay screwdriver adjustable ranges ± 10% Under voltage and restart output interval fixed ranges ± 10% Diversified Electronics 800.727.5646 atcdiversified.com 171
MAR-120-ABA-D 价格&库存
很抱歉,暂时无法提供与“MAR-120-ABA-D”相匹配的价格&库存,您可以联系我们找货
