SLA-440-ALER
SLA-440-ALER
    MUELLERELECTRIC
    失相,相序,电压感测 AC 440VAC
SLA-440-ALER 数据手册
The ATC Diversified SLA Series is designed to protect 3-phase equipment against PHASE LOSS, UNDER VOLTAGE, and PHASE REVERSAL conditions. SLA Series Style "A" With normal operating voltages applied in the proper ABC sequence, the internal relay will energize (PICK-UP). When incorrect phase sequence or phase loss occurs or the three-phase voltages fall below the drop out voltages, the relay will de-energize (DROP-OUT). On models featuring indicators, the LED glows when all line conditions are normal. IND. CONT. EQ. 496Y Both Delta and Wye systems may be monitored. In Wye systems, connections to neutral are NOT required. For UL Listed units, with field wiring terminals, copper wire with 60°/75°C rating must be used for control circuitry connections. Style "N" Style "E" NOTE: When a phase is lost while the motor is running, a condition known Phase Monitors as regeneration occurs where a voltage is induced into the open phase PROTECTS 3-PHASE EQUIPMENT nearly equal in magnitude to the normal phase-to-phase voltage. However, • Available up to 480 VAC AGAINST: with the exception of lightly loaded motors, enough change is detected by (625 VAC with "E" style) the SLA to provide the required protection when properly adjusted. The • Phase Loss • Delta or Wye Systems SLA Series is UL Listed under file Number E55826. • Fixed, Lock Shaft, or Screwdriver • Under Voltage Adjustments • Phase Reversal SPECIFICATIONS • Several Enclosure Styles 1 Ø Low 3 Ø Low RESPONSE TIMES Models Up to 300 VAC 83% of Nominal 90% of Nominal TYPICAL APPLICATIONS • Air Handlers • Irrigation Pumps • Computer Power Protection • Lift Station Pumps STYLE "A" & "E" Operate 250 mSEC • Conveyor Drive • Robotics Equipment Release 0.5 SEC • Water Waste & Sewage Machinery • Elevator Drives Models Over 300 VAC • Oil & Gas Pumps Operate 1.0 SEC • Sawmill & Woodpump Machinery Release 2.0 SEC • Power Substation • Commercial/Industrial Air Conditioning & Refrigeration Compressors 60 mSEC 0.5 SEC • Automatic Transfer Switching for Monitoring Emergency Power Supplies RESPONSE TIMES Operate STYLE "N" Release POWER Style "A" 3 VA (approximately) REQUIRED Style "E" Models up to 300 VAC: 3 VA (max.) Models over 300 VAC: 7 VA (max.) Models up to 500 VAC: 3 VA (max.) Style "N" 3 VA (max.) OPERATING See Ordering Information VOLTAGE RESET Automatic (Manual Optional) INDICATOR LED Glows when all conditions are Normal (On Applicable Models) OUTPUT RATING SPDT (Style "A" and "N") DPDT (Style "E") PHASE SEQUENCE ABC (Will not Operate CBA) TEMPERATURE Operate 32 to +131 F (0 to +55C) RATING Storage -49 to 185 F (-45 to +85 C) U.S. PATENT 3,611,050 NUMBER WEIGHT Style “A” Style “N” Style “E” NET:2.24 oz Shipping: 2.56 oz NET:4.8 oz Shipping: 5.76 oz. NET:5.3 oz Shipping: 5.6 oz Diversified Electronics PHASE VOLTAGE MONITORS DROP OUT VOLTAGE MODEL NUMBER MODEL NUMBER SLA A OPERATING VOLTAGE See Ordering Information XXX TYPE OF OPERATION Fixed F Lock Shaft Adjusted L Screwdriver Adjusted S ENCLOSURE STYLE Octal Plug-In Dust Cover A Blad Plug-In, Dust Cover B Surface Mounted, #8 Screw Terminals E Surface Mounted, 1/4" Quick Disconnect Terminals N OPTIONS Add R Suffix when manual reset is required, (Available only in Style "E" Enclosure) Plug-In models are UL Listed only when used with R U RB-08 socket. 800.727.5646 atcdiversified.com 153 SLA Series STYLE "A" DIMENSIONS (INCHES) PHASE VOLTAGE MONITORS STYLE "A" STYLE "E" STYLE "N" WIRING STYLE "B" 2.375" STYLE "A" Figure 1 RB-08 or OT-08 Figure 2 RB-11 1.75" STYLE "E" STYLE "E" Figure 4 STYLE "N" 154 Figure 3 70-463-1 STYLE "N" Diversified Electronics 800.727.5646 atcdiversified.com Figure 5 STYLE A PLUG-IN OPERATING VOLTAGE SLA-120-ALA SLA-120-ASA 95-130 Adj SLA-230-ALA SUA-120-ALA SUA-120-ALAU* SUA-230-ALA SUA-230-ALAU* SUA-380-ASA SUA-440-ASA AGENCY APPROVAL Screwdriver — 79-108 85-117 — Lock Shaft 190-270 Adj. SLA-230-ASB SLA-380-ASA SLA-440-ASA DROP-OUT VOLTAGE 1 Ø LOW 3 Ø LOW Lock Shaft SLA-120-ASB SLA-230-ASA TYPE OF ADJUSTMENT 158-224 171-243 — Screwdriver 350-440 Adj. 430-480 Adj. 290-365 357-398 315-396 387-432 95-130 Adj. 79-108 85-117 — IND. CONT. EQ 496Y Lock Shaft 190-270 Adj. 350-440 Adj. 430-480 Adj. Screwdriver 158-224 171-243 290-365 357-398 315-396 387-432 OUTPUT RATINGS DPDT, 345 VA Inductive; 10 Amps Resistive @ 240 VAC. Figure 2 SPDT, 345 VA Inductive; 10 Amps Resistive @ 240 VAC, Figure 1 SPDT, 345 VA Inductive; 10 Amps Resistive @ 240 VAC, Figure 3 DPDT, 345 VA Inductive; 10 Amps Resistive @ 240 VAC, Figure 2 SPDT, 345 VA Inductive; 10 Amps Resistive @ 240 VAC, Figure 1 SPDT, 345 VA Inductive; 10 Amps Resistive @ 240 VAC, Figure 3 SPDT, 360 VA Inductive; 10 Amps Resistive @ 240 VAC, Figure 1 SPDT, 345 VA Inductive; 10 Amps Resistive @ 240 VAC, Figure 1 IND. CONT. EQ 496Y SPDT, 10 Amps Resistive @ 240 VAC, Figure 1 *UL Listed only when used with RB-08 relay socket; 5 Amps Resistive @ 240 VAC. All voltages referenced on this page are phase-to-phase. Models also available with fixed operating voltages. Consult factory. STYLE E SURFACE MOUNTED ENCLOSURE MODEL NUMBER SLA-120-ALE SLA-120-ALER SLA-230-ALE SLA-230-ALER SLA-380-ALE SLA-380-ALER SLA-440-ALE SLA-440-ALER SLA-575-ALE OPERATING VOLTAGE DROP-OUT VOLTAGE 1 Ø LOW 3 Ø LOW 95-130 Adj. 79-108 190-270 Adj. 350-440 Adj. 430-480 Adj. 525-625 Adj. 158-224 290-365 357-398 436-519 85-117 171-243 315-396 387-432 473-563 AGENCY APPROVAL IND. RESET CONT. EQ 496Y Automatic IND. CONT. EQ 496Y Manual IND. CONT. EQ 496Y Automatic IND. CONT. EQ 496Y Manual IND. CONT. EQ 496Y Automatic IND. CONT. EQ 496Y Manual IND. CONT. EQ 496Y Automatic IND. CONT. EQ 496Y Manual IND. CONT. EQ 496Y Automatic OUTPUT RATINGS DPDT, 211 VA Inductive; 10 Amps Resistive @ 120 VAC. Figure 4 DPDT, 211 VA Inductive; 10 Amps Resistive @ 120 VAC. Figure 4 DPDT, 345 VA Inductive; 5 Amps Resistive @ 240 VAC. Figure 4 DPDT, 345 VA Inductive; 5 Amps Resistive @ 240 VAC. Figure 4 DPDT, 360 VA Inductive; 3 Amps Resistive @ 600 VAC. Figure 4 SPDT, 360 VA Inductive; 3 Amps Resistive @ 600 VAC. Figure 5 DPDT, 360 VA Inductive; 3 Amps Resistive @ 600 VAC. Figure 4 SPDT, 360 VA Inductive; 3 Amps Resistive @ 600 VAC. Figure 5 DPDT, 360 VA Inductive; 3 Amps Resistive @ 600 VAC. Figure 4 PHASE VOLTAGE MONITORS MODEL NUMBER SLA Series ORDERING INFORMATION All voltage referenced are phase-to-phase.—Models also available with fixed operating voltages. Consult factory. STYLE N EPOXY ENCAPSULATED MODEL NUMBER SLA-120-AFN SLA-208-AFN SLA-220-AFN SLA-240-AFN OPERATING VOLTAGE 120 208 220 240 TYPE OF OPERATION Fixed Fixed Fixed Fixed DROP-OUT VOLTAGE 1 Ø LOW 3 Ø LOW 100 173 183 199 AGENCY APPROVAL 108 187 198 216 SPDT 180VA @ 120VAC; 72VA @ 24VAC; All voltage referenced are phase-to-phase. SPDT 180 va @ 120 vac, 72 va @ 24 vac. Diversified Electronics 800.727.5646 atcdiversified.com 155
SLA-440-ALER 价格&库存
很抱歉,暂时无法提供与“SLA-440-ALER”相匹配的价格&库存,您可以联系我们找货
