SLM-575-ASE
SLM-575-ASE
    MUELLERELECTRIC
    频率,失相,相序,电压感测 AC 575VAC
SLM-575-ASE 数据手册
PROTECTS 3-PHASE EQUIPMENT AGAINST: • Under Voltage • Over Voltage • Phase Loss • Phase Reversal • Phase Unbalance • Phase Shift • Frequency Shift SLM Series • Models available up to 690 VAC • Automatic or Manual Reset • Delay-on-Make Timer • LED Indicators for Fault Conditions • Last Fault Memory SCREWDRIVER ADJUSTMENT FOR: • Time Delay • Voltage • Mode of Operation IND. CONT. EQ. 496Y SPECIFICATIONS VOLTAGE TRIP POINTS Drop-Out ±10% of Setting Pick-Up ± 7% of Setting Microprocessor Based 3-Phase Monitor FREQUENCY TRIP Drop-Out ±4% of 60 Hz (380 V, 50 Hz) POINTS Pick-Up ±3% of 60 Hz (380 V, 50 Hz) UNBALANCE TRIP Drop-Out 7% POINTS Pick-Up 5% RESET Automatic; Manual; Automatic with Memory* DIMENSIONS (INCHES) PHASE VOLTAGE MONITORS PHASE SEQUENCE ABC (Will Not Operate CBA) OUTPUT RATING DPDT, 360 VA Inductive; 1/2 hp 3 A Resistive @ 600 VAC SLM (120, 230) ASE - DPDT, 470 VA 10A Resistive@240VAC TERMINATIONS #8-32 Screw Terminals INDICATORS Designation Color State Condition LED* Time Delay Green Flashing Timing Output Normal ON Energized *Automatic with Memory Under Voltage Red ON Fault MODE: The Over Voltage Red ON Fault last fault is indicated and Phase Sequence, Red ON Fault remains on Shift when condiFrequency Shift Red ON Fault tions return to normal. Unbalance Red ON Fault WIRING The indicator Operate extinguishes Sampling 2 SEC only with reset or when new Reset Delay (Sampling Delay) + (1.5 seconds fault condition to 5 minute Delay) Adjustable in one occurs. (1) minute increments Release Under Voltage Over Voltage Frequency Shift Unbalance *Phase Loss/Shift 1.5 SEC, (approx.) 1.5 SEC, (approx.) 1.5 SEC, (approx.) 2.0 SEC, (approx.) 1.0 SEC, (approx.) TEMPERATURE RATING 32° to +131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) Operate Storage POWER REQUIRED 7 VA Typical TRANSIENT PROTECTION 2500 Volts for 10 ms ENCLOSURE Lexan Surface Mounted WEIGHT 22 oz. Diversified Electronics MODEL NUMBER NOMINAL PHASE-TO-PHASE VOLTAGE SET POINTS MAXIMUM VOLTAGE SLM-120-ASE 105, 110, 115, 120, 125, 130 143 VAC S LM-230-ASE 200, 210, 220, 230, 240, 250 275 VAC SLM-380-ASE 350, 365, 380, 390, 400, 415 457 VAC SLM-440-ASE 440, 450, 460, 470, 480, 490 540 VAC SLM-575-ASE 525, 550, 575, 600 690 VAC *Automatic with Memory MODE: The last fault is indicated and remains on when conditions return to normal. The indicator extinguishes only with reset or when new fault condition occurs. The SLM Series is UL Listed under UL File Number E55826. 800.727.5646 atcdiversified.com 165
SLM-575-ASE 价格&库存
很抱歉,暂时无法提供与“SLM-575-ASE”相匹配的价格&库存,您可以联系我们找货
