SPM-120-ABA-100K
SPM-120-ABA-100K
    MUELLERELECTRIC
    控制器 - 液体,液面 泄漏检测器 120VAC DIN 轨道
SPM-120-ABA-100K 数据手册
SPM Series OPERATION The ATC Diversified SPM Series Single Channel Seal Failure module is a specialized control for monitoring the shaft seal of a submersible pump motor. A leak is detected by sensing the position of a resistive float switch installed in the seal cavity. When the resistance drops below the sensitivity rating, the output relay energizes and the LED illuminates. E55826 DIMENSIONS (INCHES) Single Channel Seal Failure Alarm SPECIFICATIONS CONTROL VOLTAGE 120 VAC, 50/60 Hz SWITCH VOLTAGE 9 VDC ISOLATION 2500 Volts POWER REQUIRED 2 VA WIRING RB-11/PF013A SENSITIVITY 470 Ω ±10% Fixed 300 Ω to 10K Ω ±10% Adjustable 4.7K Ω to 100K Ω ±10% Adjustable CONTACT RATING DPDT, 10 A @ 250 VAC Resistive RESPONSE TIMES Operate Release LIFE EXPECTANCY Mechanical 10,000,000 Operations (Minimum) Electrical 50,000 Operations @ Rated Load INDICATORS Red LED illuminates when leak is detected TEMPERATURE RATING Operate Storage ENCLOSURE 11-Pin plug-in “A” style enclosure WEIGHT 8 oz. MODEL NUMBER MODEL NUMBER SPM 120 AAA SENSITIVITY 470 Ω ±10% Fixed 300 Ω to 10K Ω ±10% Adjustable 4.7K Ω to 100K Ω ±10% Adjustable Diversified Electronics 470 10K 100K 800.727.5646 atcdiversified.com 15 ms (approximately) 8 ms (approximately) -4° to 131°F (-20° to +55°C) -40° to 185°F (-40° to +85°C) SEAL FAILURE AND OVER-TEMPERATURE MONITORS DUTY CYCLE Continuous 213 SPM Series OPERATION The ATC Diversified Electronics SPM Series Seal Failure module is a specialized control for monitoring the shaft seals of submersible pump motors. Leaks are detected by sensing the conductivity of the contaminating fluid through probes installed in the seal cavity. When a seal begins to leak, the seal failure module energizes one of its SPST output relays indicating that the seal needs to be replaced before the motor is damaged. The sensitivity of the probe inputs is field adjustable. When the resistance between one of the probe inputs and the common connection drops below the sensitivity setting, the corresponding output relay and LED are activated. E55826 Dual Channel Seal Failure Alarm DIMENSIONS (INCHES) SPECIFICATIONS CONTROL VOLTAGE 120 VAC, 50/60 Hz SWITCH VOLTAGE 9 VDC ISOLATION 2500 Volts POWER REQUIRED 2 VA SEAL FAILURE AND OVER-TEMPERATURE MONITORS DUTY CYCLE Continuous 214 SENSITIVITY 10K Ω to 25K Ω ±10% Adjustable 4.7K Ω to 100K Ω ±10% Adjustable CONTACT RATING (2) SPST-N.O., 5 A @ 120 VAC Resistive LIFE EXPECTANCY Mechanical 20 Million Operations Electrical 50,000 Operations @ Rated Load INDICATORS Red LED illuminates when leak is detected TEMPERATURE RATING Operate Storage ENCLOSURE 8-Pin plug-in “A” style enclosure WEIGHT 8 oz. -4° to 131°F (-20° to +55°C) -40° to 185°F (-40° to +85°C) WIRING MODEL NUMBER RB-08/PF083A MODEL NUMBER SPM 120 ABA SENSITIVITY 10K Ω to 25K Ω ±10% Adjustable 4.7K Ω to 100K Ω ±10% Adjustable Diversified Electronics 25K 100K 800.727.5646 atcdiversified.com SPM Series OPERATION The non-volatile Latching Temperature Switch relay monitors a normally-closed-low temperature switch. It incorporates a bistable relay that retains its state during power failures. LEDs indicate the status of the relay, and connections for an external reset button are provided for manual control. The reset inputs of multiple units may be connected to a single push button as long as proper polarity is observed when making the connections. Under normal conditions the temperature switch is closed and the relay is de-energized. When the temperature switch opens, the relay energizes and latches on until the temperature switch re-closes and the reset button is pressed. The unit will function properly with zero to 2k Ω of resistance in series with the temperature switch. E55826 Temperature Switch Relay DIMENSIONS (INCHES) SPECIFICATIONS CONTROL VOLTAGE 120 VAC, 50/60 Hz POWER REQUIRED 2 VA DUTY CYCLE Continuous WIRING ACA ADA RB-11/PF113A RESPONSE TIMES Operate 10 ms (approximately) Release 1 SEC (approximately) LIFE EXPECTANCY Mechanical 30 Million Operations Electrical 50,000 Operations @ Rated Load INDICATORS SPM-120-ACA Green LED illuminates under normal conditions Red LED illuminates under fault conditions SPM-120-ADA None TEMPERATURE SWITCH Voltage 12 VDC Current 2 mA max. TEMPERATURE RATING Operate -4° to 131°F (-20° to +55°C) Storage -40° to 185°F (-40° to +85°C) ENCLOSURE 11-Pin plug-in “A” style enclosure WEIGHT 8 oz. RB-11/PF113A ORDERING INFORMATION MODEL NUMBER SPM-120-ACA SPM-120-ADA Diversified Electronics 800.727.5646 DESCRIPTION SPDT, 10A @ 250V AC Latching Temp Switch DPDT, 10A @ 250V AC Latching Temp Switch atcdiversified.com SEAL FAILURE AND OVER-TEMPERATURE MONITORS CONTACT SPM-120-ACA SPDT, 10 A @ 250 VAC, RATING Resistive, 360 VA Ind. SPM-120-ADA DPDT, 10 A @ 250 VAC, Resistive 215 SPM Series The ATC Diversified Submersible Pump Monitor is a specialized control for monitoring the shaft seal and stator temperature of a submersible pump motor. Seal leakage is detected by either a resistive float switch or a pair of conductive probes installed in the seal cavity. Over-temperature is detected by a normally-closed-low temperature switch mounted on the stator. The over-temperature function incorporates a bistable relay that retains its position during power failures. For (S) models over-temperature reset can be configured by changing the reset switch. IND. CONT. EQ. 496Y (Model AEE) ORDERING INFORMATION MODEL NUMBER Submersible Pump Monitor Dual Function Alarm Relay Dual Function Alarm Relay 120 vac Base Mount. SPM120AEA25K Dual Function Alarm Relay 120 vac, 1k to 25 k sensitivity, Plug-in. SPM24AEA25K Dual Function Alarm Relay 24v ac/dc, 1k to 25 k sensitivity, Plug-in. SPM24AEA100K CONTROL VOLTAGE 120 VAC, 50/60 Hz (Model AEE) 120-240V AC 50/60 Hz (Model AEA) 24V AC/DC (Model AEA) Dual Function Alarm Relay 24v ac/dc 4.7k to 100 k sensitivity, Plug-in. SPM120AEA(S)25K Dual Function Alarm Relay 120 vac, 1k to 25 k sensitivity, Plug-in, reset mode selector switch. SENSOR VOLTAGE 12 VDC (Model AEE) 9V DC (Model AEA) SPM24AEA(S)25K Dual Function Alarm Relay 24v ac/dc, 1k to 25 k sensitivity, Plug-in, reset mode selector switch. POWER REQUIRED 4 VA DUTY CYCLE Continuous SEAL FAILURE AND OVER-TEMPERATURE MONITORS SPM120AEE SPM120AEA100K Dual Function Alarm Relay 120 vac, 4.7k to 100 k sensitivity, Plug-in. SPECIFICATIONS 216 DESCRIPTION SENSITIVITY Leakage 1K Ω to 35K Ω adjustable (Model AEE) 1K Ω to 25K Ω adjustable (Model AEA) 4.7K Ω to 100K Ω adjustable (Model AEA) Over Temperature Open Circuit SPM120AEA(S)100K Dual Function Alarm Relay 120 vac, 4.7k to 100k sensitivity, Plug-in, reset mode selector switch. SPM24AEA(S)100K Dual Function Alarm Relay 24v ac/dc, 4.7k to 100k sensitivity, Plug-in, reset mode selector switch. CONTACT RATING (2) SPDT, 10 A @ 120 VAC Resistive LIFE EXPECTANCY Mechanical 10 Million Operations Electrical 100,000 Operations @ Rated Load INDICATORS Green LED illuminates under normal conditions Red LED illuminates when leak is detected Red LED illuminates on over-temperature TEMPERATURE RATING Operate Storage DIMENSIONS (INCHES) MODEL (AEE)BASE MOUNT DIMENSIONS (INCHES) MODEL (AEA)11 PIN PLUG-IN -4° to 131°F (-20° to +55°C) -40° to 185°F (-40° to +85°C) RESPONSE TIMES Leakage Trip 1 SEC Leakage Reset 1 SEC Temperature Trip 0.1 SEC TERMINATIONS (12) #8-32 Screw Terminals (Model AEE) ENCLOSURE Style “E” Lexan® Surface Mounted (Model AEE) Style "A" 11 Pin Plug-In (Model AEA) WEIGHT 17 oz. (Model AEE) RESET Seal Leakage: When the leakage condition clears the relay resets automatically Over Temperature: 1. Remote Manual Reset 2. For "S" type models when reset switch is set in auto position the unit will be reset by interrupting supply voltage for 1.5 sec. Diversified Electronics 800.727.5646 atcdiversified.com SPM Series OPERATION Figure 1 shows the connections for use with a Flygt model FLS float switch. The leakage sensitivity must be adjusted to 1 k for float switch applications. If a pair of conductive probes is used to sense seal leakage, a 100 k resistor is required as shown in Figure 2, and the sensitivity should be set to the desired value. The states of the unit’s relay outputs are determined by the series combination resistance of the leakage and temperature sensors. Under normal conditions the resistance remains between the leakage and over-temperature sensitivities, and both output relays are de-energized. If the temperature switch opens, the over-temperature relay latches on until the remote reset button is pressed. Two conditions must be met for reset to occur: power must be applied and the temperature switch must be closed. If the leakage sensor resistance drops below the leakage sensitivity setting, the leakage relay energizes. When the leakage condition clears, the relay resets automatically. WIRING E55826 (Model AEA) MODEL (AEE)(BASE MOUNT) Figure 1 Figure 2 . N WIRING MODEL (AEA)(PLUG-IN) PROBES Figure 1 Figure 2 THERMAL SWITCH THERMAL SWITCH 100k 1/2W FLS 6 5 RESET OVER TEMP 7 3 9 2 + OVER TEMP 7 4 8 3 9 2 10 1 6 5 RESET SEAL LEAK 8 4 11 10 1 – + 11 – ACCESSORIES: SOCKETS OT11-PC 11 pin din-rail mount socket. SEAL LEAK SEAL FAILURE AND OVER-TEMPERATURE MONITORS . RB-11 11 pin surface mount socket. Diversified Electronics 800.727.5646 atcdiversified.com 217
SPM-120-ABA-100K 价格&库存
很抱歉,暂时无法提供与“SPM-120-ABA-100K”相匹配的价格&库存,您可以联系我们找货
