TBC-120-AAA
TBC-120-AAA
    MUELLERELECTRIC
    开 - 延迟 延时继电器 0.1 秒 ~ 102.3 秒 延时 10A @ 250VAC/24VDC 可插
TBC-120-AAA 数据手册
E55826 DIP SWITCH OPERATION SUPPLY VOLTAGE OUTPUT TIME DELAY On-Delay DIP Switch TDR SPECIFICATIONS TIME DELAY RANGE A B C D E 0.1 to 102.3 SEC in 0.1 SEC Increments 1.0 to 1,023 SEC in 1.0 SEC Increments 10 to 10,230 SEC in 10 SEC Increments 0.1 to 102.3 MIN in 0.1 MIN Increments 1.0 top 1,023 MIN in 1.0 MIN Increments OUTPUT RATING 10 A @ 250 VAC or 24 VDC, resistive ACCURACY WIRING 4 5 3 7 1 SUPPLY VOLTAGE 8 SUPPLY VOLTAGE + RESET TIMES Before Time Out 100 mSEC After Time Out 50 mSEC 6 2 Setting ±2% or ±50 mSEC; whichever is greater Repeat ±0.1% or ±8.3 mSEC; whichever is greater 12, 24, 48, 120 or 240 VAC, 50/60 Hz; or DC; ±10% TIME DELAY RELAYS Digital selection of the time delay is accomplished by the use of ten (10) binary switches, each marked with a time increment. The time periods, of which there are five (5) ranges, represented by each switch in the ON position is added together to obtain the desired time delay. No more trial-by-error adjustments. TBC Series The time delay begins when supply voltage is applied to the input. Upon completion of the delay period, the relay energizes. Reset during or after the delay period is accomplished by removal of the supply voltage. The TBC Series will not false transfer if supply voltage is removed prior to completion of the delay period. A fast recycle time permits accurate, high speed, continuous operation. FALSE TRANSFER No – REVERSE POLARITY Yes PROTECTED DPDT Octal Plug-in RB-08/PF083A POWER REQUIRED 3 VA, approximately DUTY CYCLE Continuous MODEL NUMBER MODEL NUMBER TBC A CONTROL VOLTAGE 12 VDC 24 VAC/DC 48 VDC 120 VAC/DC 240 VAC 12 24 48 120 240 Operate Storage 32° to 131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) LIFE EXPECTANCY Mechanical 10 million operations, minimum Electrical 100,000 operations @ rated load D A D A A TIME DELAY RANGE 0.1 to 102.3 SEC in 0.1 SEC Increments 1.0 to 1,023 SEC in 1.0 SEC Increments 10 to 10,230 SEC in 10 SEC Increments 0.1 to 102.3 MIN in 0.1 MIN Increments 1.0 to 1,023 MIN in 1.0 MIN Increments TEMPERATURE RATING A INDICATORS LED glows when relay is energized ISOLATION 1,500 volts, input/output WEIGHT 0.35 lbs. DIMENSIONS (INCHES) B C D E HOUSING A Automatic Timing & Controls 800.727.5646 automatictiming.com 55
TBC-120-AAA
PDF文档中包含以下信息:
1. 物料型号:型号为LM324,是一款四运算放大器集成电路。
2. 器件简介:LM324是一种通用的四运算放大器,广泛应用于模拟信号处理。
3. 引脚分配:引脚1为非反相输入,引脚2为反相输入,引脚3为输出,其他引脚为供电和接地。
4. 参数特性:包括供电电压范围、输入偏置电流、增益带宽积等。
5. 功能详解:详细描述了LM324的工作原理和应用场景。
6. 应用信息:介绍了LM324在信号放大、滤波器设计等方面的应用。
7. 封装信息:提供了LM324的封装类型和尺寸信息。
TBC-120-AAA 价格&库存
很抱歉,暂时无法提供与“TBC-120-AAA”相匹配的价格&库存,您可以联系我们找货
