E55826
DIP SWITCH OPERATION
SUPPLY
VOLTAGE
OUTPUT
TIME DELAY
On-Delay DIP Switch TDR
SPECIFICATIONS
TIME DELAY
RANGE
A
B
C
D
E
0.1 to 102.3 SEC in 0.1 SEC Increments
1.0 to 1,023 SEC in 1.0 SEC Increments
10 to 10,230 SEC in 10 SEC Increments
0.1 to 102.3 MIN in 0.1 MIN Increments
1.0 top 1,023 MIN in 1.0 MIN Increments
OUTPUT RATING 10 A @ 250 VAC or 24 VDC, resistive
ACCURACY
WIRING
4
5
3
7
1
SUPPLY VOLTAGE
8
SUPPLY
VOLTAGE
RESET TIMES Before Time Out 100 mSEC
After Time Out 50 mSEC
6
2
Setting ±2% or ±50 mSEC; whichever is greater
Repeat ±0.1% or ±8.3 mSEC; whichever is greater
12, 24, 48, 120 or 240 VAC, 50/60 Hz;
or DC; ±10%
TIME DELAY RELAYS
Digital selection of the time delay is accomplished by the use of
ten (10) binary switches, each marked with a time increment. The
time periods, of which there are five (5) ranges, represented by
each switch in the ON position is added together to obtain the
desired time delay. No more trial-by-error adjustments.
TBC Series
The time delay begins when supply voltage is applied to the input. Upon completion of
the delay period, the relay energizes. Reset during or after the delay period is accomplished by removal of the supply voltage. The TBC Series will not false transfer if supply
voltage is removed prior to completion of the delay period. A fast recycle time permits
accurate, high speed, continuous operation.
FALSE TRANSFER No
REVERSE POLARITY Yes
PROTECTED
DPDT Octal Plug-in
RB-08/PF083A
POWER REQUIRED 3 VA, approximately
DUTY CYCLE Continuous
MODEL NUMBER
MODEL NUMBER
TBC A
CONTROL VOLTAGE
12 VDC
24 VAC/DC
48 VDC
120 VAC/DC
240 VAC
12
24
48
120
240
Operate
Storage
32° to 131°F (0° to +55°C)
-49° to 185°F (-45° to +85°C)
LIFE EXPECTANCY Mechanical 10 million operations, minimum
Electrical 100,000 operations @ rated load
D
A
D
A
A
TIME DELAY RANGE
0.1 to 102.3 SEC in
0.1 SEC Increments
1.0 to 1,023 SEC in
1.0 SEC Increments
10 to 10,230 SEC in
10 SEC Increments
0.1 to 102.3 MIN in
0.1 MIN Increments
1.0 to 1,023 MIN in
1.0 MIN Increments
TEMPERATURE
RATING
A
INDICATORS
LED glows when relay is energized
ISOLATION
1,500 volts, input/output
WEIGHT
0.35 lbs.
DIMENSIONS
(INCHES)
B
C
D
E
HOUSING A
Automatic Timing & Controls
800.727.5646
automatictiming.com
55
很抱歉,暂时无法提供与“TBC-120-ABA”相匹配的价格&库存,您可以联系我们找货
