TDC/TUC Series
OPERATION
The time delay begins when power is applied to the input. Upon completion of the delay period, the relay energizes. Reset during or after the
delay period is accomplished by removal of the input voltage. The TDC/
TUC will not false transfer if voltage is removed prior to completion of
the delay period. A fast recycle time permits accurate,high speed,
continuous operation.
SUPPLY
VOLTAGE
E55826
OUTPUT
TIME DELAY
WIRING
1
4
3
On-Delay Relay Output
6
5
5
8
4
6
3
7
2
1
2
DPDT Octal Plug-in
6
7
8
9
11
SUPPLY
3
5
10
1
4
9
8
SUPPLY
2
7
DPDT 11 Pin Plug-in
A
B
DPDT Blade Plug-in
External Resistor Adjustable
TIME DELAY RELAYS
RB-08/PF083A
RB-11/PF113A
DIMENSIONS
SPECIFICATIONS
70-463-1
(INCHES)
TIMING RANGES
Virtually unlimited. See page 77 for standard
ranges available.
OUTPUT
RATING
DPDT, 10 A @ 250 VAC or 24 VDC, resistive;
211 VA @ 120 VAC, inductive,
25VA @ 24VAC inductive
TIMING
Minimum Setting +0 – 20%
TOLERANCES Maximum Setting ±10%;
REPEATABILITY 1% maximum; no first cycle effect
RESET TIMES Before Time Out
After Time Out
100 mSEC
50 mSEC
RECYCLE TIME 40 mSEC
SUPPLY
VOLTAGE
24 or 120 VAC or VDC, 50/60 Hz; ±10%
(TUC Series available in 120 Volts only)
FALSE TRANSFER No
REVERSE
POLARITY
PROTECTED
Yes
POWER
CONSUMPTION
3 watts (approximately)
DUTY CYCLE
Continuous
TEMPERATURE
RATING
Operate
Storage
32° to 131°F (0° to +55°C)
-49° to 185°F (-45° to +85°C)
MODEL NUMBER
MODEL NUMBER
T
SERIES
Relay Output
Relay Output with CSA
C
A
D
U*
SUPPLY VOLTAGE
24 VAC or DC
110/120 VAC or DC
24
120
TYPE OF OPERATION
Knob Adjustable K
Lock Nut Adjustable L
Fixed F
R**
ENCLOSURE STYLE
8 or 11-pin Round Plug-in
A
Blade Plug-in B
Non-UL 12-pin DIP Plug-in
C
DELAY PERIOD
See page 77 for standard ranges available
LIFE EXPECTANCY Mechanical 10 million operations
(minimum)
Electrical
100,000 operations
@ rated load
Example: TUC-120-AKA-900—Interval on operate, 120 Volts AC or DC, knob
adjustable from 9 to 900 seconds, 8-pin octal plug-in, UL recognized and
CSA approved.
WEIGHT
Notes:* The TUC series is offered in 120 Volts, style A enclosure only with
optional types of operation “K”, “L”, or “F” CSA certified, File #LR40123**
5 oz.
TDC models using the “R” option are not UL Recognized. The “R” option is
not offered in the TUC series or the style B enclosure. TDC models using
“F”, “K”, or “L” options and in the 8-pin octal plug are only available in 24-volts.
64
Automatic Timing & Controls
800.727.5646
automatictiming.com
很抱歉,暂时无法提供与“TUC-120-AKA-010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1388.637671+180.37699
