TDE-120-AKA-48H
TDE-120-AKA-48H
    MUELLERELECTRIC
    单次 延时继电器 DPDT(2 Form C) 28.8 分 ~ 48 小时 延时 10A @ 250VAC/24VDC 可插
TDE-120-AKA-48H 数据手册
TDE/TUE Series OPERATION Voltage is continuously applied to the input. An external isolated switch controls the timer. When closed (momentary or maintained), the relay energizes and the delay period begins. Upon completion of the delay period, the relay de-energizes. * E55826 WIRING Single-Shot Relay Output 6 5 7 8 4 3 1 11 8 4 10 4 9 2 1 2 7 TIME DELAY RELAYS SPECIFICATIONS SUPPLY – SUPPLY + – 8 + SUPPLY DPDT 11 Pin Plug-in SPDT Octal Plug-in RB-11/PF113A External Resistor Adjustable RB-08/PF083A DIMENSIONS 6 5 DPDT 11 Pin Plug-in TIMING RANGES Virtually unlimited. See page 77 for standard ranges available. OUTPUT RATING + 3 SW 4 6 7 10 11 5 3 1 – 2 7 3 9 2 1 6 5 8 9 A B – + DPDT Blade Plug-in 70-463-1 (INCHES) DPDT, 10 A @ 250 VAC or 24 VDC, resistive; 211 VA @ 120 VAC, inductive TIMING Minimum Setting +0 – 20% TOLERANCES Maximum Setting ±10%; REPEATABILITY 1% maximum; no first cycle effect RESET TIMES Before Time Out After Time Out 100 mSEC 50 mSEC RECYCLE TIME 40 mSEC SUPPLY VOLTAGE 24 or 120 VAC or VDC, 50/60 Hz; ±10% (TUE Series available in 120 Volts only) FALSE TRANSFER No REVERSE POLARITY PROTECTED Yes POWER CONSUMPTION 3 watts (approximately) DUTY CYCLE Continuous TEMPERATURE RATING Operate Storage 32° to 131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) LIFE EXPECTANCY Mechanical 10 million operations (minimum) Electrical 100,000 operations @ rated load WEIGHT 4.5 oz. For UL/CSA Approved version specify TUE Series of On-Delay Relay Output Timers. MODEL NUMBER MODEL NUMBER T SERIES Relay Output Relay Output with CSA E A D U* SUPPLY VOLTAGE 24 VAC or DC 110/120 VAC or DC 24 120 TYPE OF OPERATION Knob Adjustable K Lock Nut Adjustable L Fixed F External Resistor Adjustable R** ENCLOSURE STYLE 8-pin or 11-pin Round Plug-in Blade Plug-in B A DELAY PERIOD See page 77 for standard ranges available Example: TUE-120-AKA-900—Single Shot, 120 Volts AC or DC, knob adjustable from 9 to 900 seconds, 8-pin octal plug-in. UL recognized and CSA approved. Notes:* The TUE series is offered in 120 Volts, octal plug-in (figure 23) style A enclosure only with optional types of operation “K”, “L”,or “F” CSA certified: File #LR40123 **TDE’s using the “R” option are not UL Recognized. The “R” option is NOT offered in the TUE series or the style B enclosure. 66 Automatic Timing & Controls 800.727.5646 automatictiming.com
TDE-120-AKA-48H 价格&库存
很抱歉,暂时无法提供与“TDE-120-AKA-48H”相匹配的价格&库存,您可以联系我们找货
