TDF-120-AKA-24-H060
TDF-120-AKA-24-H060
    MUELLERELECTRIC
    重复周期 延时继电器 DPDT(2 Form C) 0.6 秒 ~ 24 小时 延时 10A @ 250VAC/24VDC 可插
TDF-120-AKA-24-H060 数据手册
TDF Series OPERATION Application of voltage to the input of the timer initiates the OFF time. Upon completion of the OFF time, the relay energizes and the ON time begins. Upon completion of the ON time, the relay de-energizes and one cycle is completed. This OFF/ON cycling continues until voltage is removed from the input. The OFF/ON time periods are independently adjustable. SUPPLY VOLTAGE E55826 OUTPUT T1 T2 T1 T2 T1 WIRING 1 2 Repeat Cycle-OFF Time First Relay Output 3 5 3 6 2 7 4 6 5 1 + 7 8 SUPPLY – DPDT Octal Plug-in 8 9 A B + – DPDT Blade Plug-in RB-08/PF083A 70-463-1 DIMENSIONS (INCHES) SPECIFICATIONS TIMING RANGES Virtually unlimited. See page 77 for standard ranges available. OUTPUT RATING DPDT, 10 A @ 250 VAC or 24 VDC, resistive; 211 VA @ 120 VAC, inductive TIMING Minimum Setting +0 – 20% TOLERANCES Maximum Setting ±10%; TIME DELAY RELAYS 4 REPEATABILITY 1% maximum; no first cycle effect RESET TIMES Before Time Out After Time Out MODEL NUMBER MODEL NUMBER TDF SUPPLY VOLTAGE 24 VAC or DC 110/120 VAC or DC A RECYCLE TIME 40 mSEC SUPPLY VOLTAGE 24 120 24 or 120 VAC or VDC, 50/60 Hz; ±10% FALSE TRANSFER No TYPE OF OPERATION Knob Adjustable K Lock Nut Adjustable L Fixed F ENCLOSURE STYLE 8-pin octal plug-in A Blade plug-in B DELAY PERIOD See page 77 for standard ranges available Example: TDF-120-ALA-300—Repeat cycle, 120 Volts AC or DC, lock nut adjustable from 3 to 300 seconds, 8-pin octal plug-in, UL recognized. REVERSE POLARITY PROTECTED Yes POWER CONSUMPTION 3 watts (approximately) TEMPERATURE RATING Operate Storage 32° to 131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) LIFE EXPECTANCY Mechanical 10 million operations (minimum) Electrical 100,000 operations @ rated load WEIGHT Automatic Timing & Controls 100 mSEC 50 mSEC 800.727.5646 6.4 oz. automatictiming.com 67
TDF-120-AKA-24-H060 价格&库存
很抱歉,暂时无法提供与“TDF-120-AKA-24-H060”相匹配的价格&库存,您可以联系我们找货
