TDT-240-AKA-060
TDT-240-AKA-060
    MUELLERELECTRIC
    关 - 延迟 延时继电器 DPDT(2 Form C) 0.6 秒 ~ 60 秒 延时 10A @ 250VAC 可插
TDT-240-AKA-060 数据手册
TDT Series OPERATION When voltage is applied to the input, the relay energizes. When voltage is removed, the OFF delay begins. Upon completion of the delay period, the relay de-energizes. Reset is accomplished by reapplying voltage to the input terminals. NOTE: If voltage is reapplied during the delay period, the relay remains picked up and the timer resets to zero. VOLTAGE MUST BE APPLIED FOR A MINIMUM OF 0.5 SECONDS TO ASSURE PROPER OPERATION. SUPPLY VOLTAGE E55826 OUTPUT TIME DELAY True OFF-Delay Relay Output WIRING SPECIFICATIONS TIME DELAY RELAYS OUTPUT RATING 1 DPDT, 10 A @ 250 VAC or 24 VDC, resistive; 211 VA @ 120 VAC, inductive TIME Minimum Setting TOLERANCES Maximum Setting 4 3 RESET TIMES 0.5 seconds SUPPLY VOLTAGE 24 or 110/120 or 208/240 VAC, 50/60 Hz, or VDC; and 48 VDC; ±10% 4 6 1 8 SUPPLY – DPDT Octal Plug-in 9 A B + – 70-463-1 MODEL NUMBER REVERSE POLARITY PROTECTED Yes MODEL NUMBER POWER CONSUMPTION 3 watts (approximately) TEMPERATURE RATING Operate Storage SUPPLY VOLTAGE 24 VAC or DC 48 Volts DC 110/120 VAC or DC 208/240 VAC or DC 32° to 131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) LIFE EXPECTANCY Mechanical 10 million operations (minimum) Electrical 100,000 operations @ rated load 4.5 oz. DIMENSIONS 8 DPDT Blade Plug-in RB-08/PF083A FALSE TRANSFER No WEIGHT 6 7 7 2 + 1% 3 5 +0 – 20% ±10% REPEATABILITY 2 5 TDT 24 48 120 240 TYPE OF VOLTAGE AC and DC operation DC operation only (D Designation used for 48V model only) A D TYPE OF OPERATION Knob Adjustable K Lock Nut Adjustable L Fixed F ENCLOSURE STYLE 8-pin octal plug-in A Blade plug-in B (INCHES) 1.75” 2.375” Octal Pin Plug-in DELAY PERIOD 010 = .1 to 10 SEC 010 030 = .3 to 30 SEC 030 060 = .6 to 60 SEC 060 100 = 1 to 100 SEC 100 200 = 2 to 200 SEC 200 300 = 3 to 300 SEC 300 Example: TDT-120-ALA-300—True off delay, 120 Volts AC or DC, Lock-nut adjustable, time range from 3 to 300 seconds, 8-pin octal plug-in. 74 Automatic Timing & Controls 800.727.5646 automatictiming.com
TDT-240-AKA-060 价格&库存
很抱歉,暂时无法提供与“TDT-240-AKA-060”相匹配的价格&库存,您可以联系我们找货
