UOA-110-DKA
UOA-110-DKA
    MUELLERELECTRIC
    电压检测 AC 110VDC
UOA-110-DKA 数据手册
UOA Series The UOA Series offers protection to SINGLE PHASE equipment that is required to operate above a certain voltage minimum. OPERATION STYLE "A" Style A only STYLE "N" With operating voltage applied above the preset PICK-UP voltage, the internal relay will energize. When the voltage falls below the preset DROP-OUT voltage for a period longer than the release delay, the output relay will de-energize. When line conditions return above the preset PICK-UP voltage, the UOA Series automatically resets and the internal relay energizes. The HYSTERESIS in each unit provides a differential between the PICK-UP and DROP-OUT trip points. E55826 Single Phase Under Voltage Monitor MODEL NUMBER PHASE VOLTAGE MONITORS SPECIFICATIONS OPERATING Style A RATING Style N DPDT, 5A @ 240 VAC, Resistive; 211 VA @ 240 VAC SPDT, 10A @ 240 VAC, Resistive; 180 VA, Inductive, @ 120 VAC RESPONSE TIMES Operate Release 50 mSEC. (approx.) (500 mSEC. on 12 VDC units) 0.5 SEC (approx.) TEMPERATURE RATING 32° to +131°F (0° to +55°C) -49° to 185°F (-45° to +85°C) Operate Storage POWER REQUIRED Models Up To 110 VDC: 3 Watts, Max. Models Up To 300 VAC: 5 VA, Max. WEIGHT 5 oz. to 5.5 oz. UOA-24-A*A UOA-120-A*A UOA-208-A*A UOA-240-A*A UOA-12-D*A UOA-24-D*A UOA-48-D*A UOA-110-D*A UOA-220-D*A UOA-240-D*A UOA-120-AFN UOA-208-AFN UOA-220-AFN UOA-230-AFN UOA-240-AFN *Adjustments - DROP-OUT PICK-UP HYSTERESIS VOLTAGE VOLTAGE VOLTAGE 19-27 VAC 97-130 VAC 177-222 VAC 205-250 VAC 9-14 VDC 19-27 VDC 38-53 VDC 92-125 VDC 185-230 VDC 205-250 VDC 100 VAC 180 VAC 180 VAC 190 VAC 202 VAC F = Fixed K = Knob L = Locknut WIRING RB-08 or PF083A 166 Diversified Electronics 800.727.5646 atcdiversified.com 21-29 VAC 102-135 VAC 185-230 VAC 215-260 VAC 10-15 VDC 21-29 VDC 40-55 VDC 97-130 VDC 194-239 VDC 215-260 VDC 105 VAC 188 VAC 187 VAC 198 VAC 210 VAC 2 5 8 10 1 2 2 5 9 10 5 8 7 8 8
UOA-110-DKA 价格&库存
很抱歉,暂时无法提供与“UOA-110-DKA”相匹配的价格&库存,您可以联系我们找货
