UPA-130DIV2
UPA-130DIV2
    MUELLERELECTRIC
    UNIVERSAL POWER ALERT- CLASSI DI
UPA-130DIV2 数据手册
UPA-130 Series The UPA 130 Power Alert reduces the risk of electrical arc flash by pre-verifying the electrical isolation from outside of a control panel. Hard wired to the circuit breaker or main disconnect, the UPA flashes whenever voltage is present. Engineered with redundant circuitry, the Power Alert is powered by the same voltage that it indicates. OPERATION UL TYPE 4X, 12, 13 IND. CONT. EQ. 496Y 30mm Universal Power Alert The eight detector UPA-130 visually alerts to the presence of dangerous AC or DC (Store Energy) potentials occurring between any combination of the four monitored input lines (L1, L2, L3, GND). Two LED indicators are assigned to each input line and are designated "+" and "-". For each input line carrying an AC potential (bi-polar) , both the "+" and "-" LEDs will be active. A DC or Stored Energy potential will illuminate the "+" LED for the positive line and the "-" LED for the negative line. The UPA-130 Series is UL Listed under UL File Number E55826. • Verification of Stored Energy Inside A Panel • Redundant Circuitry • Fits 30mm Knockout • 40-750 VAC, 30-1000 VDC SPECIFICATIONS OPERATIONAL RANGE AC SINGLE OR 3-PHASE DC OR STORED ENERGY MAXIMUM RATED VOLTAGE 750 VAC/1000 VDC (LINE-TO-LINE or LINE-TO-GND) 40 to 600 VAC, 50/60/400 Hz, (LINE-TO-LINE or LINE-TO-GND 30 to 1000 VDC, (LINE-TO-LINE or LINE-TO-GND) POWER ALERTS DETECTION THRESHOLDS 29 VAC 3-Phase, 40 VAC SINGLE-Phase, 27 VDC (TYP CUTOFF) POWER CONSUMPTION 1.2 Watts @ 750 VAC (Approximately) TEMPERATURE RATING Operate Storage ENCLOSURE Totally Encapsulated for Environment Protection TERMINATIONS (4) 8 ft, 18 AWG 1000V, RED YEL BLU GRN/YEL UL-1452 L1 L2 L3 GRD WEIGHT 7 oz. -4° to 131°F (-20° to +55°C) -40° to 185°F (-40° to +85°C) INDICATOR FLASH RATES (L1, L2, L3, GND) 3- Phase Line-To-Line (VAC)
UPA-130DIV2 价格&库存
很抱歉,暂时无法提供与“UPA-130DIV2”相匹配的价格&库存,您可以联系我们找货
