MT800SWM
MT800SWM
    MULTI-TECHSYSTEMS
    Module
    RF TXRX MODULE WIFI U.FL ANT
MT800SWM 数据手册
SocketWireless Wi-Fi ® ® Embedded Serial-to-Wi-Fi Device Server Universal Socket Benefits • Interchangeable communications devices • Quick-to-market • Global approvals • Easy migration to future networks The SocketWireless® Wi-Fi® device server connects serial devices to an IP network via 802.11b wireless networking. It enables you to build wireless networking into virtually any device allowing for remote monitoring, control and configuration. The space efficient communications device (1" x 2.5") integrates a complete TCP/IP protocol stack, and can make your existing and next generation device, machine or system, IP-ready while you focus on developing its core features. Features • Complete serial-to-Wi-Fi wireless connectivity solution including network processor, media access controller and air interface • Supports ad-hoc and infrastructure mode • Wi-Fi security using WEP • Serial interface supports DTE speeds to 230K bps • Space efficient universal socket connectivity • High performance processor runs ARP, DHCP client, DNS, FTP client, ICMP (ping), IP, POP3, SMTP, TCP and UDP protocols • Two LED driver outputs for visual monitoring of link and activity • Configuration and management via AT commands • Flash memory to update firmware with the latest enhancements • Developer’s kit available for testing, programming and evaluation • Two-year warranty Highlights Applications. The SocketWireless Wi-Fi device server will wirelessly IP-enable any device to provide remote monitoring, control and configuration of any system. It is ideal for: Developer's Kit. The Developer’s Kit allows you to plug in the communications device and use it for testing, programming and evaluation. The kit includes one development board with RS-232 DB-25 connector, universal power supply, antenna and RS-232 cable. • Appliances • Point-of-sale terminals • ATM terminals • Remote diagnostics • Credit card and check verification systems • Remote metering Specifications • Security systems • Data collection Wireless Specifications • Television set-top boxes • Gas pumps • Ticketing machines • Industrial and medical remote monitoring systems • Vending/gaming machines Serial-to-Wi-Fi Technology The SocketWireless Wi-Fi IP device server provides the powerful ability to IP-enable serial devices allowing more options for data acquisition, device management, and industrial control than would otherwise be available. The communications device integrates a processor, proprietary operating system, TCP/IP stack, and an 802.11b wireless network connection to provide a complete serial-to-Wi-Fi connectivity solution. Quick-to-Market Solution. The complete, ready-to-integrate SocketWireless Wi-Fi device server is certified by the U.S. Federal Communications Commission (FCC). The FCC approval is portable across any solution for which the communications device is integrated, which means you can use the Multi-Tech license and bypass your own 802.11 regulatory product testing. This alone will save you valuable resources and dollars to allow you to focus on your product’s core features, and accelerate your time-to-market. Universal Socket Connectivity. Multi-Tech’s universal socket is a flexible, comm-port architecture that provides cellular, Ethernet, PSTN or Wi-Fi network access with interchangeable communications devices. This means you can utilize one system design and populate it with your connectivity device of choice accommodating multiple connectivity requirements. In addition, you are assured a seamless migration to future technologies. SocketWireless Wi-Fi Pin-Out. The SocketWireless Wi-Fi device server interfaces easily with existing products through a standard serial communication channel. The serial DTE channel is capable of transfer speeds to 230.4K bps and can be interfaced directly to a UART or microcontroller. The SocketWireless Wi-Fi device server also provides two LED driver outputs for visual monitoring of link and activity. World Headquarters Tel: (763) 785-3500 (800) 328-9717 www.multitech.com 9/07 86002080 Network Interface: IEEE 802.11b Frequency Range: 2.400 to 2.484 GHz Data Rate: 1, 2, 5.5, 11Mbps Maximum Transmit Power: 16 dBm Receiver Sensitivity: -82 dBm Security: 64/128 bit WEP Mode: Ad Hoc, Infrastructure Antenna Connector: MMCX Serial Interface Data Format: Serial, asynchronous, 3.3V-level signals Data Rate: Software selectable (1200 bps – 230K bps) Power Requirements 3.3VDC or 5VDC Power Usage Typical – 400mA @ 3.3VDC, 240mA @ 5VDC Network Protocol Support ARP, DHCP client, DNS, FTP client, ICMP (ping), IP, POP3 client, SMTP client, TCP, & UDP protocols Physical Description 2.541" L × 1.045" W × 0.680" H; 0.6 oz. (6.45 cm × 2.65 cm × 1.7 cm; 0.017 kg.) Operating Environment Temperature Range: -30° to +70° C Approvals Safety: UL 60950, cUL 60950, EN 60950, AS/NZS 6950:2000 EMC: FCC Part 15 Subpart C, Canada, RSS-210, EN 300 328, EN 301 489-17 Ordering Information Product MT800SWM MT800SWM-L Copyright © 2007 by Multi-Tech Systems, Inc. All rights reserved. Region Regional Regional Made in Mounds View, MN, U.S.A. Features and specifications are subject to change without notice. Trademarks / Registered Trademarks: SocketWireless, Multi-Tech, and the Multi-Tech logo: Multi-Tech Systems, Inc. / Wi-Fi is a registered trademark of the Wi-Fi Alliance. / All other products and technologies are the trademarks or registered trademarks of their respective holders. EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118-959 7774 Description 802.11b Device Server, 5V 802.11b Device Server, 3.3V Multi-Tech Systems (EMEA) France Tel: +(33) 1 49 19 22 06
MT800SWM 价格&库存
很抱歉,暂时无法提供与“MT800SWM”相匹配的价格&库存,您可以联系我们找货
