MTCDTIP-LEU1-275L-868
    MULTI-TECHSYSTEMS
    LTE CAT3 IP67 BASE W/ACCY KIT
MTCDTIP-LEU1-275L-868 数据手册
MultiConnect®Conduit® IP67 Base Station 16-channel v2.1 Geolocation Reference Design BENEFITS MultiConnect® Conduit® IP67 Base Station is a ruggedized IoT gateway solution, specifically designed for outdoor LoRa® public or private network deployments. The product can operate in two modes: standard and geolocation. The standard product operates as a 16-channel, full duplex gateway, supporting both packet-forwarder and built-in network server modes. The geolocation product is based on the Semtech v2.1 reference design, which uses the LoRaWAN™ protocol to perform Time Difference of Arrival (TDoA) calculations to deliver end-node location information in conjunction with a v2.1 LoRa Network Server. This technology provides asset location information that enables a variety of use cases, services and business models that GPS limitations cannot support. The upgradeable FPGA on the LoRa processor allows customers to deploy in standard operation today for existing LoRaWAN network needs and remotely upgrade to geolocation operation as business needs change. There is no need to send a technician to site to change mode of operation. It can support thousands of LoRaWAN certified end nodes natively, including the MultiConnect® mDot™* and xDot®*, without the need for additional hardware or software upgrades to the end nodes. *Represents ideal network configuration and equipment set up. Results vary depending on payload amount, transmission frequency, spreading factor used, as well as terrain, RF interference and obstruction type (e.g., metal, cement, etc.) • Full duplex communication reduces time and costs of operational management of LoRa end devices • Increased timing accuracy and Enhanced Security – all geolocation packets are fine timestamped and AES encrypted • Existing LoRaWAN compliant end nodes can utilize geolocation without extra hardware or software costs • GPS-free geolocation reduces complexity of locating LoRaWAN end devices FEATURES • Semtech v2.1 design is Geolocation enabled by partnering with a v2.1 LoRa Network Server • Operates as a 16-channel gateway in standard or geolocation operation • Certified for Europe 868 MHz and North American 915 MHz ISM bands • Standard operation supports 1PPS packet timestamp; geolocation operation supports finer packet timestamp www.multitech.com/IP67 IP67 BASE STATION HIGHLIGHTS CONNECTING THE “THINGS” Geolocation Applications MultiConnect® mDot™ & xDot® There are many IoT use cases that require information on the MultiConnect mDot and xDot are location of a physical asset, but traditionally have been secure, regulatory-certified, hampered by technology that either requires additional Arm® Mbed™ programmable, hardware (e.g., GPS module) and/or has limited capability (e.g., low-power RF modules, cannot work indoors in wide area applications). With providing long-range, low Semtech’s v2.1 geolocation solution, new business cases and bit rate IoT data connectivity services in key verticals such to sensors and actuators. as agriculture, health care, logistics, and construction can The mDot and xDot are benefit from location services previously too expensive or LoRaWAN compliant, providing impossible to meet utilizing GPS. Whether one wants to locate bi-directional data communication up animals, assets or provide new services cost efficiently, to 10 miles line-of-sight and 2-3 miles in buildings, using the LoRaWAN geolocation is positioned to enable a myriad of use global sub-GHz ISM radio bands in North America, Europe, cases that benefit society. and the APAC regions. Geolocation with v2.1 LoRa Network Servers The mDot was the first Arm Mbed platform listed on mbed.org The MultiConnect IP67 Conduit v2.1 base station requires a that was deployment ready. The mDot supports applications LoRa Network Server that is capable of processing v2.1 packets. written and compiled in the mbed online environment using v2.1 packets are not backwards compatible with v1.5 or earlier developer friendly libraries. Decision making and control can LoRa Network Servers. Therefore, in order to use geolocation be done at the edge, reducing the need to optimize RF with this new product, a customer must have access to a v2.1 performance and implement complex IoT middleware. capable LoRa Network Server. Check with your public LoRa operator of choice to see if they have an agreement with Semtech, as MultiTech is compatible with most operators around the world. MultiConnect® xDot® MultiConnect® mDot™ mDots and xDots bring intelligence, reduced complexity and a lower overall bill of material to the edge of the network while supporting a variety of interfaces to connect just about any battery-powered “thing”. For the Advanced Developer – Open mLinux Development Environment The mLinux Distribution Includes: With a completely open Linux development environment, • Language Support: Python, C/C++ & JavaScript our mLinux distribution is based on the Open Embedded/Yocto • Package upgrade support for Java, Perl, Ruby, Mono C# project; providing hundreds of open source packages and • Packages: SQLite (Database), Ligttpd (Web Server), extensive language support. • Operating System: Linux 4, Yocto 2.2 BusyBox (Core Utilities) This development path is recommended for those wanting to port existing applications, who have strong language preferences, or who need complete firmware control. Easily Deploy and Manage Assets Via DeviceHQ® MultiTech DeviceHQ is the M2M industry’s first IoT online application store to enable customers to easily deploy and scale applications Benefits to their connected devices. Drag-and- in-field assets. The DeviceHQ application • “Low Touch” asset deployment reduces costs, complexity and time store gives your business the power to • Easily scales to your network needs innovate operations management and • Browse and download custom applications tailored to your business needs create value-added services. • Reduce truck-rolls using remote performance management and asset updates drop tools easily allow customers to create and manage applications for SPECIFICATIONS Models MTCDT-Lxxx 4G-LTE Category 3 3GPP Release 9 (100 Mbps peak downlink/50 Mbps peak uplink) Cellular Options Frequency Band (MHz) AT&T/T-Mobile Europe Verizon 4G: 700(B17)/850(B5)/ AWS1700(B4)/1900(B2) 3G: 850(B5)/1900(B2) 2G: 850/1900 4G: 800(B2)/1800(B3)/2600(B7) 3G: 850(B5)/900(B8)/2100(B1) 2G: 900/1800 4G: 700(B13)/AWS1700(B4) ARM9 processor with 32-Bit ARM & 16-Bit Thumb instruction sets • 400 MHz • 16K Data Cache • 256 MB Flash Memory • 16K Instruction Cache • 128X16M DDR RAM Processor & Memory Packet Data Up to 100 Mbps downlink, Up to 50 Mbps uplink LoRa – a Digital Spread Spectrum technique 16 Channel gateway Radio Frequency • Open source embedded Linux distro based on the Yocto Project – 2.2 • Tool chain for creating custom images • Packet forwarder • WAN connection via Ethernet or cellular mLinux Software GNSS/GPS Module (when not using geolocation) • Cellular PPP, DHCP client & server • Firewall configuration via iptables • Full root console access via SSH and serial debug port • Out of the box support for C, C#, C++, Perl, Python, Javascript, Node.js, Ruby • Five configurable LEDs • opkg package manager with limited package feed • Basic router functionality built-in with Linux • Software configurable USB device port • Lighttpd web server • GNSS 72-channel u-blox NEO/LEA-M8T module / Concurrent reception of GPS/QZSS, GLONASS, Galileo, BeiDou / Survey-in and single satellite timing / Time pulse frequency: 0.25 Hz….10 Mhz / Time pulse accuracy: Clear sky ≤ 20 ns / Indoor ≤ 500 ns LoRa Omni-directional radiation pattern for 360⁰ / 3 dBi gain / Vertical polarization / Weight: 231 grams / Nominal Impedance: 50 Ω / Dimensions: 388.5 mm x 36.9mm / Frequency Range: 806-960/1710-2170 Mhz / N-Male connector / Power withstanding: 20 W / Wind-loading: 125 Mph Cellular Wideband LTE, 4G / 3 dBi gain / HPBW: Horizontal – 360⁰ / Vert – 60⁰ / Linear and vertical polarization / Nominal Impedance: 50 Ω / Dimensions: 178 x 22mm / N Plug connector / Weight: 70 gw / Frequency Range: 690-960/1710-2170/2500-2690 MHz Antennas GNSS/GPS Operation Voltage: 3.0 – 5.0V / Polarization: RHCP / Power Consumption: 8+/-3mA@3.0+/-0.1V / Temperature: -40⁰C to +85⁰C / Gain: 90⁰: 2.4 dBic@1575 MHz; 2.85 dBic@1602 Mhz / Connector: N-Plug / Frequency Range: 1575 – 1615 Mhz / Dimensions: 55 (Dia.) mm x 64 (W) / Noise Figure: 2.0 dB typ. MTAC LoRa mCard Listen Before Talk support / SPI interface / LoRaWAN 1.0, 1.0.1 & 1.0.2 support Dimensions – 50.59 mm x 30 mm / 902-928 MHz ISM Band – AS923 MHz compliant LoRa Channel Plan Certified Channel Support: Europe 868 Mhz, North America 915 MHz Radio Frequency Support: AS923 MHz, AU 915 MHz, IN 865 MHz, KR 920 MHz LoRaWAN Protocol LoRaWAN 1.0, 1.0.1 and 1.02 supported / Listen Before Talk support 802.3at Type 2: PoE device with power rating 60W or greater Input power: Power over Ethernet 37-57 Volts DC Voltage SIM, LEDs and USB Port accessible under IP67 rated bottom cap cover Connectors Ethernet 1 RJ-45 Ethernet 10/100 port; RJ-45 for PoE USB 1 USB Ports: USB Host (Type-A) Cellular (Optional) Female SMA, 3dBi detachable cellular antennas (Qty 2) Antenna “N” type SIM Micro-SIM Holder (3FF) Physical Description Dimensions (LxWxH) 262 mm x 91 mm x 257 mm Physical Weight 2.75 kg Chassis Type IP67-rated, Aluminum Environmental Operating Temperature -30° to +75° C Storage Temperature -40° to +85° C Relative Humidity 20% to 90%, non-condensing Certifications EMC Compliance US: FCC Part 15 Class B. EU: EN 55022 Class B, EN 55024. Canada: ICES-003 Radio Compliance FCC 15.247, IC RSS-210, EU EN 300 220 Safety UL / cUL 60950-1 2nd Ed., UL / cUL 60950-22, IEC 60950-1 2nd Ed. + A2, IEC 60950-22, RoHS compliant Network Approvals AT&T/T-Mobile, Verizon MIL-STD-810G: High Temp, Low Temp, Random Vibration. SAE J1455: Transit Drop & Handling Drop, Random Vibration, Swept-Sine Vibration. IEC68-2-1: Cold Temp. IEC68-2-2: Dry Heat Quality *UL Listed @ 40° C, limited by AC power supply. UL Recognized @ 70° C when used with the fused DC power cable, part number FPC-532-DC. Installation in outdoor locations or ambient temperature above 40° C or 70° C has not been evaluated by UL. UL Certification does not apply or extend to use in outdoor applications. Optional power must be UL Listed ITE power supply marked LPS or Class 2 rated 12VDC, 5A. Certification does not apply or extend to voltages outside certified range, and has not been evaluated by UL for operating voltages beyond tested range. Field Area Networks Sensing & Controlling Things Embedded MultiConnect® mDot™& xDot® Internet Insight + Action + Control Processing | Gateway Big Data Analytics Energy Ethernet Serial Agriculture Healthcare Enterprise / Smart City Wireless or Wired MultiConnect Conduit®IP67 Base Station ® 3G 4G HTTP CoAP JSON MQTT Ethernet Key Management Servers Wireless or Wired TM Cellular Ethernet Services Internet Cloud Data Platform WHAT’S INCLUDED WITH YOUR IP67 BASE STATION Mounting Options (optional accessories shown) Services & Warranty MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs.These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. The IP67 Base Station includes the following: • 1 - MultiTech Conduit IP67 Gateway with MTAC-LORA mCard installed • 1 - LoRa IP67-rated antenna • 2 - Cellular antennas (if equipped with Cell Backhaul) • 1 - GNSS antenna • 1 - Mounting Bracket Kit with screws and hose clamp (can mount to pole, wall, tower) Installation Support MultiTech’s Installation Support Service delivers priority service with the ability to work one-on-one with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. • 1 - Installation guide for setting up IP67 chassis and inserting SIM card Technical Support Services ORDERING INFORMATION MultiConnect Conduit IP67 Geolocation Base Station Model MTCDTIP-LEU1-270L-868 Description LTE Cat 3 Conduit IP67 Geolocation Base Station, GNSS w/Accessories MTCDTIP-LAT1-270L-915 LTE Cat 3 Conduit IP67 Geolocation Base Station, GNSS w/Accessories (AT&T) Region Europe US/Canada MTCDTIP-LVW2-270L-915 LTE Cat 3 Conduit IP67 Geolocation Base Station, GNSS w/Accessories (Verizon) US With Wi-Fi/BT/BLE Support MTCDTIP-LEU1-275L-868 LTE Cat 3 Conduit IP67 Geolocation Base Station, GNSS w/Wi-FI/BT and Accessories MTCDTIP-LAT1-275L-915 LTE Cat 3 Conduit IP67 Geolocation Base Station, GNSS w/Wi-FI/BT and Accessories (AT&T) US/Canada Europe MTCDTIP-LVW2-275L-915 LTE Cat 3 Conduit IP67 Geolocation Base Station, GNSS w/Wi-FI/BT and Accessories (Verizon) US RECOMMENDED ACCESSORIES At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go MultiConnect mDot Model MTDOT-868-X1-SMA Description 868 MHz XBee LoRa SMA Region Euro MTDOT-868-X1P-SMA 868 MHz XBee LoRa SMA w/Programming Header Euro MTDOT-868-X1-UFL 868 MHz XBee LoRa UFL Euro MTDOT-868-M1-UFL 868 MHz SMT LoRa UFL Euro MTDOT-868-M1-TRC 868 MHz SMT LoRa RF Pad Euro MTDOT-915-X1-SMA 915 MHz XBee LoRa SMA NAM MTDOT-915-X1P-SMA 915 MHz XBee LoRa SMA w/Programming Header NAM MTDOT-915-X1-UFL 915 MHz XBee LoRa UFL NAM MTDOT-915-M1-UFL 915 MHz SMT LoRa UFL NAM MTDOT-915-M1-TRC 915 MHz SMT LoRa RF Pad NAM MultiConnect xDot Model MTXDOT-NA1-A00-1 Description 915 MHz LoRa Module UFL/TRC (Single Pack) MTXDOT-EU1-A00-1 868 MHz LoRa Module UFL/TRC (Single Pack) MTXDOT-AU1-A00-1 AU915 MHz LoRa Module UFL/TRC (Single Pack) Region NAM EMEA Australia Developer Kit & Accessories Model MMTKIT-IP67-MF Description Conduit IP67 Accessory Kit (includes antenna mounting bracket, coax cable, two clamps and lightning arrestor) Region Global LGT-ARRST-x Lightning Arrestor (Single or 5 pack) Global CA-NTYPE-MF-x Outdoor Coax Cable, N Type Male & Female (Single or 5 pack) Global MB-ANT-IP67-x Antenna Mounting Bracket, Mounts 1 Antenna (Single or 5 pack) Global PS-56V-POE-NAM-x Single Port Power over Ethernet Transformer w/NAM Power Cord (Single or 5 pack) PS-56V-POE-EU-x Single Port Power over Ethernet Transformer w/EU Power Cord (Single or 5 pack) EMEA PS-56V-POE-GB-x Single Port Power over Ethernet Transformer w/UK Power Cord (Single or 5 pack) GB/IE NAM Go to www.multitech.com for detailed product model numbers. Produced in the U.S. of U.S. and non-U.S. components. Features and specifications are subject to change without notice. The LoRa® name and associated logo are trademarks of Semtech Corporation or its subsidiaries. Trademarks and Registered Trademarks: MultiTech and the MultiTech logo, MultiConnect, Conduit, mDot, xDot, DeviceHQ: Multi-Tech Systems, Inc. All other products and technologies are the trademarks or registered trademarks of their respective holders. 2019-05 • 86002208 • © 2019 Multi-Tech Systems, Inc. All rights reserved. World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) Strata House 264-270 Bath Road Harlington UB3 5JJ United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk www.multitech.co.uk
MTCDTIP-LEU1-275L-868 价格&库存
很抱歉,暂时无法提供与“MTCDTIP-LEU1-275L-868”相匹配的价格&库存,您可以联系我们找货
