MT100EOCG-EV3-GP-N3
MT100EOCG-EV3-GP-N3
    MULTI-TECHSYSTEMS
    Module
    GATEWAY EV-DO PROGR GPS VERIZON
MT100EOCG-EV3-GP-N3 数据手册
MultiConnect OCG-E ® Open Communications Gateways - Embedded The MultiConnect® OCG-E open communications gateways with CoreCDP™ comprise an open Linux development environment and a fully certified hardware offering that includes multiple interfaces and internal peripherals in one application-ready end user solution. Applications that require device networking capability can now be embedded directly onto select MultiTech hardware, providing a flexible, quick and cost-effective way to bring your solution to market. Hardware ·· 400 MHz ARM9™ CPU ·· 256MB NAND flash and 64MB SDRAM ·· Carrier approved 2G or 3G cellular connectivity ·· Non-cellular models available ·· Optional dedicated GPS receiver ·· 80-pin board-to-board connector Benefits ·· Multiple interfaces available (serial, USB host and device, Ethernet and more) • Linux-based open source software CoreCDP Software • Proven hardware for the development and deployment of custom applications ·· Custom Linux distribution ·· Provides complete Linux build environment ·· Cross-compile thousands of open source software packages • Cost-effective alternative to custom manufacturing ·· Create custom applications in a short period of time • Comprehensive service and developer support Developer Kit ·· Customized development board for use with all models ·· Includes all physical interfaces, cables, power supply and antennas necessary to develop your application ·· Speeds hardware and software development Support ·· Advanced developer support available 64MB SDRAM UART ·· Established developer community available at www.multitech.net ·· Two-year warranty GPS 256MB NAND Flash 2G/3G Cellular SocketModem® UART/USB CPU ARM9, 400 MHz Real-time Clock Temp Sensor 80 pin B2B connector Battery / GPIO / ADC / SPI / I2C / JTAG / Ethernet / USB Host / USB Device / GPS PPS - Data / Serial UARTs / LEDs Specifications Models MT100EOCG-H5 MT100EOCG-EV2 MT100EOCG-EV3 MT100EOCG-G2 Environmental Power Requirements Physical Description Certifications CoreCDP Software Specifications (Version 2.1.0) Linux Kernel 2.6.35.14 Utilizes OpenEmbedded framework Tested with the following Linux OS: Ubuntu 9.10 & 11.04 (recommended) Fedora Core 12 – 15 openSUSE 11.4 Drivers to support all peripherals included on the platform hardware Programming Languages: Python, Java (JamVM), Perl, Ruby, C/C++, PHP Networking: PPP, iptables Web Server: lighttpd Remote shell: SSH Database: sqlite3 Network file system: samba Software Development Kit: MultiConnect SDK Hardware Specifications Processor & Memory 400 MHz ARM9 CPU 256MB NAND flash 64MB SDRAM Developer kit includes an industrial grade 2GB SD flash memory card Interfaces & Peripherals 1 x 10/100BaseT Autosensing Ethernet Interface 1 x Serial TTL Interface (DTR, RXD, TXD, RTS, DCD, CTS) 1 x Serial TTL Interface (Debug or Data, RXD, TXD) 1 x USB 2.0 Full Speed Device Interface 1 x USB 2.0 Full Speed Host Interface 1 x SPI Bus Interface (6-Pin) 1 x I2C Bus Interface (2-Pin) 1 x JTAG Debug Interface (6-Pin) 1 x SDIO Memory Card Interface (6-Pin) 4 x ADC Inputs 6 x General Purpose Inputs 4 x General Purpose Outputs 1 x Cellular Link Status LED Output 2 x Ethernet LED Outputs (Speed & Link) 1 x Status (Heartbeat)/User Definable LED Output 3 x Cellular Signal Strength/User Definable LED Outputs 1 x User Definable LED Output 6 x VCC DC Input Pins (5V) 6 x Logic Ground Pins Interfaces & Peripherals (continued) Reset Battery Backup SD Card Detect SD Card Protect GPS PPS (Pulse Per Second) GPS Transmit Data RTC (Real Time Clock) Dedicated GPS receiver (Optional) 2G or 3G Cellular modem Temperature sensor Onboard LEDs 2G: Link status Connections 80-Pin Board-to-Board Manufacturer: Hirose Part number: DF12 (3.0) -80DP-0.5V/86 Cellular Antenna: UFL GPS Antenna: UFL SIM: Standard 1.8/3V SIM receptacle (G2 & H4 models) GPS Position: 2.5 meters Acquisition: Hot start 1 second; cold start 29 seconds avg. Sensitivity: Tracking -161 dBm Protocol: NMEA-0183 V3.01, GGA, GLL, GSA, GSV, RMC, VTG Highlights Proven Hardware Platform All MultiConnect OCG-E models are based on MultiTech’s proven hardware design featuring our SocketModem® cellular communication devices and an ARM9 400MHz processor. The hardware is optimized for application development utilizing our CoreCDP Linux distribution. Linux-Based Open Source The MultiConnect OCG-E uses the OpenEmbedded framework as the base to provide a custom Linux distribution, known as CoreCDP. This allows developers to cross-compile thousands of open source software packages and to create custom applications in a very short period of time. In many cases, existing applications can easily be run with little or no modification. Carrier Approved All MultiConnect OCG-E models are carrier and PTCRB or CDG approved, relieving customers the burden and expense of obtaining these approvals independently. This also provides a faster time-to-market and improved return on investment. Embedded OCG Pin-Out The MultiConnect OCG-E interfaces to your design via an 80-pin board-to-board connector giving you full access and control of the numerous interfaces and peripherals. Local connectivity options include serial, USB device and host, Ethernet, SPI, I2C. In addition, there are several user definable GPIOs, ADCs and LEDs that can be utilized to enhance your products overall design. Also included are serial and JTAG debug ports to help speed application development and debug. Developer Kit The Developer Kit allows you to plug in the MultiConnect OCG-E communications device and use it for testing, programming and evaluation. Ordering Information Cellular Only Models* Product Description MT100EOCG-H5 3G, HSPA+ Open Communications Gateway MT100EOCG-EV2-N2 3G, EV-DO Open Communications Gateway (Sprint) MT100EOCG-EV2-N3 3G, EV-DO Open Communications Gateway (Verizon) MT100EOCG-EV2-N16 3G, EV-DO Open Communications Gateway (Aeris) MT100EOCG-EV3-N3 3G, EV-DO Open Communications Gateway (Verizon) MT100EOCG-EV3-N16 3G, EV-DO Open Communications Gateway (Aeris) MT100EOCG-G2 2G, GPRS Open Communications Gateway Region Global USA USA USA USA USA Global Cellular & GPS Models* Product Description MT100EOCG-H5-GP 3G, HSPA+ Open Communications Gateway w/GPS MT100EOCG-EV2-GP-N2 3G, EV-DO Open Communications Gateway w/GPS (Sprint) MT100EOCG-EV2-GP-N3 3G, EV-DO Open Communications Gateway w/GPS (Verizon) MT100EOCG-EV2-GP-N16 3G, EV-DO Open Communications Gateway w/GPS (Aeris) MT100EOCG-EV3-GP-N3 3G, EV-DO Open Communications Gateway w/GPS (Verizon) MT100EOCG-EV3-GP-N16 3G, EV-DO Open Communications Gateway w/GPS (Aeris) MT100EOCG-GP-G2 2G, GPRS Open Communications Gateway w/GPS Region Global USA USA USA USA USA Global Non-cellular Models Product Description MT100EOCG Open Communications Gateway MT100EOCG-GP Open Communications Gateway w/GPS Region Global Global Developer Kit Model Product Description MT100EOCG-DK Developer Kit for all Open Communications Gateway Models * Product customization available. Contact your MultiTech representative for details. Region Global Services & Warranty MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs. These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. Products include a 2-year warranty. Installation Support MultiTech’s Installation Support Service delivers priority service with the ability to work one-on-one with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. Technical Support Services At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go. World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk
MT100EOCG-EV3-GP-N3 价格&库存
很抱歉,暂时无法提供与“MT100EOCG-EV3-GP-N3”相匹配的价格&库存,您可以联系我们找货
