MTR-EV3-B07-N2
MTR-EV3-B07-N2
    MULTI-TECHSYSTEMS
    ROUTER EV-DO SPRINT
MTR-EV3-B07-N2 数据手册
MultiConnect® rCell 100 Series Cellular Routers FEATURES ® features such as WAN Failover and Certificate Management, the ·· 4G-LTE, 3G and 2G cellular technology support ·· Flexible Web API for developers based on RESTful JSON over HTTPs ·· Ruggedized enclosure Class I Div 2 ·· Designed, manufactured and tested in ISO 13485 facilities ·· Remotely hosted device management platform MultiConnect rCell 100 Series creates an ideal environment for BENEFITS The MultiConnect® rCell 100 Series of cellular routers, optimized for M2M (machine-to-machine)/Internet of Things (IoT) applications, offer a robust Ethernet or serial network interface platform ready to deploy. The intuitive user interface and free cloud device management (no recurrent monthly fees) allows for quick configuration and over-the-air upgrades. Enhanced with secure and redundant communications critical to the reliability of remote monitoring systems in a variety of industries. Your Devices & Data ·· Lowest total cost of ownership ·· Long and stable lifecycles ·· Certified and carrier-approved Insight + Action + Control Wireless Service Provider Transportation Asset Management Platform Real-Time Management Energy Financial / Retail Healthcare Remote Monitoring Alerts Send + Receive Reports ® Datasheet • www.multitech.com/rcell100 SPECIFICATIONS Model MTR-LAT1 MTR-LVW2 Performance Frequency Band (MHz) MTR-H5 4G: 800(B20)/ 1800(B3)/2600(B7) 3G: 850(B5)/ 900(B8)/2100(B1) 2G: 900/1800 3G: WCDMA/HSDPA/ HSUPA 800/850/900/ AWS1700/1900/2100 2G: GSM/GPRS/EDGE 850/900/1800/1900 LTE 4G: 700(B17)/850(B5) /AWS1700(B4)/ 1900(B2) 3G: 850(B5)/1900(B2) 2G: 850/1900 Diversity/MIMO SMS HSPA+ 4G: 700(B13)/ AWS1700(B4) Packet Data* Up to 100 Mbps downlink/ Up to 50 Mbps uplink (Category 3) Up to 21.0 Mbps downlink, up to 5.76 Mbps uplink Rx Diversity and MIMO DL 2x2 Yes Point-to-Point Messaging, Mobile-Terminated SMS, Mobile-Originated SMS Voltage 7V to 32VDC Connectors Cellular Wi-Fi MTR-LEU1 Female SMA Not Available Not Available Reverse polarity female SMA GPS Female SMA SIM Mini SIM; 1.8 and 3V LAN RJ-45, 10/100 BaseT RS-232 DE9 Power Physical Description 2.5 mm miniature (screw-on) Dimensions (L x W x H) 4.17" x 3.0" x 1.15" (10.6 cm x 7.6 cm x 2.9 cm) Weight Chassis Type Environmental 0.51 lbs (0.231 Kg) Aluminum Operating Temperature† -40° to +176° F (-40° to +80° C) Storage Temperature -40° to +185° F (-40° to +85° C) -40° to +185° F (-40° to +85° C) Humidity Relative humidity 15% to 93% noncondensing Certifications Regulatory FCC Class B (US), IC (Canada) FCC Class B (US) R&TTE (EU Economic Area) Safety UL60950-1 (US), UL 201 (US) cUL60950-1 (Canada) UL60950-1 (US), UL 201 (US) IEC60950-1 (EU Economic Area) AT&T, T-Mobile, Rogers Verizon EU carriers Network Quality FCC Class B (US), IC (Canada), RED (EU Economic Area), RCM (Australia/NZ) UL60950-1 (US), UL 201 (US), Class I Div 2 (US and Canada), cUL60950-1 (Canada), IEC60950-1 (EU Economic Area), AS/NZS 60950.1 (Australia/NZ) PTCRB, GCF approved module, AT&T, T-Mobile, Telstra, EU carriers Rogers, Pending: Bell, Telus MIL-STD-810: High Temp, Low Temp, Cold Dwell, Random Vibration and Sine Vibration SAE J1455: Random Vibration and Sine Vibration Build Options Available B07, B08, B09, B10, Class I Div 2 B07, B08 * Actual performance speeds may be affected by a variety of attributes such as cell tower distance, data loads, packet sizes, etc. † Device has been tested up to +85° C. UL Recognized @ 40° C, limited by AC power supply. UL Recognized @ 60° C when used with the fused DC power cable, part number FPC-532-DC. Note: The radio’s performance may be affected at the temperature extremes. This is considered normal. There is no single cause for this function. Rather, it is the result of an interaction of several factors, such as the ambient temperature, the operating mode and the transmit power. HIGHLIGHTS Applications Security The MultiConnect rCell 100 Series of cellular routers are used in a wide variety of applications such as digital signage, smart vending, smart energy or home medical monitoring. Because the routers are certified and carrier approved, customers are able to quickly deploy with cellular connectivity to realize new revenue streams, expense reduction or improved service offering. The MultiConnect rCell 100 Series of cellular routers use IPSec industry standard data encryption to provide high performance, secure LAN-to-LAN VPN connections with 3DES or AES encryption using IKE and PSK key management. Support for five concurrent VPN tunnels. WI-FI/BLUETOOTH SPECIFICATIONS The Wi-Fi interface can be set up in 802.11 b\g\n Access Point (AP) or client mode. In AP mode, the router can support up to 5 client connections. The Bluetooth serial interface allows you to set up a transparent data pipe from a Bluetooth device to a remote server. The router can be configured using TCP or UDP protocols and supports client and server modes giving you the flexibility you need for your particular application. RFCOM and SPP profile support. Contact MultiTech about additional Bluetooth profile support today. Wi-Fi ·· 802.11 b\g\n (1x1), 2.5GHz (20MHz BW) ·· 11, 54 and 65 Mbps max theoretical throughput, for 802.11 b\g\n, respectively ·· 20, 15 and 14.5 dBm output power, for 802.11 b\g\n, respectively ·· WEP, WPA, and WPA2 support Bluetooth ·· Version 2.1+EDR · Power Class 1.5 · Data rate 3 Mbps SPECIFICATIONS Model MTR-H6 MTR-EV3 MTR-G3 MTR-C2 HSPA EV-DO GPRS Class 10 1xRTT Frequency Band (MHz) 3G: Tri-band 850/900/2100 2G: Quad-band 850/900/1800/1900 Dual-band 800/1900 Quad-band 850/900/1800/1900 Dual-band 800/1900 Packet Data* Up to 7.2 Mbps downlink, up to 5.76 Mbps uplink Up to 3.1 Mbps downlink Up to 1.8 Mbps uplink Up to 85.6K downlink Up to 85.6K uplink Up to 153.6K downlink Up to 153.6K uplink No Yes Performance Diversity/MIMO SMS No Point-to-Point Messaging, Mobile-Terminated SMS, Mobile-Originated SMS Voltage 7V to 32VDC Connectors Cellular Female SMA Wi-Fi Not Available Not Available Reverse polarity female SMA GPS SIM Female SMA Mini SIM; 1.8 and 3V N/A LAN Mini SIM; 1.8 and 3V N/A RJ-45, 10/100 BaseT RS-232 DE9 Power Physical Description 2.5 mm miniature (screw-on) Dimensions (L x W x H) 4.17" x 3.0" x 1.15" (10.6 cm x 7.6 cm x 2.9 cm) Weight Chassis Type Environmental 0.51 lbs (0.231 Kg) Aluminum Operating Temperature† -40° to +185° F (-40° to +85° C) Storage Temperature -40° to +185° F (-40° to +85° C) Humidity Relative humidity 15% to 93% noncondensing Certifications Regulatory RED (EU Economic Area), RCM (Australia/NZ) FCC Class B (US) R&TTE (EU Economic Area) FCC Class B (US) Safety IEC60950-1 (EU Economic Area), AS/NZS 60950.1 (Australia/NZ) UL60950-1 (US), UL 201 (US), Class 1 Div 2 (US and Canada) IEC60950-1 (EU Economic Area) UL60950-1 (US), UL 201 (US) GCF, Telstra, EU carriers Aeris, Verizon, Sprint EU carriers Verizon, Aeris Network MIL-STD-810: High Temp, Low Temp, Cold Dwell, Random Vibration and Sine Vibration SAE J1455: Random Vibration and Sine Vibration Quality Build Options Available B16, B18, B19 B07, B08, B09, B10 B16 B16, B17 * Actual performance speeds may be affected by a variety of attributes such as cell tower distance, data loads, packet sizes, etc. † Device has been tested up to +85° C. UL Recognized @ 40° C, limited by AC power supply. UL Recognized @ 60° C when used with the fused DC power cable, part number FPC-532-DC. Note: The radio’s performance may be affected at the temperature extremes. This is considered normal. There is no single cause for this function. Rather, it is the result of an interaction of several factors, such as the ambient temperature, the operating mode and the transmit power. BUILD / ORDERING OPTIONS (FOR MODELS WITH ACCESSORY KITS) Build Number B07 B08 B09 B10 B16 B17 B18 Power Supply Cellular Antenna Ethernet Cable X X X X X X X X X X X X X X X X X X X X X WIRELESS ACCESSORIES ORDERING GUIDE: WWW.MULTITECH.COM/CPAG.GO GPS Antenna Wi-Fi Antenna X X X X X X SOFTWARE SPECIFICATIONS SERVICES & WARRANTY SECURITY Up to 5 concurrent tunnels IPSec IKEv1,v2 Cipher suite: DHGroup 14 Configurable encryption: AES256, DES, 3DES Configurable hash: SHA-1,2, MD5, RSA Configurable TLS: 1.0,1.1,1.2 Encapsulation: ESP Open VPN MAC Filtering Accept, reject, drop or log packets based on MAC address SPI Firewall Configurable DNAT, NAT-T, SNAT IP Defense Denial-of-service ICMP/Ping flood Brute force access X.509 Certificates Support generation and/or import of certificates through use of SHA-256 PAP/CHAP Authentication protocols for secure PPP connections MANAGEMENT SNMP V1,2,3 HTTP server Web UI for setup and help Trouble shooting commands to store logs to DeviceHQ Remote reboot over SMS Commands to retrieve connection status, radio stats, Ethernet link status APN modification over SMS SMS Remote device management platform provides device status and information in a clear graphical format. Manage , monitor, group, configure and upgrade devices remotely DeviceHQ Active/inactive interface status (serial, Ethernet, Wi-Fi, cellular link) Data traffic stats (Ethernet, Wi-Fi, Cellular) Data usage alerts Event Notifications (SNMP, SMS, Email) Time Stamped API RESTful JSON over HTTPs MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs. These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. INSTALLATION SUPPORT MultiTech’s Installation Support Service delivers priority service with the ability to work one-onone with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. TECHNICAL SUPPORT SERVICES At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go USER INTERACTION User Interface Secure graphical and intuitive web UI (requires user name and password) Configuration Help Personalization Set up wizard or manual option Context sensitive help. Documentation and step-by-step directions integrated into the web UI Customize support contact information, logos and color schemes World Headquarters NETWORKING FLEXIBILITY WAN Failover Dynamic DNS (DDNS) Wi-Fi to Cellular Automatically updates DNS DHCP Server Supports fixed and dynamic IP addressing Bridge Mode PPP/IP Pass-through Clock Serial RS-232 MODBUS Configurable SNTP client PAD, TCP/UDP client and server MODBUS pass-through, MODBUS RTU to TCP and vice versa Persistent Connectivity/ Keep Alive Automatic repair of the cellular PPP connection Configurable ICMP or TCP ping at specified intervals Dial on Demand Cellular connection only when there is traffic to send Wake up on Call Cellular connection upon a wake up event such as ring, caller ID or SMS GPS Server and client Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) Strata House 264-270 Bath Road Harlington UB3 5JJ United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk www.multitech.co.uk
MTR-EV3-B07-N2 价格&库存
很抱歉,暂时无法提供与“MTR-EV3-B07-N2”相匹配的价格&库存,您可以联系我们找货
