MTCMR-G2-ED-GB/IE
MTCMR-G2-ED-GB/IE
    MULTI-TECHSYSTEMS
    MODEM ICELL GPRS MULTIMODEM
MTCMR-G2-ED-GB/IE 数据手册
MultiModem iCell ® Intelligent GPRS Cellular Modem Benefits • Intelligent Universal IP stack • Enhanced M2M functionality • Programmable GPIO ports • Carrier approved The MultiModem® iCell intelligent GPRS cellular modem offers standards-based quad-band GPRS performance. This ready-to-deploy, standalone modem provides wireless data communication and GPS tracking and integrates seamlessly with virtually any application. The intelligence of the embedded Universal IP™ stack allows for automatic/persistent connectivity for mission-critical applications and enhanced M2M functionality. The MultiModem iCell intelligent cellular modem is based on industry-standard open interfaces and can be desktop or panel mounted. Features • GPRS Class 10 • Quad-band 850/900/1800/1900 MHz • Intelligent Universal IP stack for enhanced machine-to-machine functionality • Models with GPS tracking capability • NMEA-0183 V3.01 compliant GPS messages • Event monitoring and reporting via integrated GPIO ports • Supports Short Message Service • Available with RS-232 and USB 2.0 interfaces • Packet data up to 85.6K bps • Circuit-switched data up to 14.4K bps • USB 2.0 full speed interface • SMA antenna connector(s) and SIM socket • Desktop or panel mounting • FCC, PTCRB and R&TTE certified • AT command compatible • Two-year warranty Highlights Applications. The MultiModem iCell intelligent cellular modem with GPRS support is ideal for highly data-intensive, missioncritical applications such as remote video surveillance, and other multimedia applications where you are sending digital images, web pages and photographs. For asset tracking and fleet management applications, models with a dedicated GPS receiver are available. Universal IP for Enhanced M2M Connectivity. Multi-Tech’s Universal IP stack consists of a common set of TCP/IP networking protocols and M2M applications implemented using a standard AT command interface. Universal IP provides developers a common programming interface effectively future proofing their application as new cellular technologies are introduced. Some of the benefits of Universal IP are Automatic/Persistent Connectivity, Device Monitor, Event Monitoring/Reporting, Ping & TCP Keep Alive and Wake-up on Caller ID/Wake-up on Ring. Reduces Development Time. The MultiModem iCell intelligent cellular modem can make your existing and next generation device communication-ready without requiring any hardware changes to its design. It actually provides faster time-to-market because it relieves the burden and expense of obtaining PTCRB and RF approvals. Multiple Interface Options. The MultiModem iCell intelligent cellular modem is designed around a broad range of interface options including RS-232, USB and GPIO to provide you with seamless connectivity for your application. Each interface option offers unique features and benefits related to the technology it supports. Comprehensive Service and Support. The Multi-Tech commitment to service means we provide a two-year product warranty and service that includes free technical support, 24-hour web site and ftp support. Ordering Information Product Description Region MTCMR-G2* Intelligent GPRS Modem Global MTCMR-G2-GP* Intelligent GPRS Modem (GPS) Global Ordering Codes -NAM Includes US Style Power Plug -ED 900/1800 MHz Default -EU Includes Euro Style Power Plug -GB/IE Includes UK Style Power Plug * Use ordering codes for specific build options. Go to www.multitech.com for detailed product model numbers. Produced in the US of US and non-US components. Features and specifications are subject to change without notice. Trademarks / Registered Trademarks: MultiModem, Universal IP, Multi-Tech, and the Multi-Tech logo: Multi-Tech Systems, Inc. / All other products and technologies are the trademarks or registered trademarks of their respective holders. World Headquarters Tel: (763) 785-3500 (800) 328-9717 www.multitech.com 6/12 86002128 EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118-959 7774 Copyright © 2012 by Multi-Tech Systems, Inc. All rights reserved. Specifications Packet Data Features GPRS Class 10, PBCCH support Coding Schemes: CS1 to CS4 Embedded TCP/IP stack Circuit Switched Data/Fax Features Asynchronous, transparent & non-transparent up to 14.4K bps, MNP2 & V.42bis SMS Features Text & PDU, Point-to-Point, cell broadcast Universal IP Features TCP/IP Features: DNS resolve, FTP client, Ping, POP3 client, PPP (dial-out), SMTP client, TCP RAW client & server, UDP RAW client & server, PAP, CHAP GPS Position: 2.5 meters Aquisition: Hot start 1 second; cold start 29 seconds avg. Sensitivity: Tracking -161 dBm Protocol: NMEA-0183 V3.01, GGA, GLL, GSA, GSV, RMC, VTG Connectors RF & GPS Antenna: 50 ohm SMA female RS-232: DE-9 female / USB: USB Type B Power: 2.5mm miniature screw GPIO: 6-pin Molex female with ESD protection SIM: Standard 1.8V & 3V SIM receptacle Power Requirements 9V to 32VDC GPIO Functions Pin 1-2: Digital input, 24V tolerance Pin 3-4: Configurable as digital input (5V tolerant TTL/ CMOS levels); digital outputs (3.3V high), or ADC inputs (0 to 3.3V rail) Pin 5: ADC input (0 to 3.3V rail) Pin 6: Ground (must be connected to the ground of the attached device) Physical Description 4.9" w x 1.1" h x 3.5" d; 8 oz (12.4 cm x 2.8 cm x 8.9 cm; 227 g) Environment Operating: -22º to +122º F (-30º to +50º C) Storage: -40º to +185º F (-40º to +85º C) Humidity: 20% to 90% non-condensing Certifications EMC Compliance: FCC Part 15 Class B; EN55022 Class B Radio Compliance: FCC Part 22, 24; RSS 132, 133; EN301 489-1, EN301 489-3 (GPS model only), EN301 489-7, EN301 511, AS/ACIF S042.1, AS/ACIF, S042.3 Safety: UL 60950-1, cUL 60950-1, IEC 60950-1 Network Compliance: PTCRB
MTCMR-G2-ED-GB/IE 价格&库存
很抱歉,暂时无法提供与“MTCMR-G2-ED-GB/IE”相匹配的价格&库存,您可以联系我们找货
