MTSMC-H4-MI-GP-P2-SP
    MULTI-TECHSYSTEMS
    Module
    RX TXRX MODULE CELL U.FL TH
MTSMC-H4-MI-GP-P2-SP 数据手册
SocketModem iCell ® Intelligent HSPA Cellular Modem Universal Socket Benefits • Interchangeable communications devices • Intelligent Universal IP stack • Quick-to-market • Easy migration to future networks The SocketModem® iCell intelligent cellular modem is a complete, ready-to-integrate communications device that offers standards-based tri-band HSPA 7.2 performance. This quick-to-market communications device allows developers to add wireless communication and GPS tracking to products with a minimum of development time and expense. The intelligence of the embedded Universal IP™ stack allows for automatic/persistent connectivity for mission critical applications and enhanced M2M functionality. The SocketModem iCell intelligent cellular modem is based on industry-standard open interfaces and utilizes Multi-Tech's Universal Socket design. Features • Tri-band HSPA 7.2 • Quad-band GSM/GPRS/EDGE • Universal Socket connectivity • Intelligent Universal IP stack for enhanced M2M functionality • Models with GPS tracking capability • Event monitoring and reporting via integrated GPIO pins (-MI builds) • NMEA-0183 V3.01 compliant GPS messages • Circuit-switched data up to 14.4K bps • Short Message Services (SMS) • UFL antenna connector and SIM socket • Serial only or serial/USB models • Serial interface supports DTE speeds to 921.6K bps* • AT command compatible • PTCRB and carrier certified • Two-year warranty * Effective throughput is 700-750K bps Highlights Applications. With increased 3G packet data rates, the SocketModem iCell intelligent cellular modem will support highly data-intensive applications such as remote video surveillance, multimedia POS/ATM terminals as well as other data-intensive applications. For asset tracking and fleet management applications, models with a dedicated GPS receiver are available. Universal Socket Connectivity. Multi-Tech’s Universal Socket is a flexible, comm-port architecture that provides cellular, Ethernet, PSTN or Wi-Fi network access with interchangeable communications devices. This means you can utilize one system design and populate it with your connectivity device of choice accommodating multiple connectivity requirements. In addition, you are assured a seamless migration to future technologies. Developer's Kit. The Developer's Kit allows you to plug in the communications device and use it for testing, programming and evaluation. For a complete listing of the Developer Kit contents, visit www.multitech.com/pdfs/devkit.go Specifications Packet Data Features HSPA 7.2/UMTS/EDGE/GPRS Frequency Bands 3G: 850/1900/2100 MHz 2G: 850/900/1800/1900 MHz Connectors Antenna: UFL (one each, cellular & GPS) SIM: Standard 1.8/3V SIM receptacle Universal IP. Multi-Tech’s Universal IP consists of a common set of TCP/IP networking protocols and M2M (machine-tomachine) applications implemented using a standard AT command interface. Universal IP allows developers to write their host application one time while having the freedom to select from a growing number of Universal Socket communication devices. GPIO Functions (MI builds only) Reduces Development Time. The SocketModem iCell intelligent cellular modem enhances your product while you focus on developing its core features. It actually provides faster timeto-market because it relieves the burden and expense of obtaining PTCRB and RF approvals. GPS SocketModem iCell Pin-Out. The SocketModem iCell intelligent cellular modem interfaces easily with existing products through a standard serial or USB 2.0 interface. The serial DTE channel is capable of transfer speeds to 921.6K bps and can be interfaced directly to a UART or microcontroller. The complete on-board RF transceiver interfaces with an antenna for direct connection to wireless SMS, circuit‑switched dial‑up, or packet data networks. It also includes an onboard LED to display network status. Pins 48 & 49: Programmable digital input/output Pins 50 & 51: Programmable digital input/output or ADC IP Protocols Supported DNS resolve, FTP client, Ping, POP3 client, PPP (dialout), SMTP client, TCP RAW client & server, UDP RAW client & server, PAP, CHAP authentication Position: 2.5 meters Aquisition: Hot start 1 second; cold start 29 seconds avg. Sensitivity: Tracking -161 dBm Protocol: NMEA-0183 V3.01, GGA, GLL, GSA, GSV, RMC, VTG M2M Applications Automatic connect/reconnect, device monitor, modem emulation, Ping & TCP keep alive, wake-up on Caller ID, wake-up on ring, GPIO event monitoring & alerts Power Requirements IP Models: Sleep: 130mA; Typical: 530mA; Maximum: 910mA GP Models: Sleep: 205mA; Typical: 650mA; Maximum: 995mA Physical Description 3.1" L x 1.4" W x 0.5" H; 1 oz. (7.8 cm x 3.5 cm x 1.2 cm; 28 g) Ordering Information Product Description MTSMC-H4-IP HSPA 7.2 Serial Embedded Modem MTSMC-H4-GP HSPA 7.2 Serial Embedded Modem (GPS) MTSMC-H4-MI-IP HSPA 7.2 Serial/USB Embedded Modem MTSMC-H4-MI-GP HSPA 7.2 Serial/USB Embedded Modem (GPS) Ordering Codes -P1 Generic - Europe -P2 For AT&T Networks (USA) Region Regional Regional Regional Regional Produced in the US of US and non-US components. Features and specifications are subject to change without notice. Trademarks / Registered Trademarks: SocketModem, Universal IP, Multi-Tech, and the Multi-Tech logo: Multi-Tech Systems, Inc. / All other products and technologies are the trademarks or registered trademarks of their respective holders. World Headquarters Tel: (763) 785-3500 (800) 328-9717 www.multitech.com 11/10 86002127 EMEA Headquarters Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118-959 7774 Copyright © 2010 by Multi-Tech Systems, Inc. All rights reserved. Operating Environment -30° to +75° C Certifications CE Mark, R&TTE EMC: FCC Part 15 Class B, 22, 24, EN 301 489-1, EN 301 489-7, RSS 132, 133 Radio Compliance: EN 301 489-24, EN 301 489-3 (GPS models) Safety: cUL 60950-1, IEC 60950-1, UL 60950-1, AS/NZS 60950-1 Network: PTCRB / RoHS Compliant
MTSMC-H4-MI-GP-P2-SP 价格&库存
很抱歉,暂时无法提供与“MTSMC-H4-MI-GP-P2-SP”相匹配的价格&库存,您可以联系我们找货
