MTSMC-EV3-N2.R1
MTSMC-EV3-N2.R1
    MULTI-TECHSYSTEMS
    Module
    RF TXRX MODULE CELLULAR U.FL ANT
MTSMC-EV3-N2.R1 数据手册
SocketModem Cell ® Embedded Cellular Modem BENEFITS ·· 2G, 3G, and 4G models ·· 4G Category 3 models include GNSS ·· Universal Socket connectivity ·· Short Message Services (SMS) ·· Serial or USB interfaces ·· Serial interface supports speeds up to 921.6K bps The SocketModem® Cell embedded cellular modem is a complete, ready-to-integrate communications device ideal for customers looking to add cellular communications to their solutions. Choose a carrier approved and end-device certified embedded modem from MultiTech to decrease your time to market and save you money. ·· AT command compatible ·· USB 2.0 HS compatible (3G and 4G models) ·· Two-year warranty FEATURES ·· Approved by carriers and regulatory agencies saving customers time, money, and protection from the risks associated with pursuing their own certifications ·· Quick to market leveraging MultiTech’s approvals ·· Interchangeable communications devices for easy migration to future networks ·· Long solution lifecycle reduces redesign time and cost www.multitech.com/SMCell Your Devices & Data ·· Support from the leading experts in M2M technology Connecting Your Devices Insight + Action + Control Transportation Energy Alerts Financial / Retail Real-Time Management Healthcare Remote Monitoring Wireless Service Provider Asset Management Platform Reports Universal Socket Connectivity HIGHLIGHTS Ethernet Future Network PSTN Universal Socket Connectivity Bluetooth Cellular MultiTech’s Universal Socket is a flexible, comm-port architecture that provides cellular, Ethernet, PSTN or Bluetooth® network access with interchangeable communications devices. This means you can utilize one system design and populate it with your connectivity device of choice accommodating multiple connectivity requirements. In addition, you are assured a seamless migration to future technologies. SPECIFICATIONS Model Performance MTSMC-LAT1 / MTSMC-LAT1-U MTSMC-LAT3 / MTSMC-LAT3-U MTSMC-LEU1 MTSMC-LEU1-U MTSMC-LVW2 / MTSMC-LVW2-U MTSMC-LVW3 / MTSMC-LVW3-U LAT1: LTE 3GPP Release 9 (Category 3; 100 Mbps peak downlink/50 Mbps peak uplink) with HSPA+ 21/GPRS fallback LAT3: LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/5 Mbps peak uplink) with HSPA fallback LTE 3GPP Release 9 (Category 3; 100 Mbps peak downlink/50 Mbps peak uplink) with HSPA+ 42/GPRS fallback LVW2: LTE 3GPP Release 9 (Category 3; 100 Mbps peak downlink/50 Mbps peak uplink) (No fall back) LVW3: LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/5 Mbps peak uplink) (No fall back) LAT1: 4G: 700(B17)/850(B5)/ Frequency Bands (MHz) AWS1700(B4)/1900(B2) 3G: 850(B5)/1900(B2) 2G: 850/1900 LAT3: 4G: 700(B12/B13)/850(B5)/ AWS1700(B4)/1900(B2) 3G: 850(B5)/1900(B2) LVW2: 700(B13)/AWS1700(B4) 4G: 800(B20)/1800(B3)/2600(B7) 3G: 850(B5)/900(B8)/2100(B1) 2G: 900/1800 LVW3: 700(B13)/ AWS1700(B4)/1900(B2) SMS Mobile Originate, Mobile Terminated and Cell Broadcast PDU or Text Mode USB USB 2.0 high speed compatible (-U models) TCP/IP Functions FTP, SMTP, SSL, TCP, UDP Connectors Antenna (LAT1/LVW2): 3 UFL (Cellular, Rx Diversity/MIMO, GPS) Antenna (LAT3/LVW3): 2 UFL (Cellular, Rx Diversity/MIMO) Mini SIM; 1.8V & 3V Dimensions 3.15" x 1.375" (80.010 mm x 34.925 mm) Power Draw* (LVW2) (LAT1/LEU1) Serial Model @ 5VDC; 8mA sleep, 20mA idle, 554mA average at max power USB Model @ 5VDC; sleep N/A, 29mA idle, 560mA average at max power (LAT3) TBD Input Power Serial Model @ 5VDC; 5mA sleep, 63mA idle, 453mA average at max power USB Model @ 5VDC; sleep N/A, 27mA idle, 500mA average at max power (LVW3) TBD 3.3V – 5VDC Environmental Operating Temperature -40° to +85° C Storage Temperature -40° to +85° C Humidity 20% to 90% RH, non-condensing Certifications EMC Compliance FCC Part 15 Class B EN55022 Class B, EN55024 FCC Part 15 Class B Radio Compliance FCC Part 22, 24, 27 EN 301 511, EN 301 489-1, EN 301 489-7, EN 301 489-24 FCC Part 27 UL 60950-1 2nd ED, cUL 60950-1 2nd ED, IEC 60950-1 2nd ED IEC 60950-1 2nd ED, AS/NZS 60950.1 UL 60950-1 2nd ED, cUL 60950-1 2nd ED, IEC 60950-1 2nd ED Safety Network Carrier PTCRB AT&T, T-Mobile * See device guides for additional information. N/A N/A Verizon SocketModem Cell Pin-Out Developer Kits The SocketModem Cell cellular The Developer Kits allow you to plug in the modem interfaces easily with communications device and use it for testing, existing products through a programming and evaluation. standard serial communication The MTSMI-UDK developer kit is designed to work channel. The serial DTE channel with all Universal Socket devices including cellular and is capable of transfer speeds analog SocketModems as well as SocketEthernet IP® and to 921.6K bps (depending on SocketWireless® Bluetooth® device servers. model) and can be interfaced directly to a UART or The MTUDK2-ST-CELL developer kit is designed to work microcontroller. The complete with all versions of our cellular SocketModems as well as on-board RF transceiver interfaces with an antenna the new MultiConnect® Dragonfly™ family of cellular SoMs. for direct connection to wireless data networks. It also Both kits include a development board and all the includes an onboard LED to display network status. necessary accessories to get you up and running right out of the box. SPECIFICATIONS Models Performance Frequency Bands (MHz) MTSMC-H5 HSPA+ MTSMC-C2 EV-DO Rev A GPRS Class 10 CDMA2000 1xRTT (AWS)/1900/2100 800/1900 850/900/1800/1900 800/1900 Band Class 10 (-N2 only) 2G: 850/900/1800/1900 USB 2.0 High Speed TCP/IP Functions N/A FTP, SMTP, TCP, & UDP Antenna: 2 UFL (Cellular, Rx Diversity) Mini SIM; 1.8V & 3V Antenna: 2 UFL (Cellular, Rx Diversity) Dimensions Power Draw* MTSMC-G3 3G: 850/900/1700 USB Connectors MTSMC-EV3 FTP, SMTP, TCP, & UDP FTP, SMTP, TCP, & UDP Antenna: 1 UFL Mini SIM; 1.8V & 3V 1 UFL 3.15" x 1.375" (80.010 mm x 34.925 mm) 5VDC; 19mA sleep, 28mA idle, 397mA maximum Input Power 5VDC; 22mA sleep, 34mA idle, 423mA maximum 3.3V - 5VDC 5VDC; 32mA sleep, 54mA idle, 358mA maximum 5VDC; 32mA sleep, 45mA idle, 552mA maximum 3.3V - 5VDC 3.3V - 5VDC Environmental Operating Temperature -35° to +85° C -40° to +85° C Storage Temperature -40° to +85° C Humidity 20% to 90% RH, non-condensing Certifications EMC Compliance FCC Part 15 Class B, EN55022, EN55024 FCC Part 15 Class B EN55024 FCC Part 15 Class B Radio Compliance FCC Part 22, FCC Part 24, RSS 132, RSS 133, EN 301 511, EN 301 489-1, EN 301 489-3, EN 301 489-7, EN 301 489-24 FCC Part 22, FCC Part 24 EN 301 511, EN 301 489-1, EN 301 489-3, EN 301 489-7 FCC Part 22, FCC Part 24 Safety UL 60950-1 2nd ED, cUL 60950-1 2nd ED, IEC 60950-1 2nd ED UL 60950-1 2nd ED, cUL 60950-1 2nd ED, IEC 60950-1 2nd ED IEC 60950-1 2nd ED UL 60950-1 2nd ED, cUL 60950-1 2nd ED, IEC 60950-1 2nd ED Network PTCRB N/A Uses a GCF certified module N/A Carrier AT&T, Aeris, T-Mobile, Rogers Verizon, Aeris, Sprint N/A Verizon, Aeris, Sprint * See device guides for additional information. ORDERING INFORMATION LTE Models SERVICES & WARRANTY Product Description Region MTSMC-LAT1 LTE Cat 3 Embedded Modem w/Fallback & GNSS (Serial Interface) US/Can MTSMC-LAT1-U LTE Cat 3 Embedded Modem w/Fallback & GNSS (USB Interface) US/Can MTSMC-LEU1 MTSMC-LEU1-U MTSMC-LVW2 LTE Cat 3 Embedded Modem w/Fallback & GNSS (Serial Interface) LTE Cat 3 Embedded Modem w/Fallback & GNSS (USB Interface) MTSMC-LVW2-U Euro/GB/AU Euro/GB/AU LTE Cat 3 Embedded Modem w/GNSS w/o Fallback (Serial Interface) (Verizon) US LTE Cat 3 Embedded Modem w/GNSS w/o Fallback (USB Interface) (Verizon) US MTSMC-LAT3 LTE Cat 1 Embedded Modem w/Fallback (Serial Interface) US/Can MTSMC-LAT3-U LTE Cat 1 Embedded Modem w/Fallback (USB Interface) US/Can MTSMC-LVW3 LTE Cat 1 Embedded Modem w/o Fallback (Serial Interface) (Verizon) US MTSMC-LVW3-U LTE Cat 1 Embedded Modem w/o Fallback (USB Interface) (Verizon) US INSTALLATION SUPPORT HSPA+ Models Product Description Region MTSMC-H5 HSPA+ Embedded Modem (Serial Interface) Global MTSMC-H5-U HSPA+ Embedded Modem (USB Interface) Global EV-DO Models Product Description MTSMC-EV3-N2 Region EV-DO Rev A Embedded Modem (Serial Interface) (Sprint) US MTSMC-EV3-U-N2 EV-DO Rev A Embedded Modem (USB Interface) (Sprint) US MTSMC-EV3-N3 US EV-DO Rev A Embedded Modem (Serial Interface) (Verizon) MTSMC-EV3-U-N3 EV-DO Rev A Embedded Modem (USB Interface) (Verizon) US MTSMC-EV3-N16 US EV-DO Rev A Embedded Modem (Serial Interface) (Aeris) MTSMC-EV3-U-N16 EV-DO Rev A Embedded Modem (USB Interface) (Aeris) US GPRS Models Product Description MTSMC-G3-EU MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs. These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. 850/900/1800/1900 MHz GSM/GPRS Modem Region Euro/GB CDMA Models Product Description Region MTSMC-C2-N2 CDMA2000 1xRTT Modem (Serial Interface) (Sprint) US MTSMC-C2-N3 CDMA2000 1xRTT Modem (Serial Interface) (Verizon) US MTSMC-C2-N16 CDMA2000 1xRTT Modem (Serial Interface) (Aeris) US MultiTech’s Installation Support Service delivers priority service with the ability to work oneon-one with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. TECHNICAL SUPPORT SERVICES At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go Developer Kits Product Description Region MTUDK2-ST-CELL SocketModem & Dragonfly Developer Kit - Cellular Global MTSMI-UDK Universal Socket Developer Kit – Cellular, Analog, Bluetooth, Ethernet Global Ordering part numbers as listed are 50 packs. To order a single pack add a –SP to the end of the ordering part number. (MTSMC-LAT1-SP) WORLD HEADQUARTERS Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA HEADQUARTERS Multi-Tech Systems (EMEA) United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk
MTSMC-EV3-N2.R1 价格&库存
很抱歉,暂时无法提供与“MTSMC-EV3-N2.R1”相匹配的价格&库存,您可以联系我们找货
