760088
760088
    MULTICORE
    FLUX - NO CLEAN PEN
760088 数据手册
Technical Data Sheet Multicore“ Flux/Cleaner Pens August 2007 CONTROLLED RELEASE PEN APPLICATORS SPECIAL PROPERTIES Reference x Ideal for touch-up, repair and/or light assembly of TAB, surface mount and high density boards as well as ceramic substrates x Controlled pin-point release x Pen applicators for fluxing and cleaning x User-friendly x Safe, quick and cost-effective x Simple, efficient, easy-to-use for difficult to reach areas x Replaceable tips APPLICATION A new user-friendly method for pin-point application of flux or cleaning solvent on restricted or difficult to reach areas. Ideal for touch up, repair and light assembly of TAB, surface mount and high density boards. Multicore Pen Applicators are safe, quick, easy-to-use and cost-effective. INSTRUCTIONS Multicore Pen Applicators are designed with a stainless steel spring-loaded applicator head that delivers a controlled amount of liquid to the work surface. To apply, gently depress the chiselled tip against the work surface to start the flow to the applicator head. The precision dispensing mechanism eliminates dripping, pooling and wastage or running on vertical and inclined surfaces. Excessive use on rough surfaces will accelerate wear of applicator tip. Replacement tips may be ordered separately. To replace a tip, pull out the old tip and insert a new one. Americas Henkel Corporation 15350 Barranca Parkway Irvine, CA 92618 U.S.A. 949.789.2500 Mini Fluxer MFX3210i Description Halide free,low solids high SIR and passes MILNo Clean P-28809A without X32-10i cleaning. For fast spot soldering on boards, reducing bridging. Resin and halide free, low No Clean solids and contains copper X33S-07i corrosion inhibitors. Leaves least residue. Usage High reliability boards, moderately aged bare or passivated copper finishes. Promotes through-hole filling on bare, passivated and lacquered copper finishes. General cleaner for removal of flux residues, greases and oils from Mini Non-CFC and electronic circuitry. Cleaner Cleaner biodegradable. Soluble in Excellent for all organics, MCF800 MC-PV-01 water and alcohols. also for cleaning solder paste from difficult corners on stencils and screens. Mini Fluxer MFX33S07i PACKAGING Each pen contains 10ml of liquid. Pens can be customised with other dispensable materials, on special order. SHELF LIFE Unopened, one year. GENERAL INFORMATION For safe handling information on this product, consult the Material Safety Data Sheet, (MSDS). Note The data contained herein are furnished for information only and are believed to be reliable. We cannot assume responsibility for the results obtained by others over whose methods we have no control. It is the user's responsibility to determine suitability for the user's purpose of any production methods mentioned herein and to adopt such precautions as may be advisable for the protection of property and of persons against any hazards that may be involved in the handling and use thereof. In light of the foregoing, Henkel Corporation specifically disclaims all warranties expressed or implied, including warranties of merchantability or fitness for a particular purpose, arising from sale or use of Henkel Corporation’s products. Henkel Corporation specifically disclaims any liability for consequential or incidental damages of any kind, including lost profits. The discussion herein of various processes or compositions is not to be interpreted as representation that they are free from domination of patents owned by others or as a license under any Henkel Corporation patents that may cover such processes or compositions. We recommend that each prospective user test his proposed application before repetitive use, using this data as a guide. This product may be covered by one or more United States or foreign patents or patent applications. Europe Henkel Loctite Adhesives Ltd Technologies House, Wood Lane End Hemel Hempstead Hertfordshire HP2 4RQ, United Kingdom +44 (0) 1442 278 000 All trademarks, except where noted are the property of Henkel Corp. Product Asia Henkel Loctite (China) Co. Ltd No. 90 Zhujiang Road Yantai Development Zone Shandong, China 264006 +86 535 6399820
760088 价格&库存
很抱歉,暂时无法提供与“760088”相匹配的价格&库存,您可以联系我们找货
