SCM-36R4.8-8N1R
SCM-36R4.8-8N1R
    EAST
    SPEAKER 8 1W
SCM-36R4.8-8N1R 数据手册
Product Specification 48273 Lakeview Blvd Fremont, CA 94538, U.S.A Tel: 510-413-0002 Fax: 510-413-0010 http://www.east-elec.com Product Name: Speaker Part Number: SCM-36R4.8-8N1R Version: Rev. 1 Date: 2020-3-31 (8Ω 1W) Note: Company passed ISO 9001 / ISO TS16949 / ISO 14001Certifications Revision History Rev. Description 1 Released East Electronics Author/Date Checked By Lv Wenbin March 31. 2020 Gao Rong Approver Wang Jiancheng 1/5 1. Part Number : SCM-36R4.8-2N1R 2. Dimension Drawing: (Unit: mm) 振幅 3. Specification: No. Items 3-1 Rated impedance 8Ω± 15 % 3-2 Resonant frequency (f0) 570Hz ± 20 % 3-3 SPL normal power input 100dB ± 3 0.1M/1W 3-4 Frequency range f0 ~6 kHz 3-5 Distortion < 10 % at 1kHz 3-6 Normal power 3-7 Maximum power 3-8 Appearance normal 3-9 Buzzes & Specification 1.0 V (800,1000,1200,1500,Hz average ) SPL-10dB 2.83 V 2.83 V 2.83V 1W @ Rated noise power operating continuously for 100 hours 2.83 V rattles appearance 1.5 W @ Stimulant program signal for 1 min. on & 2 min. off, cycling for 10 times 3.46 V @ A.T. 15~35℃, H.M. 25~75%, B.P. 86~106kPa no @ 0.3m with sine wave from 100Hz to 4 kHz input/rated noise power 2.83 V 3-10 Diaphragm material Mylar 3-11 8.8 g Weight at 2 kHz NOTES: 1. Test in anechoic room and use the IEC standard baffler which size at : 1350 mm (W) X 1650 mm (H) 2. Test should be made under the conditions of room temperature (20 ±10 °C), relative humidity (60 ±20%) and normal atmospheric pressure. In this case, however, that the judgment is questionable, the test conditions are to be changed to room temperature 20 ±2 °C, relative humidity 60~70% and normal atmospheric pressure. East Electronics 2/5 4. Typical Frequency Response Curve: Frequency(Hz) 300-600 800-2K 2.5K-4.0K 4.2K-7K 7.1K-12K Upper limit +5 +3 +4 +6 +15 Lower limit -5 -3 -4 -6 -15 5. Reliability Test: No. 5-1 5-2 Item Operating temperature High-temperature loading & storage Method of Test -40 °C ~ +85 °C @ ¼ rated noise power /85 ± 2 °C operating for 16 hours then Meet requirements of depositing for 2 hours at constant temperature,completing appearance、Buzzes & testing within 1 hour after withdrawing. rattles after test @ ¼ rated noise power/-10 ± 3 °C operating for 1 hours, 5-3 5-4 5-5 Low-temperature depositing @ -25 ± 3 °C for 2 hours, then resuming at normal loading & storage atmosphere conditions (GB/T9396-1996 4.2) for 4 hours. Static humidity /temperature Temperature (high and low) cycle test East Electronics Tolerance after Testing @ A.T. 40 ± 2 °C, H.M.93± 2 % depositing for 48 hours, then resuming @ normal atmosphere conditions (GB/T9396-1996 4.2) for 24 hours. Meet requirements of appearance、Buzzes & rattles, solderability after test Meet requirements of appearance, Buzzes & rattles, insulation resistance, bearing voltage after test Storage in -40 °C ± 5 °C for 2hours, in 20 °C ± 5 °C for 2 hours, in 85°C ± 5 °C for 2 hours then back in 20 °C ± 5 °C 2 hours, as Appearance: no obviously one cycle. 12 cycle in total. damage 3/5 Drop a product naturally from the height of 1000 mm onto the 5-6 Drop test surface of 100 mm thick wooden board. Two directions: upper and side of the product are to be applied for this drop test once respectively. 5-7 Life test in the room temperature Input the signal with the valid frequency range on the speaker in continuously for 100 hours, the room temperature should control in 15 °C to 35 °C. Conduct the test for the directions of X Y and Z for 0.5 hour each 5-8 Vibration test Tone: no obviously noise SPL ±3dB F0 ±20% ACR ±15% (total 1.5 hours). To-and Fri sweep time(from 10 to 55 Hz and then 55 to 10) under single amplitude of 0.75 mm is 3 minute, then expose to the room temperature for 2 hours. NOTE: The frame is allowed to deform after drop test. 6. Electrical Testing Method: East Electronics 4/5 7. Packing Information: Packing information: 40pcs per tray 9trays for unit,2units per carton Total:720 pcs per box Size:42*32*35cm East Electronics 5/5
SCM-36R4.8-8N1R 价格&库存
很抱歉,暂时无法提供与“SCM-36R4.8-8N1R”相匹配的价格&库存,您可以联系我们找货
