SFM-8527-03
SFM-8527-03
    EAST
    插件,8.7x8.7mm
    BUZZER 3V 8.7MM X 8.7MM TH
SFM-8527-03 数据手册
Product Specification Ningbo East Electronics Limited NO. 88 East Jinhui Road,Yinzhou Ningbo 315100,P.R.China http://www.east-mingtao.com Product Name: SMD Magnetic Transducer Part Number: Version: Date: SFM SFM-- 8527 8527-- 03 1.04 2019 2019-- 11 11-- 6 Note: East is an ISO 9001 , IATF16949 and ISO 14001Certified Company Revision History Rev. Description Author/Date Checked By Approver 1.04 Quality management system revised 汤礼东 2019-11-6 吕文斌 王建成 1.03 Return to version 1.01 吕文斌 2016-7-14 俞凯 王建成 1.02 structure change 吕文斌 2016-6-14 俞凯 王建成 Ningbo East Electronics Limited 1/6 1. Part Number SFM-8527-03 2. Dimension Drawing (Unit: mm) SFM-TERMINAL VERSION Solder paste thickness is not below 0.3mm RECOMMENDED SMD FOOT PATTERN 3.Specification No. Item Specification 3-1 Min. Sound Pressure Level 80dB/2730Hz/3V /10cm 3-2 Rated Voltage 3V 3-3 Operating Voltage 2~5V 3-4 Max. Consumption (At 3VDC) 80mA/2730Hz/6VP-P square wave 3-5 Resonant Frequency 2730Hz 3-6 Coil Resistance 24±8Ω 3-7 Coil Impedance 60Ω 3-8 Operating Temperature -30~+85℃ 3-9 Storage Temperature -30~+85℃ 3-10 Case Material/Color PPS/Black 3-11 Weight 1.0g 3-12 Pin Strength More than 10N NOTES: 1、Value applying rated voltage(resonant frequency,1/2duty,square wave) 2、Test should be made under the conditions of room temperature (20±10℃), normal humidity (60±20%) and normal atmospheric pressure. In this case, however, that the judgment is questionable, the test conditions are to be changed to room temperature 20±2℃, relative humidity 60~70% and normal atmospheric pressure Ningbo East Electronics Limited 2/6 4.Typical Frequency Response Curve Note: Input Voltage 3V Distance 10 cm 5. Reliability Test No. Item Method of Test 5-1 Operating Temperature -30~+85℃ 5-2 Storage in high temperature Storage in +85℃ test box 96 hours then exposed to the room temperature for 2 hours 5-3 Storage in low temperature Storage in -30℃ test box 96 hours then exposed to the room temperature for 2 hours 5-4 Life test in the room Operate the product continuously 5 seconds on 5 seconds off temperature 300 hours at rated voltage 5-5 Temperature / humidity cycle test Storage in +40℃, 93±3%RH test box 96 hours then exposed to the room temperature for 2 hours 5-6 Temperature (high and low) cycle test Conduct the test for 5 cycles without applying power then expose to the room temperature for 2 hours.(See Figure 5-6) Tolerance after Testing Sound pressure level initial value ±10dB Max. consumption value ±20% Conduct the test for the directions of X Y and Z for 0.5 hour Ningbo East Electronics Limited 3/6 5-7 5-8 5-9 5-10 Vibration test each (total 1.5 hours). To-and Fri sweep time(from 10 to 55Hz and then 55 to 10) under single amplitude of 0.75mm is 3 minute, then expose to the room temperature for 2 hours Drop test Drop a product naturally from the height of 700mm onto the surface of 100mm thick wooden board. Two directions: upper and side of the product are to be applied for this drop test once respectively Reflow soldering heat resistance a) Pre-heating conditions shall be +140℃ to 160℃ for 160 to 200 seconds. (See Figure5-9) b) Heating conditions shall be within 60 seconds at +200℃ min., but peak temperature shall be lower than +260℃. (See Figure 5-9) Test of soldering Dip the connecting pins in soldering at 255±5℃ for 3±0.5 seconds Solder shall be attached around over 95% of the dipped portion NOTE: The pins are allowed to deform after drop test. Figure 5-6 Figure 5-9 Ningbo East Electronics Limited 4/6 6. Electrical Testing Method S.P.L.M Sound Pressure Level Meter T.S Testing Sample F.C Frequency Counter T.C Test Circuit F.S.G Frequency Signal Generator A.V.M AC Voltage Meter P.S Power Supply D.V.M DC Voltage Meter D.A.M DC Ampere Meter TEST CIRCUIT: Ningbo East Electronics Limited 5/6 7. Packing Information Ningbo East Electronics Limited 6/6
SFM-8527-03 价格&库存
很抱歉,暂时无法提供与“SFM-8527-03”相匹配的价格&库存,您可以联系我们找货
