W-53A
W-53A
    EAST
    插件,D=50mm
    BUZZER 18V 50MM TH
W-53A 数据手册
Product Specification Ningbo East Electronics Limited NO. 88 East Jinhui Road,Yinzhou Ningbo 315100,P.R.China http://www.east-mingtao.com Product Name: High High-- Output Piezo Alarm Transducer Part Number: Version: Date: W - 53A 1.02 2019 2019-- 10 10-- 9 Note: East is an ISO 9001 , IATF16949 and ISO 14001Certified Company Revision History Rev. Description Author/Date Checked By Approver 1.02 Quality management system revised 汤礼东 2019-10-9 吕文斌 王建成 1.01 Quality Certificate Symbol revised 刘宁 2015-2-12 汤礼东 王建成 1.0 Released 汤礼东 2012-3-9 陈启旺 王建成 Ningbo East Electronics Limited 1/5 1. Part Number W-53A 2. Dimension Drawing (Unit: mm) 3.Specification No. Item Specification 3-1 Min. Sound Pressure Level 105dB/3±0.5kHz/18Vp-p square wave /30cm 3-2 Allowable Input Voltage 50Vp-p 3-3 Capacitance 140±30%nF(At 100Hz) 3-4 Resonant Frequency 1.0~5.0kHz 3-5 Operating Temperature -20~+70ºC 3-6 Storage Temperature -30~+80ºC 3-7 Case Material /Color PA66+30% Glass Fiber/Black 3-8 Weight 9.65g 3-9 Pin Strength More than 10N NOTES: Test should be made under the conditions of room temperature (20±10℃), normal humidity (60±20%) and normal atmospheric pressure. In this case, however, that the judgment is questionable, the test conditions are to be changed to room temperature 20±2℃, relative humidity 60~70% and normal atmospheric pressure Ningbo East Electronics Limited 2/5 4.Typical Frequency Response Curve Note: Input Voltage 18Vp-p square wave Distance 30cm 5. Reliability Test No. Item 5-1 Operating Temperature -20~+70℃ 5-2 Storage in high temperature Storage in +80℃ test box 96 hours then exposed to the room temperature for 2 hours 5-3 Storage in low temperature Storage in -30℃ test box 96 hours then exposed to the room temperature for 2 hours 5-4 Life test in the room Operate the product continuously 5 seconds on 5 seconds off temperature 96 hours at rated voltage 5-5 Temperature / humidity cycle test Storage in +40℃, 93±3%RH test box 96 hours then exposed to the room temperature for 2 hours 5-6 Temperature (high and low) cycle test Conduct the test for 5 cycles without applying power then expose to the room temperature for 2 hours.(See Figure 5-6) Vibration test Conduct the test for the directions of X Y and Z for 0.5 hour each (total 1.5 hours). To-and Fri sweep time(from 10 to 55Hz and then 55 to 10) under single amplitude of 0.75mm is 3 minute, then expose to the room temperature for 2 hours 5-7 Ningbo East Electronics Limited Method of Test Tolerance after Testing Sound pressure level initial value ±10dB Capacitance value ±20% 3/5 5-8 Drop test Drop a product naturally from the height of 700mm onto the surface of 100mm thick wooden board. Two directions: upper and side of the product are to be applied for this drop test once respectively 5-9 Soldering heat resistance test Dip the connecting pins in soldering at 260±5℃ for 10±1 seconds 5-10 Test of soldering Dip the connecting pins in soldering at 230±5℃ for 3±0.5 seconds Solder shall be attached around over 95% of the dipped portion NOTE: The pins are allowed to deform after drop test. Figure 5-6 Ningbo East Electronics Limited 4/5 6. Electrical Testing Method S.P.L.M Sound Pressure Level Meter T.S Testing Sample F.C Frequency Counter F.S.G Frequency Signal Generator A.V.M AC Voltage Meter P.A Power Amplifier 7. Packing Information Packing: 400pcs per export carton Carton Size: 47× 30.5× 35 cm G. Weight: 5.7 kgs N. Weight: 3.9 kgs Ningbo East Electronics Limited 5/5
W-53A 价格&库存
很抱歉,暂时无法提供与“W-53A”相匹配的价格&库存,您可以联系我们找货
