3990251773
3990251773
    TELITWIRELESSSOLUTIONS(泰利特)
    - LE910C4-NF 蜂窝式开发平台 评估板
3990251773 数据手册
51 mm LE 910Cx Mini PCIe Series Linux LTE Cat.1 and 4 LTE Cat to1 and 4 mPCIe Data Cards Embedded 30 mm Product Description IoT Connectivity Ready The LE910Cx series Mini PCIe (mPCIe) modules are optimized for LTE low category networks and are available in single mode and 3G/2G fallback options. In addition to VoLTE support, the LE910Cx series are swappable with other modules in the xE910 mPCIe family. This product is capable of supporting the extensive suite of Value Added Services from IoT Connectivity including Module Management and others which make the management of IoT deployments under mobile networks effective, enhancing profitability and reliability. It is also Portal-ready which means that the AT command library in this module includes a set of high-level commands designed exclusively for quick and hassle-free onboarding of the device to the portal and to back-end systems and servers. Telit Portal-ready modules powered by deviceWISE make application-level data flows and controls simple to program, maintain and improve. Key Benefits • Standard Mini PCIe Data-card form factor • Best-in class 3GPP rel10 platform • Easy to integrate with peripherals and actuators using USB 2.0 HS, UART and user definable GPIOs • Battery-friendly 1.8V GPIO • Ideal platform for IoT applications and mobile data and computing devices with ultra-compact design and extended operating temperature range • Internet friendly with integrated TCP/IP and UDP/IP stacks, • Simple drop-in migration and technology design reuse path to 2G and 3G with any xE910 module • Over-the-Air firmware update Variants 2.2 mm AVAILABLE FOR EMEA North America Latin America Japan LATAM Australia Complete, Ready-to-Use Access to the Internet of Things IoT Modules Connectivity Plans Cat.4 and Cat.1 4G North American market - AT&T, Verizon and T-Mobile Cat.1 4G North American market for Sprint (LTE single-mode) and AT&T (with the addition of global roaming capabilities due to 3G/2G fallback). Cat.1 4G with 3G fallback for APAC optimized for the ANZ region and Japan. Cat.4 and Cat.1 4G with 3G/2G fallback for Europe with full coverage for EU market Family Concept Longevity and cost efficiency are built right into the developer’sproduct architecture with the Telit family, “design once, use anywhere” philosophy. Designers looking to add LTE capabilities to commercial and industrial computing devices benefit from the simple, yet powerful mPICe form factor with the flexibility to choose another technology best suited for the application environment from any one of the other models in the xE910 mPCIe series. 1 Software & Platforms LE910C1-NA LE910C1-NAD North America North America APAC North America (AT&T) (AT&T) (Telstra/ NTT/KDDI/SB) (Sprint) Market LE910C1/C4-AP LE910C1-NS LE910C1/C4-EU LE910C1/C4-NF LE910C1/C4-NFD EMEA North America (Public safety, AT&T, FirstNet, T-Mobile, Verizon + Canada) North America (Public safety, AT&T, FirstNet, T-Mobile, Verizon + Canada) LE910C1-SA LE910C1-SAD LE910C1-SV LE910C1/C4-LA LATAM North America North America North America (FirstNet, AT&T) (FirstNet, AT&T) (VZW) LE910C4-CN China. India Frequencies B1, B3, B5, B8 B1, B3, B5, B8 4G bands (MHz) B2, B4, B12 B2, B4, B12 B9, B18, B19, B26, B28 B2, B4, B5, B1, B3, B7, B2, B4, B5, B12 B2, B4, B5, B12 B12, B25, B26 B8, B20, B28A B13, B14, B66, B71 B13, B14, B66, B71 B2, B4, B12, B14, B66 B2, B4, B12, B14, B66 B4,B13 B1, B2, B3, B4, B5 B7, B28 TDD: B38, B39, B40, B41, TD-SCDMA: B34, B39 3G bands (MHz) B1, B2, B1, B2, B4, B5, B8 B4, B5, B8 2G bands (MHz) B2, B3, B2, B3, B5, B8, B5, B8, Voice VoLTE/3G/2G - B1, B5, B6 B8, B19 - B1, B3, B8 B2, B4, B5 B2, B4, B5 B3, B8 VoLTE VoLTE/3G VoLTE/3G/2G VoLTE/3G - - - - B1, B2, B4, B5 - - - B2, B3, B5, B8 B3, B8 VoLTE VoLTE/3G/2G VoLTE/3G/2G VoLTE - LE910Cx Mini PCIe Series Product Features Environmental Electrical • LTE FDD Cat.1, 3GPP release 10 compliant • Dimensions 51 x 30 x 3.2 mm • LTE FDD Cat.4, 3GPP release 10 compliant • Supply voltage - Nominal: 3.3 VDC - Range: 3.3 - 4.2 VDC • Rx Diversity and MIMO DL 2x2 • Temperature Range -40°C to +85°C • Single Rx option • REACH and RoHS compliant • VoLTE support Interfaces • SMS over IMS • 181-pin LGA interafce • Built in UDP/TCP/FTP/SMTP stack • IPv4/IPv6 stack • Control via AT commands according to 3GPP TS 27.005, 27.007 and Telit Custom AT commands • SIM application Tool Kit 3GPP TS 51.014 • OMA-DM Telit Software Management • Simultaneous support of GPS, Glonass, Bei-dou, Galileo, QZSS • 10 I/O ports (@1.8V) including multifunctional I/Os • USB 2.0 HS / HSIC • UART • PCM • 1.8 V /3 V SIM interface Approvals • FCC /IC, PTCRB , GCF (North America) Data • RCM (Australia) LTE Cat.1 • JRL/JTBL(Japan) • Uplink up to 5 Mbps • RED/GCF (Europe) • Downlink up to 10 Mbps • CCC (China) LTE Cat.4 • Uplink up to 50 Mbps • Downlink up to 150 Mbps DC-HSPA+ 42 Mbps (supported on the variants with 3G fallback) QUESTIONS? VISIT WWW.TELIT.COM/CONTACT-US [07.2022] www.telit.com/facebook | www.telit.com/linkedin edin | www.telit.com/ Telit reserves all rights to this document and the information contained herein. Products, names, logos and designs described herein may in whole or in part be subject to intellectual property rights. The information contained herein is provided “as is.” No warranty of any kind, either express or implied, is made in relation to the accuracy, reliability, fitness for a particular purpose or content of this document. This document may be revised by Telit at any time. For most recent documents, please visit www.telit.com Copyright © 2022, Telit B1, B8
3990251773 价格&库存
很抱歉,暂时无法提供与“3990251773”相匹配的价格&库存,您可以联系我们找货
    库存:11
