UL865N3G204T701
UL865N3G204T701
    TELITWIRELESSSOLUTIONS(泰利特)
    Module
    IC RF 3D CELLULAR MODULE
UL865N3G204T701 数据手册
UL865 Series UL865-N3G UMTS | HSPA 7.2/5.76 Embedded CL865 -DUAL CDMA | 1xRTT GL865-QUAD 24.4 mm GSM | GPRS Embedded Embedde 2.6 mm 24.4 mm Product Description Family Concept The UL865-N3G is a 3G-only, North American, dual-band module in the xL865 family. It is based on the latest Intel chipset to protect the developer’s design investments as a long term availability solution. The UL865-N3G features VQFN packaging that is fully pad-level compatible with its 2G and 3G companions, the CL865-DUAL, GL865 V3 Series and UL865 Series. The Telit xL865 family was conceived to address system integrators and developers needing to start with low volumes (LCC mounting) as well as those already running high volumes (VQFN mounting). Its ultra-compact package allows integration into very small devices. The family includes products that are pin-to-pin and API compatible in GSM | GPRS, CDMA | 1xRTT and UMTS | HSPA. Key Benefits Variants • Simple drop-in migration and technology upgrade solution to 3G high-speed performance for designs currently using 2G xL865 VQFN products Single variant with band combination for North American applications only • Ideal for fleet management and track-and-tracing application with easy to follow reference designs pairing with Telit GPS and GPS / GLONASS receivers IoT Connectivity Ready LE920 Series • Internet application friendly with integrated TCP/IP and UDP/IP stacks AUTO • Voice-capable for applications requiring digital (DVI) interface • Complete SMT platform for m2m solutions running the Embedded LTE 100/50application | DC-HSPA+ customer inside42.0/5.76 the module with embedded Python Script Interpreter This product is capable of supporting the extensive suite of IoT Connectivity value-added services and connectivity you can use to enhance your application and boost your competitive AUTO advantage. HE920 Series Available For EMEA North America Latin America APAC Korea Australia Combine your Cellular module with Short Range modules GNSS modules ATOP 4G www.telit.com GPS | GLONASS | GA UMTS | HSPA+ 14.4/5.76 Embedded Complete, Ready LTE 100/50 | DC-HSPA to Use Access to the Internet of Things • Over-the-Air firmware update via Premium FOTA Management service • Battery-friendly 1.8V GPIO IoT Modules ENABLING JUPITER JF2THE IoT IS WHAT WE DO. JUPITER JN3 IoT Connectivity IoT Portal JUPITER SE8 UL865-N3G Product Features Approvals • Supported Frequencies UMTS | HSPA: 850 / 1900 MHz • RoHS Compliant • FCC, PTCRB, IC (North America) • SIM Access Profile • 3GPP release 7 compliant Electrical • Control via AT commands according to 3GPP TS27.005, 27.007 and customized Telit AT commands • Output power - Class 3 (0.25 W, 24 dBm) @ UMTS • Serial port multiplexer 3GPP TS27.010 • SIM application Tool Kits 3GPP TS 51.014 • Built in UDP / TCP / FTP / SMTP stack • Supply voltage - Nominal: 3.8 VDC - Range: 3.4 - 4.2 VDC • Digital voice and SMS Software • IP stack with TCP and UDP protocols • Python* application resources • Standard and extended AT command set • Python* version = 2.7.2 Data • Python* script interpreter (module takes the application code directly in the Python* language) HSPA category 6 in Uplink and up to category 8 in Downlink: • HSUPA up to 5.76 Mbps • HSDPA up to 7.2 Mbps • Memory: 2 MB of NV memory for the user scripts and 2 MB RAM for the Python engine usage Additional features Environmental • Small dimensions 24.4 x 24.4 x 2.6 mm • PFM (Premium FOTA Management) Over-The-Air Update service • Temperature range -40°C to +85°C • Remote AT commands • Event monitor Interfaces • 8 I/O ports maximum including multifunctional I/Os (1.8 V logic level) • I2S for digital audio interface • USB 2.0 HS • UART • SPI • 1.8 V / 3 V SIM interface [10.2015] • 2 A/D plus 1 D/A converters Telit reserves all rights to this document and the information contained herein. Products, names, logos and designs described herein may in whole or in part be subject to intellectual property rights. The information contained herein is provided “as is”. No warranty of any kind, either express or implied, is made in relation to the accuracy, reliability, fitness for a particular purpose or content of this document. This document may be revised by Telit at any time. For most recent documents, please visit www.telit.com Copyright © 2015, Telit * Copyright © 1990-2015, Python Software Foundation Telit Communications S.p.A. Via Stazione di Prosecco, 5/B I-34010 Sgonico (Trieste), Italy Phone +39 040 4192 200 Fax +39 040 4192 383 E-Mail EMEA @ telit.com Telit Wireless Solutions Inc. 3131 RDU Center Drive, Suite 135 Morrisville, NC 27560, USA Phone +1 888 846 9773 or +1 919 439 7977 Fax +1 888 846 9774 or +1 919 840 0337 E-Mail NORTHAMERICA @ telit.com Telit Wireless Solutions Inc. Rua Paes Leme, 524, Conj, 126 05424-101, Pinheiros São Paulo-SP-Brazil Phone +55 11 3031 5051 Fax +55 11 3031 5051 E-Mail LATINAMERICA @ telit.com Join the Telit Technical Forum For a quicker and more rewarding integration experience join the Telit Technical Forum. There you can browse the first open forum covering all IoT topics, get direct support by region (EMEA, North America, Latin America, APAC), take part in this quickly growing IoT community and exchange experiences. Telit Wireless Solutions Co., Ltd. 8th Fl., Shinyoung Securities Bld. 6, Gukjegeumyung-ro8-gil, Yeongdeungpo-gu Seoul, 150-884, Korea Phone +82 2 368 4600 Fax +82 2 368 4606 E-Mail APAC @ telit.com www.telit.com www.telit.com/techforum www.telit.com/facebook www.telit.com/twitter
UL865N3G204T701 价格&库存
很抱歉,暂时无法提供与“UL865N3G204T701”相匹配的价格&库存,您可以联系我们找货
