PIS-1526
PIS-1526
    PISUPPLY
    - EG95-NA,L70,MT7628,RAK634,SX1301 收发器; LoRa®(LoRaWAN™) 915MHz 评估板
PIS-1526 数据手册
DIY Enterprise Gateway WisDevice Series RAK7249 Product Description The Enterprise Grade DIY outdoor Gateway is an ideal product for IoT commercial deployment. It contains the Main Board, Operator-grade waterproof enclosure, backup battery and mounting accessories. The hardware main board completely integrates the WIFI, 4G, GPS and PoE main supply with an integrated back-up battery. The firmware implements a fully featured LoRaWAN™ complinant network base station. The Gateway has a range of over 15Km line-of-sight and over 2Km in dense urban environments. The DIY Gateway brings more flexiblity for the developer to create an enterprise grade solution. Our most important difference is our flexible development support structure, allowing for faster development and time to market. We offer both a ready to go firmware image for openWRT based platforms and an open SDK for integration into hardware to support the needs of each customer. It can connect the standard NS (network server) and the local NS. And it also supports the built-in NS(By default, a license that supports 128 terminals and 5 external gateways is embedded). It does not need users to deploy NS in the cloud and locally, it saves the cost for server and R&D investment, and has the advantages of high execution efficiency and shorter delay. Package Content Gateway Device Mounting Kit PoE Injector GPS Hardware Interfaces Feature Set Enterprise grade network gateway with your own configuration. LoRaWAN™ Stack Inside and integrate the Web UI for management. Complete Hardware specification including LoRa concentrator, Cellular, GPS and WIFI. Supports Power of Ethernet (PoE) IEEE 802.3af/at-Compliant Class 4, 48V. Battery Backup sustains operation for about 10 hours under typical conditions. IP67 waterproof enclosure with cable gland. WiFi LTE LoRa DIY Enterprise Gateway WisDevice Series RAK7249 Enclosure Main Board CPU:RAK634 Module(MT7628 inside) RAM:128MB DDR2 Flash:16MB WIFI: 2x2 MIMO 802.11b/g/n LoRa concentrator Standard version with 8 channel Gateway and also support Max.16 channel Gateway. Tx Power is up to 27dBm and Rx sensitivity is down to -142dBm. 4G Cellular: Quectel EG95 for CAT4 cellular network. L70 GPS Module Power-over-Ethernet (PoE): 100M base-T Ethernet with IEEE802.3af/at standard PoE. Accessories Mounting Kit PoE Injector Antennas(WiFI Antenna, GPS Antenna, LoRa Antenna, LTE Antenna) IP67 waterproof white color. Interface: 5 x N-Type connectors for Antenna,1 PoE port and 1 reserve port. Weight (with cable): approximately 70.54oz (2kg). Dimensions: 220mm x 220mm x 104mm. Wall thickness: 2mm. Support up to 70~100 mm diameter pole mount Backup Battery The maximum space in the Enclosure can be placed 12V/10AH batteries for about 10 hours lifetime under typical operation. Battery powered real time clock. Battery Within 140 x 70 x 30mm. DC 5.5 x 2.1 circular joint with two interfaces, one male and one female. Supported Software For LoRa For Management For Network Supports class A , C Supports LoRaWAN protocol Country code setup TX power setup Data logger Statistic Location setup Server address & port setup WEB Management Supports SSH2, NTP Firmware update Supports configure the LoRa Packet Forwarder Supports Build-in LoRa Server Supports OpenVPN, Ping Watch Dog Supports MQTT Bridge WiFi AP mode LTE APN setup Uplink backup Supports 802.1q DHCP Server/Client Router module NAT Firewall DIY Configuration Part Number RAK7249-0x-14x 8 Channel SX1301 √ RAK7249-1x-14x RAK7249-2x-14x √ √ RAK7249-3x-14x RAK7249-0x √ √ RAK7249-1x RAK7249-2x RAK7249-3x 16 channel SX1301 √ √ √ Cat4 Cellular GPS WIFI Battery Backup √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ √ DIY Enterprise Gateway WisDevice Series RAK7249 RF Specifications Key Features Computing WIFI Feature LoRa Feature Cellular  MT7628, DDR2RAM 128MB     Frequency: 2.400 - 2.4835GHz (802.11b/g/n) RX Sensitivity: -95dBm (Min) TX Power: 20dBm (Max)  SX1301 Mini PCIe card  8 Channels (Optional: 16 channels)  TX Power: 27dBm (Max)  RX Sensitivity: -142dBm (Min)  Supports Quectel EG95-E / EG95-NA(IoT/M2M-optimized LTE Cat 4 Module)  EG95-E for EMEA Region LTE FDD: B1/B3/B7/B8/B20/B28A WCDMA: B1/B8 GSM/EDGE: B3/B8  EG95-NA for North America Region LTE FDD: B2/B4/B5/B12/B13 WCDMA: B2/B4/B5 Power Supply  POE (IEEE 802.3af), 42~57VDC Power Consumption ETH  12W (typical) Antenna  5 N-Type connectors  IP67 Enclosure Material  Aluminum Dimension Operating Temp. Installation Method  Approximately 111.11oz (3.15kg with mounting kit)  220mm x 220mm x 104mm  -30°C ~ +55°C  Pole or Wall mounting  IEEE 802.11b/g/n Wi-Fi Operating Frequency  ISM band: 2.412~2.472(GHz) Wi-Fi Operation Channels  2.4GHz: 1-13 Wi-Fi Transmit Power (The maximum power may be different depending on local regulations)  802.11b 19dBm@ 1Mbps  802.11g 18dBm@ 6Mbps 16dBm@ 54Mbps  802.11n(2.4G) 18dBm@MCS0 (HT20) 16dBm@MCS7 (HT20) 17dBm@MCS0 (HT40) 15dBm@MCS7 (HT40) Wi-Fi Receiver Sensitivity (Typical)  802.11b -95dBm@ 1Mbps  802.11g -90dBm @6 Mbps -75dBm@54Mbps  802.11n(2.4G) -89dBm@MCS0 (HT20) -72dBm @MCS7(HT20) -86dBm @MCS0(HT40) -68dBm @MCS7(HT40) LoRa Operating Frequency  EU433 / CN470 / EU868 / US915 / AU915 / AS923 / AS920 / KR920 / IN865 LoRa TX Power  27 dBm (Max)  RJ45 (10/100M) Ingress Protection Weight Wireless Standard LoRa RX Sensitivity  -142 dBm (Min) Compliance  CE, FCC, RCM Order Information Part Number Description RAK7249-03-142 8 channel DIY Gateway with Cat 4 Cellular + GPS for EU868 region RAK7249-04-141 8 channel DIY Gateway with Cat 4 Cellular + GPS for US915 region RAK7249-13-142 Advanced version, 16 channel DIY Gateway with Cat 4 Cellular + GPS for EU868 region RAK7249-14-141 Advanced version, 16 channel DIY Gateway with Cat 4 Cellular + GPS for US915 region About RAKwireless: RAKwireless is the pioneer in providing innovative and diverse cellular and LoRaconnectivity solutions for IoT edge devices. It’s easy and modular design can be used in different IoT applications and accelerate time-to-market. For more information, please visit Rakwireless website at www.rakwireless.com. Copyright © 2018 Shenzhen Rakwireless Technology Co. Ltd. All rights reserved. Rakwireless, RAK logo, and WisKeyTM logo are registered trademarks of Shenzhen Rakwireless Technology Co. Ltd. All other trademarks are the property of their respective owners.
PIS-1526 价格&库存
很抱歉,暂时无法提供与“PIS-1526”相匹配的价格&库存,您可以联系我们找货
