NN AMC 3461 PC01
NN AMC 3461 PC01
    NEONODE
    INFRARED TOUCH SENSOR 90DEGREES
NN AMC 3461 PC01 数据手册
zForce AIR™ Touch Sensor User's Guide 2017-12-21 Legal Notice Neonode may make changes to specifications and product descriptions at any time, without notice. Do not finalize a design with this information. Neonode assumes no liability for applications assistance or customer product design. Customers are responsible for their products and applications using Neonode components. To minimize the risks associated with customer products and applications, customers should provide adequate design and operating safeguards. Neonode components are neither designed nor intended for use in FDA Class III applications, or similar life-critical medical equipment. Customers acknowledge and agree that they will not use any Neonode components in FDA Class III applications, or similar life-critical medical equipment, and that Neonode will not be responsible for any failure to meet the requirements of such applications or equipment. No part of the materials contained in any Neonode document may be copied, photocopied, reproduced, translated or reduced to any electronic medium or machine-readable form, in whole or in part, without specific written permission from Neonode Inc. NEONODE, the NEONODE logo and ZFORCE are trademarks of Neonode Inc. registered in the United States and other countries. ZFORCE AIR is a trademark of Neonode Inc. All other trademarks are the property of their respective owners. Copyright © 2017 Neonode Inc. All rights reserved.  zForce AIR™ Touch Sensor User's Guide Table of Contents 1 Table of Contents 1 Table of Contents .................................................................................................................3 2 2.1 Introduction ..........................................................................................................................6 Product Overview 6 2.1.1 Main Features 6 2.2 Product Variants 6 2.2.1 Sensor Orientation 7 2.2.2 Sensor Length 7 Touch Active Area 8 2.3 2.4 2.5 Basic Principles Applications Product Design and Components 10 10 11 2.5.1 Sensor Design 11 Exploded view 11 2.5.2 Sensor Components 12 2.6 Product Integration 13 3 3.1 3.2 3.3 3.4 Getting started with zForce AIR Touch Sensor Evaluation ..........................................14 Evaluation Kit Contents 14 Getting Started 14 Connecting Sensor 14 Communicating with Sensor 16 3.4.1 Neonode Workbench 16 3.4.2 USB HID Digitizer Mode 17 3.4.3 USB HID Raw Mode 17 3.4.4 I2C Transport 17 3.4.5 SDK 17 4 4.1 Multi-Touch Functionality.................................................................................................18 Shadows 18 4.1.1 Shadow Trick 18 4.2 4.3 Adjacent Objects More Than Two Objects 19 19 5 5.1 Mechanical Integration .....................................................................................................20 Means of Integration 20 5.1.1 Horizontal Integration 20 5.1.2 Vertical Integration 21 5.1.3 Options for Guiding and Fastening 21  zForce AIR™ Touch Sensor User's Guide Table of Contents 5.1.4 External Window 22 5.1.5 External Reflective Surface 22 5.2 Touch Applications 22 5.2.1 Touch Accuracy 22 5.2.2 Hovering Touches 23 5.2.3 Assembly Tolerances 23 Translational Tolerances 23 Rotational Tolerances 23 6 6.1 6.2 6.3 6.4 6.4.1 6.4.2 6.5 7 7.1 Electrical Integration.........................................................................................................26 Electrical Block Diagram 26 Physical Connector 26 Pin-Out 27 Interface Configuration 28 USB Connection 28 USB Characteristics 28 I2C Connection 30 I2C Characteristics 30 PIN 3 ( DR ) Characteristics 31 I2C Reading Sequence 32 Power On and Boot Sequence 32 Software Integration .........................................................................................................33 Software Integration Overview 33 7.1.1 Communication Protocol 33 7.1.2 zForce SDK 33 7.2 Initializing Sensors 33 7.2.1 USB HID Raw Mode 33 7.2.2 I2C 33 7.3 zForce® Communication Protocol 34 7.3.1 Communication Protocol Overview 34 Introduction 34 Transport Layer 34 7.3.2 7.3.3 8 8.1 8.1.1 Presentation Layer 35 Transport Layer 35 I2C Transport 35 USB HID Transport 38 Presentation Layer (ASN.1) 50 ASN.1 PDU Description 50 ASN.1 PDU Examples 61 Specifications .....................................................................................................................65 Specifications Overview 65 Touch Performance Specification 65  zForce AIR™ Touch Sensor User's Guide Table of Contents 8.1.2 Technical Specification 65 8.2 Touch Performance 66 8.2.1 Touch Object Requirement 66 8.2.2 Touch Accuracy 66 Specification 66 8.2.3 Definition 66 Response Time 67 Specification 67 Definition 67 8.2.4 Scanning Frequency 68 8.3 Power Consumption 69 8.3.1 Specification 69 8.3.2 Definition 69 8.4 Environmental Requirements 70 8.4.1 Operating and Storage Conditions 70 8.4.2 ESD rating 70 8.4.3 Agency Approvals 70 8.5 Electrical Requirements 70 8.5.1 Absolute Maximum Ratings 70 8.5.2 Recommended Operating Conditions 70 8.6 Optical Requirements on External Window 71 8.6.1 Optical Requirements 71 8.6.2 Geometrical Constraints 71 8.7 Mechanical Data 72 8.7.1 Physical Dimensions and Position of Origin 72 Top View 72 Side View 74 8.8 Test Specifications and Definitions 75 8.8.1 Reliability Test Specification 75 Overview 75 Reliability Test Report 77 8.8.2 zForce AIR™ Touch Sensor User's Guide Introduction 2 Introduction 2.1 Product Overview The zForce AIR Touch Sensor is a laser light based touch sensor that can be integrated and used in various applications. The sensor characteristics are high scanning frequency, low latency, good touch accuracy and the fact that it can be used on any surface or even in mid air. zForce AIR Touch Sensor can be connected to the host system through a standard connector and communicate through a standard I2C or USB interface. 2.1.1 Main Features • • • • • • • • • Enables touch on any surface or in mid air Dual touch support High scanning frequency – up to 200Hz or more depending on sensor length Low touch latency High touch accuracy Idle mode for reduced current power consumption Configurable touch active area I2C and USB interface Standard 5V power supply 2.2 Product Variants In order to fit in a wide range of applications, the zForce AIR Touch Sensor exists in two types and a number of different lengths.  If the variant you are interested in is not available for purchase from your distributor, please contact the distributor or a Neonode sales representative (refer to www.neonode.com1) for more information. 1 http://www.neonode.com/ https://support.neonode.com  6 zForce AIR™ Touch Sensor User's Guide Introduction 2.2.1 Sensor Orientation The zForce AIR Touch Sensor is available in two types, one where the active area emerges straight out from the sensor (0° type) and one where it emerges out from the sensor at a 90° angle (90° type). This enables both vertical and horizontal integration. 0° Type 90° Type 2.2.2 Sensor Length The Touch Sensor is available in 43 different lengths. The length affects the Touch Active Area (TAA) in both X and Y directions. https://support.neonode.com  7 zForce AIR™ Touch Sensor User's Guide Introduction Touch Active Area The table lists all product variants, the product number, and the TAA for each variant. See also Physical Dimensions and Position of Origin (see page 72). Product number TAA (mm) 0° Type 90° Type X Y NNAMC0430PC01 NNAMC0431PC01 43.2 14.9 NNAMC0500PC01 NNAMC0501PC01 50.4 29.8 NNAMC0580PC01 NNAMC0581PC01 57.6 29.8 NNAMC0640PC01 NNAMC0641PC01 64.8 44.7 NNAMC0720PC01 NNAMC0721PC01 72 44.7 NNAMC0790PC01 NNAMC0791PC01 79.2 59.6 NNAMC0860PC01 NNAMC0861PC01 86.4 59.6 NNAMC0940PC01 NNAMC0941PC01 93.6 74.5 NNAMC1010PC01 NNAMC1011PC01 100.8 74.5 NNAMC1080PC01 NNAMC1081PC01 108 89.4 NNAMC1150PC01 NNAMC1151PC01 115.2 89.4 https://support.neonode.com  8 zForce AIR™ Touch Sensor User's Guide Introduction NNAMC1220PC01 NNAMC1221PC01 122.4 104.3 NNAMC1300PC01 NNAMC1301PC01 129.6 104.3 NNAMC1370PC01 NNAMC1371PC01 136.8 119.2 NNAMC1440PC01 NNAMC1441PC01 144 119.2 NNAMC1510PC01 NNAMC1511PC01 151.2 134.0 NNAMC1580PC01 NNAMC1581PC01 158.4 134.0 NNAMC1660PC01 NNAMC1661PC01 165.6 148.9 NNAMC1730PC01 NNAMC1731PC01 172.8 148.9 NNAMC1800PC01 NNAMC1801PC01 180 163.8 NNAMC1870PC01 NNAMC1871PC01 187.2 163.8 NNAMC1940PC01 NNAMC1941PC01 194.4 178.7 NNAMC2020PC01 NNAMC2021PC01 201.6 178.7 NNAMC2090PC01 NNAMC2091PC01 208.8 193.6 NNAMC2160PC01 NNAMC2161PC01 216 193.6 NNAMC2230PC01 NNAMC2231PC01 223.2 208.5 NNAMC2300PC01 NNAMC2301PC01 230.4 208.5 NNAMC2380PC01 NNAMC2381PC01 237.6 208.5 NNAMC2450PC01 NNAMC2451PC01 244.8 208.5 NNAMC2520PC01 NNAMC2521PC01 252 208.5 NNAMC2590PC01 NNAMC2591PC01 259.2 208.5 NNAMC2660PC01 NNAMC2661PC01 266.4 208.5 NNAMC2740PC01 NNAMC2741PC01 273.6 208.5 NNAMC2810PC01 NNAMC2811PC01 280.8 208.5 NNAMC2880PC01 NNAMC2881PC01 288 208.5 NNAMC2950PC01 NNAMC2951PC01 295.2 208.5 NNAMC3020PC01 NNAMC3021PC01 302.4 208.5 NNAMC3100PC01 NNAMC3101PC01 309.6 208.5 https://support.neonode.com  9 zForce AIR™ Touch Sensor User's Guide Introduction NNAMC3170PC01 NNAMC3171PC01 316.8 208.5 NNAMC3240PC01 NNAMC3241PC01 324 208.5 NNAMC3310PC01 NNAMC3311PC01 331.2 208.5 NNAMC3380PC01 NNAMC3381PC01 338.4 208.5 NNAMC3460PC01 NNAMC3461PC01 345.6 208.5 2.3 Basic Principles zForce AIR Touch Sensors detect and trace objects by detecting diffusely reflected infrared light. The sensor comprises an optical system arranged to combine emitted IR beams and receiver fields of view within the same apertures. IR light beams are emitted perpendicular to the output window, while receivers field of view is centered at a certain angle left and right. Each emitter-receiver combination covers a narrow region on the active area. An object present in the active area will affect several emitter-receiver channels, and the reported coordinates is the outcome of a center of gravity calculation on these signals. 2.4 Applications zForce AIR Touch Sensors can be integrated for a wide range of applications, such as:  • • • • • • • • • PCs/Tablets TVs/Monitors Printers Mechanical key replacement White goods Smart furniture Interactive mirrors Elevator panels eReaders https://support.neonode.com  10 zForce AIR™ Touch Sensor User's Guide • • • • • • • Introduction Instruments Vending Machines ATM/POS terminals Robotics Range finders Collision detectors ... and much more 2.5 Product Design and Components The zForce AIR Touch Sensor is a laser light based touch sensor that can be used for various touch and mid-air detection applications. The sensor is available in varying sizes, see Product Variants (see page 6). 2.5.1 Sensor Design The image below show the sensor design (0° type). The connector is shown to the far right. Exploded view The image below shows the sensor (0° type) in an exploded view. https://support.neonode.com  11 zForce AIR™ Touch Sensor User's Guide Part Decription A Cover B Adhesive C Front light pipe –   straight shooting or 90 degree shooting depending on sensor type D Lenses - amount depends on size E PCBA Introduction 2.5.2 Sensor Components  The PCBA is equipped with both active and passive components, for example: • MCU https://support.neonode.com  12 zForce AIR™ Touch Sensor User's Guide • • • • • Introduction Co-processor, a Neonode proprietary scanning IC Optical lenses, made out of polycarbonate VCSELs Photo diodes Other passive components 2.6 Product Integration The zForce AIR Touch Sensor can be integrated to any host system through a physical connector with 8 contact pads with support for both I2C and USB HID. The host system can communicate with the sensor through a communication protocol and an SDK developed by Neonode. https://support.neonode.com  13 zForce AIR™ Touch Sensor User's Guide Getting started with zForce AIR Touch Sensor Evaluation 3 Getting started with zForce AIR Touch Sensor Evaluation This section describes how to get started with the evaluation of a zForce AIR Touch Sensor. 3.1 Evaluation Kit Contents The evaluation kit includes the following: • 1 x zForce AIR Touch Sensor • 1 x Interface board (with USB and I2C interface) • 1 x FPC Cable with connector 3.2 Getting Started 1. Connect the sensor according to Connecting Sensor (see page 14). 2. Start communicating using one of the means listed below:  • Neonode Workbench (see page 16). Use the Neonode Workbench software for Windows to configure a sensor and test and evaluate touch performance. • USB HID Digitizer Mode (see page 17). This is the easiest and fastest way to try out the Touch Sensor. It only requires connecting the interface board to a Windows or Linux computer via USB, but is limited in functionality. • USB HID Raw Mode (see page 17). This also uses a USB connection to a Windows or Linux computer, but requires communicating with the sensor using ASN.1 encoded messages. • I2C Transport (see page 17). This involves sending and receiving ASN.1 encoded messages over I2C. • SDK (see page 17). Using the zForce SDK function library facilitates communication with sensors without considering ASN.1 encoded messages. 3.3 Connecting Sensor 1. Connect the FPC cable to the interface board:   a. Lift the flip lock on the interface board. b. Insert the FPC cable into the end of the connector, with the connector pads facing down, towards interface board. The yellow piece of PCB of the connector on the other side of the cable is facing upwards. Make sure the direction is straight into the connector and the pads have reached the end of the connector. https://support.neonode.com  14 zForce AIR™ Touch Sensor User's Guide Getting started with zForce AIR Touch Sensor Evaluation  Make sure the connector pads of the FPC cable are facing downwards, towards interface board. The sensor risks damage if the FPC cable is connected in wrong direction. c. Press down the flip lock. 2. Connect the FPC cable to the sensor:     a. Place the sensor so that the sensor connector pads of the sensor are facing downwards (steel surface upwards). b. Insert sensor into the connector on FPC cable (yellow piece of PCB of the FPC connector still facing upwards). c. Make sure the direction of the pads is straight into the connector, and the pads have reached the end of the connector. 3. To use Neonode Workbench, USB HID Digitizer mode, USB HID Raw mode, or SDK: Connect a USB cable with a Micro USB type B connector to the interface board.   4. To use I2C Transport: Wire the pads of +5V, DR-B0, I2C-D, I2C-C, and GND on the interface board to the host system. For details, refer to Electrical Integration (see page 26). Do not connect power until the following steps have been performed. 5. Place the sensor on a table with the steel surface facing downwards and with the optical surface facing towards you. https://support.neonode.com  15 zForce AIR™ Touch Sensor User's Guide Getting started with zForce AIR Touch Sensor Evaluation  Make sure no object is within the touch active area of the sensor before connecting power to the sensor through USB or I2C. The sensor calibrates itself when powered on and an object within the touch active area may interfere with the calibration. 6. To use Neonode Workbench, USB HID Digitizer mode, USB HID Raw mode, or SDK: Insert the USB cable into a computer meeting the requirements of USB HID or SDK, respectively. C 7. To use I2C Transport: Connect the power to the sensor through the I2C. 8. The green LED on the interface board lights up when connected.  In case of strong side light, covering the short sides of the sensor with, for example, black tape might improve performace. 3.4 Communicating with Sensor 3.4.1 Neonode Workbench Neonode Workbench is a software tool to use with zForce AIR™ sensors. With Neonode Workbench it is possible to: • • • • Visualize sensor touches. Temporarily configure sensor characteristics, such as active area and scanning frequency. View the sensor firmware version. Conduct Open/Short-circuit tests to identify any damaged photo or laser diodes. https://support.neonode.com  16 zForce AIR™ Touch Sensor User's Guide Getting started with zForce AIR Touch Sensor Evaluation  Download Neonode Workbench from Downloads2 and refer to separate Neonode Workbench documentation. 3.4.2 USB HID Digitizer Mode The easiest way to see the Touch Sensor functionality is to use USB HID Digitizer mode: 1. When the sensor has enumerated, it will act as a touch screen USB HID device. 2. Put an object in the touch active area, touch HID reports will be send to host. For more information on USB HID Digitizer mode, refer to USB HID Transport (see page 38). 3.4.3 USB HID Raw Mode In USB HID Raw Mode, communication with a Touch Sensor is performed by sending and receiving messages as reports defined by the USB HID standard. To start communicating, perform the following: 1. When the sensor has enumerated, start communicating as defined in USB HID Transport (see page 38). The messages are encoded with ASN.1.Refer to Presentation Layer (ASN.1) (see page 50). 2. The Touch Sensor starts sending touch notifications once it is initialized. For initialization procedures, refer to Initializing Sensors (see page 33). 3.4.4 I2C Transport To start communicating, perform the following: 1. Send or read data over the I2C bus. Refer to I2C Transport (see page 35). The messages are encoded with ASN. 1. Refer to Presentation Layer (ASN.1) (see page 50). 2. The sensor starts sending touch notifications once it is initialized. For initialization procedures, refer to Initializing Sensors (see page 33). 3.4.5 SDK To start communicating, follow the Getting Started instructions in the separate SDK documentation.  2 https://support.neonode.com/docs/display/Downloads https://support.neonode.com  17 zForce AIR™ Touch Sensor User's Guide Multi-Touch Functionality 4 Multi-Touch Functionality zForce AIR Touch Sensor determine an object's position by signals derived from emitter-receiver pairs and have the capacity to detect and track several objects at the same time. Both the HW and the SW have been optimized in order to support standard touch gestures like, pinch-to-zoom, rotate, swipe and tap. However, some combinations of two or more objects might need special consideration. 4.1 Shadows An object directly behind another object cannot be illuminated.  In the figure above, object A will not be detected since illumination is blocked by object B. The correct receiver must have a clear field of view. Object B is in a region covered only by left looking receivers. Object B will not be detected because its field of view is blocked by object D. Object C may be seen by both left and right looking receivers. Although the right looking field of view is blocked by object D, object C is detected by the left looking receiver. Object D is detected by both left and right looking receivers. 4.1.1 Shadow Trick Note that in most cases, user experience is not affected by the shadow situations mentioned above. This is because of a functionality implemented in the Touch Sensor firmware called "shadow trick", which e.g. generates a smooth "rotate" feeling despite one touch object being shadowed during the rotate gesture . A previously detected object that can no longer be detected is still reported as present if: The object was last seen close to a location where it could be shadowed by another object. The potentially shadowing object is still detected and hasn't moved away from a shadowing location. The shadow trick make multi-touch gestures such as "rotate" and "pinch-to-zoom" work better.  https://support.neonode.com  18 zForce AIR™ Touch Sensor User's Guide Multi-Touch Functionality 4.2 Adjacent Objects • In order to recognize two objects close to each other (A and B), a separation must allow at least one emitterreceiver channel (~10 mm) to pass freely between them. Otherwise, the two objects will be reported as one large object. 4.3 More Than Two Objects When more than two objects are being tracked the likelihood that an object ends up being in the shadow of another object increases. Therefore, it is only recommended to enable more than two tracked objects if, for example: • it is not vital to track all detected objects 100% in all possible combinations and locations at all time.  • When all objects are likely to be detected by the sensor, for example when it is expected that all objects will be placed along a line that is parallel to the sensor, as in the example below. https://support.neonode.com  19 zForce AIR™ Touch Sensor User's Guide Mechanical Integration 5 Mechanical Integration zForce AIR Touch Sensor can be used for different purposes, such as touch on a surface or motion in mid-air. Assembly requirements differ depending on what purpose the Touch Sensor fulfills. In addition, different industries have different standards and demands to fulfill. Mid-air detection applications generally require lower mounting tolerances. 5.1 Means of Integration zForce AIR Touch Sensor comes in two types: one is designed to be integrated horizontally and the other vertically. This allows different types of assembly possibilities and better adaptation of the available space in the host system. The two sensor designs are built on the same concept, but use two different front light pipes. One light path is unaffected; the other bent 90°.   The front optical surface is not allowed to be blocked by the host system. In x direction the entire surface is used by the sensors optics. 5.1.1 Horizontal Integration Light is sent straight out and enables an active area in front of the module (in the same plane).   When integrating zForce AIR Touch Sensor into a host system make sure not to interfere with the light path. For horizontal integration, the opening for the sensors light path must be minimum 1.4 mm. If the host system have large tolerances, opening must be adjusted to always be minimum 1.4 mm.     https://support.neonode.com  20 zForce AIR™ Touch Sensor User's Guide Mechanical Integration 5.1.2 Vertical Integration Light is bent 90 degrees within the Touch Sensor. This allows the sensor to be assembled vertically but still have an active area in the horizontal plane. To make sure not to interfere with the sensor light path, opening must be minimum 1.6 mm. If host system have large tolerances, opening must be adjusted to always be minimum 1.6 mm. Also note that it is not allowed to mount, glue or in any other way affect the sensors optical surfaces since it will affect the performance. This applies to both the sensors visible optical surface and also the built-in optical surface A (mirror surface). 5.1.3 Options for Guiding and Fastening • Double adhesive tape – for smaller sizes this can be used alone to hold the zForce AIR Touch Sensor. The host system geometry needs to provide a flat supporting surface. • Snaps – Host system geometry provides some sort of snap features holding the zForce AIR Touch Sensor in place. These must be developed for each case to fit the host System cover and the surrounding. • Sandwiched – the zForce AIR Touch Sensor is mounted by pressing the Touch Sensor between host system exterior cover and display. A structure (ribs, foam gasket or adhesive) is needed to make sure the Touch Sensor cannot move. https://support.neonode.com  21 zForce AIR™ Touch Sensor User's Guide Mechanical Integration The zForce AIR Touch Sensor needs to be protected from outer pressure and forces that can bend the sensor and by that change the direction of the sensor light. The most common cause of bending is when a Touch Sensor is mounted on a non-flat surface, so the host system supporting structure needs to be flat. 5.1.4 External Window An external window is something placed between the sensor and the desired touch active area, usually in form of a plastic or glass “window”. It is of high importance for the function that these surfaces fulfill the optical demands stated in Optical Requirements on External Window (see page 71). It is important to know that each window the light passes through will reduce the sensors received signal levels, even though the requirements are fulfilled, which in some applications might reduce the maximum detection range. 5.1.5 External Reflective Surface An external reflective surface is a surface located outside the active area, but close enough to be reached by the IR light emitted by the sensor. Depending on the angle and the reflectance of the surface, reflected light might enter the sensor and interfere with touch object detection. If the external reflective surface is close to the touch active area, it is recommended to make sure it has a low reflectance in the direction back towards the sensor. Touch Active Area 5.2 Touch Applications The sections below describe integration aspects specific for touch applications and do not concern mid-air applications. 5.2.1 Touch Accuracy Mechanical integration of zForce AIR Touch Sensor and assembly tolerances has a direct impact on touch accuracy. For this reason relaxed assembly tolerances might in some applications have an impact on the perceived touch performance. The best user experience is achieved when the projected touch Active Area from the zForce AIR Touch Sensor perfectly overlaps the intended touch sensitive area on the host device, for example, the active area on a display. Touch active area of host system and zForce AIR Touch Sensor needs to be well aligned. Translational tolerances in x and y directions and rotational tolerances will affect accuracy. See Translational Tolerances (see page 23) (x and y direction) and Rotational Tolerances (see page 23) (angle "b"). https://support.neonode.com  22 zForce AIR™ Touch Sensor User's Guide Mechanical Integration 5.2.2 Hovering Touches Hovering touch means that the Touch Sensor reports a touch event before the object reaches the surface. The basic principle of the Touch Sensor is that light is sent above the surface. To provide a good user experience the Touch Sensor software adjusts the signal and reports a touch first when the object reaches the surface. Hovering touches is also direct linked to how the zForce AIR Touch Sensor is integrated in the host system. It’s important that the mounting surface has the correct angle compared to the intended touch surface. Twisting and tilting of zForce AIR Touch Sensor should always be avoided. Relaxed tolerances can lead to missed touches and increased hovering. See Translational Tolerances (see page 23) (z direction) and Rotational Tolerances (see page 23) (angle "a"). Furthermore, host system active area surface need to be flat or slightly concave. A convex surface can give false touches. 5.2.3 Assembly Tolerances Translational Tolerances Direction Recommended Tolerances for Touch Applications x-direction ±0.5 mm y-direction ±0.5 mm z-direction 0 mm to +0.5 mm Translational tolerances affects the overlap between the display active area and the touch active area. For example, if the Touch Sensor is translated 0.5 mm in x-direction there will be a systematic touch offset of 0.5 mm for the complete sensor in x-direction. A 0 mm translation in z-direction means that the host system active area surface is positioned exactly at the edge of the light path. A positive translation means that zForce AIR Touch Sensor, and therefore the light path, is translated up from the host system active area surface. This will not affect the touch accuracy in the sensor, but it can affect the perceived touch performance, since it leads to increased hovering. A negative translation in z-direction should be avoided since parts of the light will be blocked which leads to no or reduced touch performance. Rotational Tolerances There are two types of rotations that can affect the performance; defined as the angles "a" and "b". Angle "a" affects the floating and angle "b" affects the overlap between the intended active area and the Touch Sensor active area. Both these issues will grow with larger display sizes. The angles are exaggerated in the pictures to better illustrate the problem. Angle "a" The angle "a" is defined as shown in the images below. https://support.neonode.com  23 zForce AIR™ Touch Sensor User's Guide Mechanical Integration The example below illstrates the problem increasing with larger active areas. Angle "b" The angle "b" is defined as shown in the image below. How sensitive zForce AIR Touch Sensor is for assembly rotations is directly linked to the size. At any given angle b, the touch AA will be tilted twice as much at 200 mm compared to at 100 mm. https://support.neonode.com  24 zForce AIR™ Touch Sensor User's Guide https://support.neonode.com  Mechanical Integration 25 zForce AIR™ Touch Sensor User's Guide Electrical Integration 6 Electrical Integration  Electrostatic Sensitive Device! To prevent equipment damage, use proper grounding techniques. 6.1 Electrical Block Diagram 6.2 Physical Connector The Touch Sensor has 8 contact pads and a PCB outline that matches that of a standard 0.3-0.33 mm thick FFC/FPC with 1 mm pitch and top mounted connectors: The contact pads are placed on the backside of the Touch Sensor PCBA. List of supported FFC connectors: Supplier Part number Molex3 2005290080 Omron Electronic Components4 XF3M(1)-0815-1B 3 http://www.molex.com/molex/home 4 https://www.components.omron.com/ https://support.neonode.com  26 zForce AIR™ Touch Sensor User's Guide Electrical Integration Wurth Electronics Inc5. 686108148922 Almita Connectors6 BL124H-8R-TAND 6.3 Pin-Out Function Pin name Pin No Directi on Description Comment Power ground GND 1 - Ground Reset N_RST 2 Input Resets sensor to initial state. Active low. A minimum of a 300 ns low pulse is required Data Ready DR 3 Output Indicates that sensor has data to send Push/pull output. Only used in I2C mode. I2C Data I2C_DAT A 4 I/O I2C data line Requires resistor external pull-up I2C Clock I2C_CLK 5 Input I2C clock line Requires resistor external pull-up USB DM USB D- 6 I/O USB DM line USB 2.0 Compliant USB DP USB D+ 7 I/O USB DP line USB 2.0 Compliant 5 http://www.digikey.com/en/supplier-centers/w/wurth-electronics 6 http://www.almita-connectors.com/ https://support.neonode.com  27 zForce AIR™ Touch Sensor User's Guide Power supply +5V 8 Electrical Integration - +5V power supply USB 2.0 Compliant Note: All pins use 3.3V voltage level and have 5V tolerance. 6.4 Interface Configuration The zForce AIR Touch Sensor provides two interfaces for communication with the host system, I2C and USB HIDdevice. User can choose to connect one of them, or both. The typical Touch Sensor connection to a host system is shown in the diagram below. 6.4.1 USB Connection The zForce AIR Touch Sensor provides a USB full-speed device interface through its 8-pin connector. In this connection, PIN 1, 6, 7, 8 ( GND, USB D-, USB D+, VBUS  ) are used. After connecting the sensor to the host system, it could be enumerated as a normal USB HID-device and act as a digitizer for a touch screen. In this connection, only the default touch active area size could be used. Please refer to Product Variants (see page 6) for the actual values. In this case, it is recommended to use two 1kΩ pull-up resistors to tie up I2C_DATA and I2C_CLK pins to VBUS or 3.3V power supply to avoid noise issue on I2C interface, and leave other pins as not connected. PIN 2 ( N_RST ) could be used to reset or enable/disable the sensor. USB Characteristics The USB interface meets the requirements of USB specifictions 2.0: https://support.neonode.com  28 zForce AIR™ Touch Sensor User's Guide Symbol Electrical Integration Parameter Input   levels Conditions Min Typ Max Unit - - V      VDI Diff.   Input sensitivity 0.2 VCM Diff.   common mode range 0.8 2.5 VSE Single   ended receiver threshold 1.3 2 VOL Output   level low 1.5kΩ to VDD - - 0.3 VOH Output   level high 15kΩ to VSS 2.8 - 3.6 RPD D+/D- VIN=VDD 17 21 24 RPU D+/D- VIN=VSS 1.5 1.8 2.1 Output   levels kΩ   USB full speed timings: definition of data signal rise and fall time. Driver characteristcs Symbol Parameter Conditions Min Max tr Rise time CL = 50pF 4 20 tf Fall time CL = 50pF 4 20 trfm Rise/fall time matching tr/tf 90 110 VCRS Output signal crossover 1.3 2 https://support.neonode.com  29 zForce AIR™ Touch Sensor User's Guide Electrical Integration 6.4.2 I2C Connection The zForce AIR Touch Sensor provides an I2C interface through its 8-pin connector. The interface runs in fast mode, which means the speed is 400kbps. With this interface, more advanced configuration could be performed. PIN 1, 3, 4, 5, 8 ( GND, DR, I2C_DATA, I2C_CLK, VBUS ) are used for this connection. It is recommended to use two 1kΩ pull-up resistors to tie up I2C_DATA and I2C_CLK pins to VBUS or 3.3V power supply to perform proper I2C communication. If USB connection is not used in parallel, PIN 6, 7 ( USB D-, USB D+ ) could be left unconnected. After the Touch Sensor is powered on, it will act as a slave device on a I2C bus. For further information about what commands could be send or receive through this interface, please refer to I2C Transport (see page 35). I2C Characteristics The I2C interface meets the requirements of the standard I2C communication protocol with the following restrictions: SDA and SCL are mapped to I/O pins that are not “true” open-drain. When configured as open-drain, the PMOS connected between the I/O pin and VDD is disabled, but is still present. The I2C characteristics are described in below. Symbol Parameter Min Max Unit tw(SCLL)  SCL clock low time 4.7 - us tw(SCLH)  SCL clock high time 4.0 - tsu(SDA)  SDA setup time 250 - th(SDA)  SDA data hold time 0 - tr(SDA) SDA and SCL rise time - 1000 ns tr(SCL) tf(SDA) SDA and SCL fall time 300 tf(SCL) th(STA)  Start condition hold time 4.0 - tsu(STA)  Repeated Start condition setup time 4.7 - tsu(STO)  Stop condition setup time 4.0 - tw(STO:STA)  Stop to Start condition time (bus free 4.7 - https://support.neonode.com  us 30 zForce AIR™ Touch Sensor User's Guide Electrical Integration tSP Pulse width of the spikes that are   suppressed by the analog filter 0 50 ns Cload Capacitive load for each bus line - 400 pF V IL Input low level voltage 0.8 V V IH Input high level voltage V OL Output low level voltage V OH Output high level voltage 2.3 V 0.4 2.9 V V   PIN 3 ( DR ) Characteristics PIN 3 is used as a 'Dataready' signal output. This signal is only used in I2C communication. Because the sensor can only act as an I2C slave, this pin is needed to notify host to read out any data in it output buffer. • This pin will be set to High (‘1’) when there is data in buffer to be sent from sensor. • This pin will be reset to Low (‘0’) when there is no data in buffer to be sent from sensor. This pin could be used as an interrupt input or be repeatedly read by host. When this pin is set to high, the FW will keep waiting for the host to read data from I2C bus. When the ‘Read’ transaction finished, this DR will be reset automatically by the zForce AIR Touch Sensor. The figure below shows the timing behavior of a typical I2C transaction. https://support.neonode.com  31 zForce AIR™ Touch Sensor User's Guide Electrical Integration I2C Reading Sequence See I2C Transport (see page 35). 6.5 Power On and Boot Sequence Power on timing latency are listed in the table below. Name Min Typ. Max Unit Comment t1 - 15 20 ms Delay time from power on to NRST to high voltage. t2 - 60 70 ms Delay time from power on to USB pins voltage ready. t3 - 170 - ms Delay time from USB init ready to sending/receiving data. t4 5 7 10 ms Delay time from power on to I2C pins voltage ready. t5 65 70 80 ms Delay time from I2C pins voltage ready to triggering boot complete packet request. The power on sequence is shown in the figure below. https://support.neonode.com  32 zForce AIR™ Touch Sensor User's Guide Software Integration 7 Software Integration 7.1 Software Integration Overview 7.1.1 Communication Protocol zForce AIR Touch Sensors can communicate with a host system through USB HID or I2C transport. The content of the communication (presentation layer) is encoded in ASN.1 (except for in HID Touch Digitizer mode). Read more under zForce® Communication Protocol (see page 34). 7.1.2 zForce SDK The zForce Software Development Kit (SDK) is a function library that uses the communication protocol and enables communication with a sensor without considering any ASN.1 encoded data. Read more under the separate SDK documentation. 7.2 Initializing Sensors The following are procedures to initialize a sensor for USB HID Raw mode and I2C respectively. An initialization procedure is not required when using USB HID Touch Digitizer mode. 7.2.1 USB HID Raw Mode Do the following procedure to initialize a sensor over USB HID Raw mode. 1. Power on the sensor. 2. Wait for HID enumeration. This signals the sensor is now booted. 3. Set the sensor to the correct Operation Mode by sending an OperationMode command to Feature Report 1. The data to send is: EE 12 40 02 02 00 67 0C 80 01 FF 81 01 00 82 01 00 83 01 00 This will put the sensor in Detection Mode (which will produce touch notifications). 4. Wait for the sensor to signal that there is data to read. This comes as an Input Report 2. 5. Read the data from Feature Report 2. The data should be: EF 12 40 02 02 00 67 0C 80 01 FF 81 01 00 82 01 00 83 01 00 This means the mode setting has succeeded. The initialization is now complete. After the initialization, the sensor is enabled by default and will start sending touch notifications. To disable notifications, a Disable request must be sent. Refer to ASN.1 PDU Examples (see page 61) for examples of requests, responses and notifications. How to communicate with the sensor is described in USB HID Transport (see page 38). 7.2.2 I2C Use the following procedure to initialize the sensor over I2C. https://support.neonode.com  33 zForce AIR™ Touch Sensor User's Guide Software Integration 1. Power on the sensor. 2. Wait for sensor to assert Data Ready pin (DR). 3. Initiate 2 byte I2C read operation. Payload of this read should be EE XX where XX is the amount of bytes to read in a second I2C read operation. 4. Read XX amount of bytes (number of bytes to read is indicated by second byte of first I2C Read Operation). Now read a message called BootComplete. The message should be F0 11 40 02 00 00 63 0B 80 01 YY 81 02 03 YY 82 02 00 YY where YY is usually "00" but can have another value. This signals the sensor is now booted. 5. To enable the sensor to start sending touch notifications, do the following: a. Sending an Enable command: EE 09 40 02 02 00 65 03 81 01 00 b. Read the response. The response should be: EF 09 40 02 02 00 65 03 81 01 00 The initialization is now complete. When DR is asserted the sensor will send a touch notification or a new BootComplete. A BootComplete indicates that the sensor has restarted for some reason; Enable must then be set again. For more details, refer to I2C Transport (see page 35). 7.3 zForce® Communication Protocol 7.3.1 Communication Protocol Overview Introduction Neonode sensors communicate through a transport interface with ASN.1 encoded payload, with the exception of the HID Touch Digitizer mode where the payload follows the HID standard. Transport Layer Two transport interfaces are supported: USB and I2C. I2C The sensor's I2C implementation has a certain byte sequence and a signaling system to ensure stability. The sensor takes the role of an I2C slave and has the address 0x50. For more information, refer to I2C Transport (see page 35). USB HID The sensor has two USB implementations, both over HID: https://support.neonode.com  34 zForce AIR™ Touch Sensor User's Guide Software Integration 1. HID Touch Digitizer. The sensor can be used as a standard HID Touch Digitizer to report touch data to the OS. 2. HID raw. This implementation uses HID Get and Set Feature Reports as a pipe to read and write. For more information, refer to USB HID Transport (see page 38).  Presentation Layer The zForce Communication Protocol is using ASN.1 encoded data to communicate with the host. ASN.1 stands for Abstract Syntax Notation One and provides a dynamic and verbose way of describing the data. For more information, refer to Presentation Layer (ASN.1) (see page 50). 7.3.2 Transport Layer I2C Transport Sensor Address The Slave I2C address of the sensor is 0x50 (7-bit).  When sending the 7-bit address, still 8 bits are used. The extra bit is used to inform the slave if the master is writing to it or reading from it. If the bit is 0 the master is writing to the slave. If the bit is 1 the master is reading from the slave. The 7 bit address is placed in the upper 7 bits of the byte and the Read/Write (R/W) bit is in the LSB (Least Significant Bit). The resulting address bytes are 0xA1 (Read) and  0xA0 (Write). Reading Sequence The sensor does not communicate using registers / memory accesses, so the STM32 documentation is not applicable. To maximize performance and minimize the load on the I2C bus, the host is expected to read data in a certain sequence. This ensures a stable and reliable communication. The I2C read sequence is specified below. 1. Read the first 2 bytes: FrameStart and DataSize (number of bytes in the payload) https://support.neonode.com  35 zForce AIR™ Touch Sensor User's Guide Software Integration 2. Read the remaining bytes: Payload (specified by DataSize) Syntax The I2C Transport Protocol is very simple and identical in both directions (Read and Write). • Byte 1: FrameStart (A synchronization byte). • Byte 2: DataSize (Contains the size of the data that will be transmitted. Please note that the DataSize >= 1. The reason being that :even if the Command Data size is zero, one byte will be transmitted containing the CommandID). • Bytes 3 - : Payload encoded in ASN.1.  All bytes in this section are written in hexadecimal form, if not indicated otherwise. The first two bytes are: EE XX [payload] Where EE is a constant and XX is number of bytes of ASN.1 payload. So, for example, if the ASN.1 payload is 8 bytes long, the I2C Transport Protocol is: EE 08 [payload] If the payload is 25 bytes long the I2C Transport Protocol is: EE 19 [payload] After the first two bytes, the ASN.1 encoded payload is added. Sending Data Host initiates an I2C Write operation for I2C 7-bit Address 0x50 and writes the full payload including I2C Transport Protocol bytes.  https://support.neonode.com  36 zForce AIR™ Touch Sensor User's Guide Software Integration  If DR (Data Ready) is asserted (that is, it is signaling to the host that the host should initiate a Read operation), it is NOT permitted to initiate an I2C Write Operation. Always wait for the corresponding response from one command before sending another command. Note that not all commands have a response command. If there is no corresponding response command, the host is free to issue another command. Examples The following assume DR is NOT asserted. To send a Request, and the first byte of the ASN.1 payload is "EE". Do not confuse this with the EE of the I2C Protocol, even though they are the same they have completely different meaning. EE XX EE [rest of payload] Example: Sending an ENABLE message to the sensor: EE 0B EE 09 40 02 02 00 65 03 81 01 00 The first two bytes (EE 0B) is the I2C Transport Protocol and the rest is the ASN.1 Protocol. Receiving Data The sensor triggers the DataReady signal when there is data to send. The host processor then triggers an I2C read to read the data. 1. The sensor asserts DR. 2. Host initiates a 2 byte I2C Read operation for I2C 7-bit Address 0x50. 3. The sensor fills in the 2 Bytes. These two bytes are (as described above) EE XX where XX is the length of the following ASN.1 Payload. 4. Host initiates an I2C Read operation for I2C Address and reads XX bytes (as indicated by the second byte of the I2C Transport Protocol). 5. The sensor deasserts DR. Examples The data received from the sensor will have the first ASN.1 payload byte be either EF or F0. If the sensor responds to a request using a Response. The first byte of the ASN.1 payload is the "EF", making the whole received message, including the I2C transport protocol: EE XX EF [rest of payload] https://support.neonode.com  37 zForce AIR™ Touch Sensor User's Guide Software Integration If a sensor sends something other than a Response, it is called a Notification. The first byte of the ASN.1 payload is then "F0". EE XX F0 [rest of payload] BootComplete When the sensor has finished booting, the command BootComplete is put into the send queue. The DataReady signal is triggered and the host needs to read the data to acknowledge that the sensor is ready to operate. If the sensor powers on before the host system does, the host system needs to check if the DataReady signal is active, in which case it needs to read the data.  Do not send any commands to the sensor before BootComplete has been read. Before BootComplete is put into the send queue, the sensor is configuring hardware such as the I2C module, and therefore it is not possible to communicate with the sensor until BootComplete has been read. USB HID Transport When connected via USB, the sensor communicates in Full Speed (12 Mbit/s) in two modes: Raw HID mode and HID Touch Digitizer mode. HID Touch Digitizer mode is initiated automatically as soon as the sensor is plugged in. When using Raw HID mode, the sensor must be initiated and enabled to start receiving notifications. Raw HID Mode This mode uses a mix of two HID Feature Reports and an HID Input Report to communicate with the host. • Send data to the sensor by writing to Feature Report 1.  • Input Report 2 indicates that there is data to read • Read data from the sensor by reading from Feature Report 2. Refer to ASN.1 PDU Examples7 for examples of requests, responses and notifications. HID Touch Digitizer Mode The sensor acts as a HID Input device and communicates directly with the OS. HID Report Descriptor Item Data Usage Page (Digitizer) 05 0D Usage (Touch Screen) 09 04 Collection (Application) A1 01 7 http://confluence.neonode.local/display/ZAMCD/.ASN.1+PDU+Examples+v1.0 https://support.neonode.com  38 zForce AIR™ Touch Sensor User's Guide Software Integration     Report Id (4) 85 04     Usage (Contact count maximum) 09 55     Logical minimum (0) 15 00     Logical maximum (255) 25 FF     Report Size (8) 75 08     Report Count (1) 95 01     Feature (Data,Value,Absolute,Non-volatile,Bit Field) B1 02     Report Id (3) 85 03     Usage (Contact count) 09 54     Input (Data,Value,Absolute,Bit Field) 81 02     Usage (Scan Time) 09 56     Logical maximum (65 535) 27 FF FF 00 00     Report Size (16) 75 10     Unit Exponent (12) 55 0C     Unit (SI Linear: Time [s]) 66 01 10     Input (Data,Value,Absolute,Bit Field) 81 02     Usage (Finger) 09 22     Collection (Logical) A1 02         Usage (Tip Switch) 09 42         Logical maximum (1) 25 01         Report Size (1) 75 01         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Contact identifier) 09 51         Logical maximum (127) 25 7F         Report Size (7) 75 07 https://support.neonode.com  39 zForce AIR™ Touch Sensor User's Guide Software Integration         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Generic Desktop) 05 01         Usage (X) 09 30         Logical maximum (65 535) 27 FF FF 00 00         Report Size (16) 75 10         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Y) 09 31         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Digitizer) 05 0D         Unit Exponent (14) 55 0E         Unit (SI Linear: Distance [cm]) 65 11         Usage (Width) 09 48         Usage (Height) 09 49         Report Count (2) 95 02         Input (Data,Value,Absolute,Bit Field) 81 02     End Collection C0     Usage (Finger) 09 22     Collection (Logical) A1 02         Usage (Tip Switch) 09 42         Logical maximum (1) 25 01         Report Size (1) 75 01         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Contact identifier) 09 51 https://support.neonode.com  40 zForce AIR™ Touch Sensor User's Guide Software Integration         Logical maximum (127) 25 7F         Report Size (7) 75 07         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Generic Desktop) 05 01         Usage (X) 09 30         Logical maximum (65 535) 27 FF FF 00 00         Report Size (16) 75 10         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Y) 09 31         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Digitizer) 05 0D         Unit Exponent (14) 55 0E         Unit (SI Linear: Distance [cm]) 65 11         Usage (Width) 09 48         Usage (Height) 09 49         Report Count (2) 95 02         Input (Data,Value,Absolute,Bit Field) 81 02     End Collection C0      Usage (Finger) 09 22     Collection (Logical) A1 02         Usage (Tip Switch) 09 42         Logical maximum (1) 25 01         Report Size (1) 75 01         Report Count (1) 95 01 https://support.neonode.com  41 zForce AIR™ Touch Sensor User's Guide Software Integration         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Contact identifier) 09 51         Logical maximum (127) 25 7F         Report Size (7) 75 07         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Generic Desktop) 05 01         Usage (X) 09 30         Logical maximum (65 535) 27 FF FF 00 00         Report Size (16) 75 10         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Y) 09 31         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Digitizer) 05 0D         Unit Exponent (14) 55 0E         Unit (SI Linear: Distance [cm]) 65 11         Usage (Width) 09 48         Usage (Height) 09 49         Report Count (2) 95 02         Input (Data,Value,Absolute,Bit Field) 81 02     End Collection C0      Usage (Finger) 09 22     Collection (Logical) A1 02         Usage (Tip Switch) 09 42         Logical maximum (1) 25 01         Report Size (1) 75 01 https://support.neonode.com  42 zForce AIR™ Touch Sensor User's Guide Software Integration         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Contact identifier) 09 51         Logical maximum (127) 25 7F         Report Size (7) 75 07         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Generic Desktop) 05 01         Usage (X) 09 30         Logical maximum (65 535) 27 FF FF 00 00         Report Size (16) 75 10         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Y) 09 31         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Digitizer) 05 0D         Unit Exponent (14) 55 0E         Unit (SI Linear: Distance [cm]) 65 11         Usage (Width) 09 48         Usage (Height) 09 49         Report Count (2) 95 02         Input (Data,Value,Absolute,Bit Field) 81 02     End Collection C0      Usage (Finger) 09 22     Collection (Logical) A1 02         Usage (Tip Switch) 09 42         Logical maximum (1) 25 01 https://support.neonode.com  43 zForce AIR™ Touch Sensor User's Guide Software Integration         Report Size (1) 75 01         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Contact identifier) 09 51         Logical maximum (127) 25 7F         Report Size (7) 75 07         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Generic Desktop) 05 01         Usage (X) 09 30         Logical maximum (65 535) 27 FF FF 00 00         Report Size (16) 75 10         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Y) 09 31         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Digitizer) 05 0D         Unit Exponent (14) 55 0E         Unit (SI Linear: Distance [cm]) 65 11         Usage (Width) 09 48         Usage (Height) 09 49         Report Count (2) 95 02         Input (Data,Value,Absolute,Bit Field) 81 02     End Collection C0      Usage (Finger) 09 22     Collection (Logical) A1 02         Usage (Tip Switch) 09 42 https://support.neonode.com  44 zForce AIR™ Touch Sensor User's Guide Software Integration         Logical maximum (1) 25 01         Report Size (1) 75 01         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Contact identifier) 09 51         Logical maximum (127) 25 7F         Report Size (7) 75 07         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Generic Desktop) 05 01         Usage (X) 09 30         Logical maximum (65 535) 27 FF FF 00 00         Report Size (16) 75 10         Report Count (1) 95 01         Input (Data,Value,Absolute,Bit Field) 81 02         Usage (Y) 09 31         Input (Data,Value,Absolute,Bit Field) 81 02         Usage Page (Digitizer) 05 0D         Unit Exponent (14) 55 0E         Unit (SI Linear: Distance [cm]) 65 11         Usage (Width) 09 48         Usage (Height) 09 49         Report Count (2) 95 02         Input (Data,Value,Absolute,Bit Field) 81 02     End Collection C0  End Collection C0  https://support.neonode.com  45 zForce AIR™ Touch Sensor User's Guide Software Integration Usage Page (Vendor-defined 0xFF00) 06 00 FF Usage (Vendor-defined 0x0001) 09 01 Collection (Application) A1 01     Report Id (1) 85 01     Usage (Vendor-defined 0x0001) 09 01     Report Size (8) 75 08     Report Count (1) 95 01     Logical minimum (0) 15 00     Logical maximum (255) 25 FF     Feature (Data,Value,Absolute,Non-volatile,Bit Field) B1 02     Usage (Vendor-defined 0x0002) 09 02     Report Count (64) 95 40     Feature (Data,Value,Absolute,Volatile,Buffered Bytes) B2 82 01     Report Id (2) 85 02     Usage (Vendor-defined 0x0001) 09 01     Report Count (1) 95 01     Feature (Data,Value,Absolute,Non-volatile,Bit Field) B1 02     Usage (Vendor-defined 0x0002) 09 02     Report Count (64) 95 40     Feature (Data,Value,Absolute,Volatile,Buffered Bytes) B2 82 01     Usage (Vendor-defined 0x0003) 09 03     Report Size (1) 75 01     Logical maximum (1) 25 01     Report Count (1) 95 01     Input (Data,Value,Absolute,Bit Field) 81 02     Report Size (7) 75 07 https://support.neonode.com  46 zForce AIR™ Touch Sensor User's Guide Software Integration     Input (Constant,Array,Absolute,Bit Field) 81 01     Report Size (8) 75 08     Report Id (128) 85 80     Usage (Vendor-defined 0x0001) 09 01     Feature (Constant,Value,Absolute,Non-volatile,Bit Field) B1 03     Report Id (130) 85 82     Usage (Vendor-defined 0x0001) 09 01     Feature (Constant,Value,Absolute,Non-volatile,Bit Field) B1 03 End Collection C0  Parsed reports by Report ID Input Report 2 Bit offset Bit count Description 0 1 Vendor-defined 0x0003 1 7 (Not used) Input Report 3 Bit offset Bit count Description 0 8 Contact count 8 16 Scan Time 24 1 Tip Switch 25 7 Contact identifier 32 16 X 48 16 Y 64 16 Width 80 16 Height 96 1 Tip Switch https://support.neonode.com  47 zForce AIR™ Touch Sensor User's Guide 97 7 Contact identifier 104 16 X 120 16 Y 136 16 Width 152 16 Height 168 1 Tip Switch 169 7 Contact identifier 176 16 X 192 16 Y 208 16 Width 224 16 Height 240 1 Tip Switch 241 7 Contact identifier 248 16 X 264 16 Y 280 16 Width 296 16 Height 312 1 Tip Switch 313 7 Contact identifier 320 16 X 336 16 Y 352 16 Width 368 16 Height 384 1 Tip Switch 385 7 Contact identifier 392 16 X 408 16 Y https://support.neonode.com  Software Integration 48 zForce AIR™ Touch Sensor User's Guide 424 16 Width 440 16 Height Software Integration Feature Report 1 Bit offset Bit count Description 0 8 Vendor-defined 0x0001 8 512 Vendor-defined 0x0002 Feature Report 2 Bit offset Bit count Description 0 8 Vendor-defined 0x0001 8 512 Vendor-defined 0x0002 Feature Report 4 Bit offset Bit count Description 0 8 Contact count maximum Feature Report 128 Bit offset Bit count Description 0 8 Vendor-defined 0x0001 Feature Report 130 Bit offset Bit count Description 0 8 Vendor-defined 0x0001 Known limitations A race condition might occur when calling the functions HidD_GetFeature, HidD_GetManufacturerString, HidD_GetProductString or HidD_GetSerialNumberString simultaneously. A Mutex lock might be needed to only call one of them at the same time, otherwise they could fail randomly. https://support.neonode.com  49 zForce AIR™ Touch Sensor User's Guide Software Integration 7.3.3 Presentation Layer (ASN.1) ASN.1 PDU Description PDU Definition Download the ASN.1 PDU definition file from https://support.neonode.com/docs/display/downloads. Introduction This document describes the host interface to a sensor. The host interface is the means for which an outside device can communicate with the sensor. The communication protocol is using ASN.1 (Abstract Syntax Notation One) which is a standard and a notation that is described in ISO/IEC 8824. Rules in the standard enables representation of data that is agnostic to machine specific implementations. This document is the specification of what corresponds to layers 6 and 7 of the OSI model8: • Layer 6: Presentation Layer: Encoding and decoding of application layer messages • Layer 7: Application Layer: Communication by sending messages. Message Specification All communication is done by sending messages in a format specified using ASN.1. The message is either a request, response or notification. The host sends a request to the sensor, and the device responds with a response. The device may send notifications to the host at any time. All messages contain a virtual device address. Virtual devices are functionally isolated from each other, and communicate separately with the host. The virtual device called "Platform" represents the system. The virtual device called "Air" is a touch sensor. A sensor will always contain one platform virtual device and can contain any number of instances of other virtual device types. Abstract Syntax Notation One (ASN.1) ASN.1 is a means and method of abstracting the data definition from the message format being used. The data that is to be transferred is expressed as an object. The object definition then has a set of Encoding Rules applied to produce the actual data format. Among the more common Encoding Rules are Basic Encoding Rules (BER), and its subset Distinguished Encoding Rules (DER), and XML Encoding Rules (XER). The encoding rules are what determines how the data is encoded and decoded, and there are quite a big variance depending on which encoding rules are used. XER produces "fully readable" XML data, whereas BER and DER gives a lot more space preserving binary encoding of the same set of data. References: • ITU-T ASN.1:2008 Publications9 • Layman's Guide to a subset of ASN.1, BER and DER10 • OSS Nokalva's Resource pages11 8 https://en.wikipedia.org/wiki/OSI_model 9 http://www.itu.int/ITU-T/studygroups/com17/languages/ 10 http://luca.ntop.org/Teaching/Appunti/asn1.html 11 http://www.oss.com/resources/resources.html https://support.neonode.com  50 zForce AIR™ Touch Sensor User's Guide Software Integration • ITU-T Introduction to ASN.112 ASN.1 Definitions Defining objects in the ASN.1 syntax is done by defining one or more Protocol Data Unit (PDU) on a top level of a definition file. Any data unit that is defined on top level and is not referenced by any other data unit is considered to be a top level unit. The definitions then part by part describe what this PDU can contain. What can be defined is generally divided into two types of objects; Constructed types and Primitive types. The constructed type contains further definitions defining what the type can contain, whereas the primitive types can be considered as an endpoint, or a leaf node, where they are the types that contains any actual data itself. Examples of constructed types are Sequence, Choice and Set. Examples of primitive types are Integer, Octet String (string of data bytes, binary blob) and IA5String (printable ascii string). All data types (both constructed and primitive) inherit their traits from an already existing type, which may or may not be defined from another existing type. In the extension all types are however based on a set of basic data types, called the Universal types. As such, the encoding rules only need to cover these universal types to be able to encode any definitions, with a little help of hints in the definition. The types of hints given in the definition are identifier numbers and definition categories. In addition to the basic data definitions it is also possible to define cardinality, optionality, extensibility and size as constraints. zForce PDU All messages are instances of a Protocol Data Unit (PDU) defined in the zForce definition file. The top level PDU ProtocolMessage contains a choice of either a request, response or notification child. The request and response are of the same PDU Message, and the notification is of the PDU Notification. The Message PDU contains the deviceAddress and a command. The deviceAddress specifies a virtual device within the sensor, which is the recipient of the request. In the request the command specifies what is being requested. In the response, the command is of the same PDU as in the reponse, but now contains the result or requested information of the request. The Notification PDU contains the deviceAddress and the notificationMessage. Some notifications contain the notificationTimestamp. Encoding Rules When applying a set of Encoding Rules to the ASN.1 definitions, one gets the data format used for the interchange. zForce uses the Distinguised Encoding Rules (DER). In this document, examples will be given with the human readable Generic String Encoding Rules (GSER). Here is one such example: request: { deviceAddress '0200'H, enable { enable NULL } } GSER Notation The examples written down in GSER notation will hopefully be quite easy to read, but some parts are not necessarily obvious. So, as a lead to it here's a list of used notation: 12 http://www.itu.int/en/ITU-T/asn1/Pages/introduction.aspx https://support.neonode.com  51 zForce AIR™ Touch Sensor User's Guide Software Integration Sequences and/or sets (items containing sub items) are shown as curly brackets: { } Values encoded as octet strings are written as hexadecimal octets enclosed within single quotes and suffixed with H: 'FF9900'H Bit strings are also shown as octet strings when the number of bits is a multiple of 8, otherwise each bit is shown as a single 1 or 0, and suffixed with B: '11010101001'B In a choice element, the selected type is denoted by its name followed by a colon: request: Full reference at Generic String Encoding Rules (GSER) for ASN.1 Types13. Tools The tool FFASN1Dump14 can transcode from GSER to DER: ffasn1dump -I gser -O der zforce_pdu_def.asn ProtocolMessage  Currently ffasn1dump does not handle identifiers for Integer values. For this reason, they need to be replaced with numerical values. Application Interface The application interface specifies what requests can be made and what responses and notifications they activate. Messages will be specified using the templates below, and specifying only: • • • • address request command command response notification request request: { deviceAddress , } response response: { deviceAddress , } 13 https://tools.ietf.org/html/rfc3641#page-6 14 http://www.bellard.org/ffasn1/ https://support.neonode.com  52 zForce AIR™ Touch Sensor User's Guide Software Integration notification notification: { deviceAddress , notificationTimestamp } address Octet string with 2 octets; device type and index: ''H device types: • • • • • 0: Platform 1: Core 2: Air 3: Plus 4: Lighting Eg. '0000'H for platform. timestamp Integer representing int16 counting at 32768 Hz. Platform Platform commands relate to generic system information and settings. These are using the platform address: address '0000'H Device Information Get product id and FW version. request command deviceInformation { } command response deviceInformation { platformInformation { platformVersionMajor 7, https://support.neonode.com  53 zForce AIR™ Touch Sensor User's Guide Software Integration platformVersionMinor 0, protocolVersionMajor 1, protocolVersionMinor 5, firmwareVersionMajor 1, firmwareVersionMinor 0, hardwareIdentifier "Demo board", hardwareVersion "R2", asicType nn1002, numberOfAsics 1, mcuUniqueIdentifier '340038000E51333439333633'H, projectReference "DEMO_1.0_REL", platformReference "734cebd", buildTime "16:01:14", buildDate "2016-07-01" } } The fields have the following meaning: • versions: • platform: FW platform version • protocol: communication protocol version • firmware: product FW version • • • • hardware: Product hardware, with configuration and revision asic: Which type of the Neonode optical scanner ASICs is used, and count mcuUniqueIdentifier: Identifier created at chip manufacturing Reference: FW GIT tags or hashes for: • project: product specific. Uniquely identifies FW revision • platform: Uniquely identifies generic firmware base commit • build: Date and time of build in Central European Time. Device Count Enumerate the available virtual devices. request command deviceCount { } command response deviceCount { totalNumberOfDevices 1, airDevices 1 } Device type instances are indexed from zero. This response means that the only virtual device available is Air[0]. https://support.neonode.com  54 zForce AIR™ Touch Sensor User's Guide Software Integration Frequency Change the update frequency of all touch sensors globally. These update frequencies can be set, if enabled in the product: • finger: Activated when objects with characteristics matching regular fingers are detected • stylus: Activated for narrow stylus-like objects • idle: Activated when no objects are detected, in order to minimize power usage. The unit is Hz. request command frequency { finger 30, idle 10 } The response confirms the setting for the frequencies supported on the product: command response frequency { finger 30, idle 10 } In this example, the touch sensor update frequency will be 30 Hz as long as objects were recently detected. When not, the frequency will drop to 10 Hz. Touch Sensor There are a number of different touch sensor products that can co-exist on the same physical device. They have some product-specific commands, but the ones listed here are general. Air will be used as example, which means the device address will be that of the first Air virtual device: address '0200'H Operation Mode Choose what processing should be done on sensor signals, and what diagnostics should be exposed. This example sets it to normal object detection: https://support.neonode.com  55 zForce AIR™ Touch Sensor User's Guide Software Integration request command operationMode { detection TRUE, signals FALSE, ledLevels FALSE, detectionHid FALSE, gestures FALSE } command response operationMode { detection TRUE, signals FALSE, ledLevels FALSE, detectionHid FALSE }  As can be seen gestures is missing in the response. This is valid response, since the device has been built with a subset of the protocol, or an older forward-compatible version. Touch Format Retrieve the binary format of the detected objects.  request command touchFormat { } command response touchFormat { touchDescriptor { id, event, loc-x-byte1, loc-x-byte2, loc-y-byte1, loc-y-byte2, size-x-byte1, size-ybyte1, confidence } } The touchDescriptor is a bit string, where each bit signifies one byte of payload being included in the touchNotification octet strings. A  touchNotification is the concatenation of those bytes. The following table lists all bits. Bits flagged by the example touchDescriptor are marked green. Name Description id Touch Identifier https://support.neonode.com  Comment 56 zForce AIR™ Touch Sensor User's Guide Software Integration event Up/Down/Move 0=Down; 1=Move; 2=Up; 3=Invalid; 4=Ghost loc-x-byte1 X coordinate loc-x-byte2 X expanded for higher precision loc-x-byte3 X expanded for higher precision loc-y-byte1 Y coordinate loc-y-byte2 Y expanded for higher precision loc-y-byte3 Y expanded for higher precision loc-z-byte1 Z coordinate loc-z-byte2 Z expanded for higher precision loc-z-byte3 Z expanded for higher precision size-x-byte1 X size size-x-byte2 X size for higher precision size-x-byte3 X size for higher precision size-y-byte1 Y size size-y-byte2 Y size for higher precision size-y-byte3 Y size for higher precision size-z-byte1 Z size size-z-byte2 Z size for higher precision size-z-byte3 Z size for higher precision orientation Orientation Hand orientation confidence Confidence pressure Pressure Location and size coordinates can be specified with up to 3 bytes. The byte order in decreasing significance - bigendian. For example: • 1 byte: location x = loc-x-byte1 • 2 bytes: location x = (loc-x-byte1
NN AMC 3461 PC01 价格&库存
很抱歉,暂时无法提供与“NN AMC 3461 PC01”相匹配的价格&库存,您可以联系我们找货
NN AMC 3461 PC01
  • 1+1189.839921+153.91263
  • 5+1107.488235+143.25997
  • 10+1076.7990410+139.29015
  • 25+1040.0785625+134.54014
  • 50+1014.9236150+131.28620
库存:233
