MOD-DEV-100 REV 1.12
    NETBURNER
    MOD NETBURNER MOD-DEV
MOD-DEV-100 REV 1.12 数据手册
NBWIFIUG 802.11b/g Wireless Module 100 Version DATASH EET Key Points • Secure data communications with 64/128-bit WEP • Wireless Standards: IEEE 802.11 b/g, 2.4GHz RF band mode PA Features • Compatible with NetBurner MOD5234, MOD5270, MOD5272 and MOD5282 Modules • Modulation: OFDM,DSSS, CCK, DQPSK, DBPSK, 64 QAM, 16 QAM • SPI Interface • Operating range: -10° to 70°C Updated: September 4, 2012 | Page 1 of 4 © 2012 NetBurner Inc. All Rights Reserved. NBWIFIUG Hardware Specifications Wireless Standards • IEEE 802.11 b/g • 2.4GHz RF band mode PA Security 64/128-bit WEP Modulation OFDM, DSSS, CCK, DQPSK, DBPSK, 64 QAM, 16 QAM Interface SPI Power DC Input Voltage: 3.3V @ 160mA Environmental Operating Temperature -10° to 70°C RoHS Compliance The Restriction of Hazardous Substances guidelines ensure that electronics are manufactured with fewer environment harming materials. Agency Approvals UL, C/UL, CE, FCC Compatibality To use the NBWIFIUG-100CR 802.11b/g module, you will need a compatable module development kit: NNDK-MOD5234-KIT, NNDK-MOD5234LC-KIT, NNDK-MOD5270-KIT, NNDK-MOD5270LC-KIT, NNDK-MOD5272-KIT, or NNDK-MOD5282-KIT. The development kit must include a MOD-DEV-100 carrier board revision of 1.12 (or later) or a MOD-DEV-70 carrier development board revision 1.6 (or later). If you have a module development kit with a carrier board revision earlier than 1.12 (MOD-DEV-100) or 1.6 (MOD-DEV-70), you will need to purchase a new development kit. Updated: September 4, 2012 | Page 2 of 4 © 2012 NetBurner Inc. All Rights Reserved. NBWIFIUG Module Pinout and Signal Description The NBWIFIUG-100CR Module has a 10-pin header which enables you to quickly and easily connect to your own carrier board. Table 1 provides descriptions of pin function of the module header. Table 1: Module Header Pinout and Signal Descriptions Pin Silkscreen SPI Signal Module Signal SPI Function 1 2 3 4 5 6 7 8 9 10 GND SD02 SD03 SDCMD GND VDD SDCLK GND SD00 SD01 GND Unused SS MOSI GND VCC SC(L)K GND MISO IRQ GND QSPI_[0:3] QSPI_DOUT GND VCC QSPI_CLK GND QSPI_DIN IRQ[3:7] Ground Slave Select (Chip Select) Master Out / Slave In Ground Supply Voltage 3.3V Clock Ground Master In / Slave Out Interrupt Note: 1. The NBWIFIUG-ADPT-100CR routes IRQ3 and QSPI_1 to be used as interrupt and slave select respectively. Updated: September 4, 2012 | Page 3 of 4 © 2012 NetBurner Inc. All Rights Reserved. NBWIFIUG Part Numbers 802.11b/g Wireless Module Development Kit Part Number: NNDK-NBWIFIUG-KIT Kit includes a NBWIFIUG-100CR module, an adapter board, and an antennae. A compatible NetBurner network development kit is required to use this product. 802.11b/g Wireless Module Part Number: NBWIFIUG-100CR Ordering Information E-mail: sales@netburner.com Online Store: www.Netburner.com Telephone: 1-800-695-6828 Updated: September 4, 2012 | Page 4 of 4 © 2012 NetBurner Inc. All Rights Reserved.
MOD-DEV-100 REV 1.12 价格&库存
很抱歉,暂时无法提供与“MOD-DEV-100 REV 1.12”相匹配的价格&库存,您可以联系我们找货
