PART CODE:
1206Y106Z100JC
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
Q0608- 1206Y106Z100JC
DATE
June 08, 2023
REVISION
A2
DESCRIPITION
Multilayer Ceramic Chip Capacitors 1206 (3216 Metric) Series,
L3.20*W1.60*H1.15mm, Thickness: 1.35mm Max.
Dielectric Y5V, Capacitance 10µF, Tolerance -20/+80%, Rated Voltage 10V,
Operating Temp. Range -25°C ~+85°C
Package in Tape/Reel, 3,000pcs/Reel
RoHS/RoHS III compliant
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
Aillen 1206Y106Z100JC
PART CODE
1206Y106Z100JC
VENDOR APPROVE
Issued/Checked/Approved
DATE: June 08, 2023
CUSTOMER APPROVE
DATE:
6/8/2023
NextGen Components, Inc.
1
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
1206Y106Z100JC
MULTILAYER CERAMIC CHIP CAPACITORS 1206 SERIES
MAIN FEATURE
MLCC consists of a conducting material and electrodes. To manufacture a chip-type SMT and achieve
miniaturization, high density and high efficiency, ceramic condensers are used. MLCC is made by NP0, X7R, X6S,
X5R and Y5V dielectric material and which provides product with high electrical precision, stability and reliability.
MAIN FEATURE
• RoHS III Compliant • Wide Operating Temperature Range -55~+125℃ • High capacitance in given case size
• A wide selection of sizes is available (0201 to 1812) • Capacitor with lead-free termination (pure Tin)
APPLICATION
• General Digital Circuit • Power Supply by pass capacitors • Consumer Electronics • Telecommunication
RFQ
PART CODE GUIDE
Request For Quotation
Code
Name
Key Specification Option
1206
Size
0201 (0603): L0.60*W0.30mm; 0402 (1005): L1.00*W0.50mm
0603 (1608): L1.60*W0.80mm; 0805 (2012): L2.00*W1.25mm
1206 (3216:) L3.20*W1.60mm; 1210 (3225): L3.20*W2.50mm
1812 (4532): L4.50*W3.20mm
Y
106
Dielectric
N: NP0 (C0G); B: X7R; Y: Y5V; W: X5R; S: X6S
Capacitance
Two significant digits followed by number of Zero, The 3rd digit signifies the
multiplying factor, and letter R is decimal point.
6R8: 6.8pF; 8R2: 8.2pF; 226: 22µF; 106: 10µF
Z
Tolerance
A=±0.05pF; B=±0.1pF; C=±0.25pF; D=±0.5pF; F=±1%; G=±2%; J=±5%; K=±10%
M=±20%; Z=-20/+80%
100
Rated Voltage
Two significant digits followed by No. of zeros. “R” is in place of decimal point.
4R0=4 VDC; 6R3=6.3 VDC; 100=10 VDC; 160=16 VDC; 250=25 VDC; 500=50 VDC;
101 =100 VDC
J
Thickness
J: 1.15±0.20mm, See Table 1
C
Package
K: 0.5 Kpcs/Reel; A: 1Kpcs/Reel; B: 2Kpcs/Reel; C: 3Kpcs/Reel; D: 4Kpcs/Reel;
E: 15Kpcs/Reel; I: 10Kpcs/Reel; J: 2.5Kpcs/Reel; F: others
Internal Control
Internal Code: Letter + Number; Blank: N/A;
6/8/2023
2
PART CODE:
1206Y106Z100JC
DIMENSION (Unit: mm)
Image for reference
Table 1
Size
L
W
T (Symbol )
Code
0201
Soldering
MB
Method
0.6±0.09
0.30±0.09
0.3±0.09 (L)
R
0.15+0.1/-0.05
1.00±0.20
0.50±0.20
0.50±0.05 (N); 0.50±0.20 (H)
R
0.25+0.05/-0.10
1.60±0.20
0.80±0.20
0.50±0.20 (H); 0.80±0.10 (S)
R/W
0.40±0.15
0.50±0.20 (H); 0.60±0.10 (A)
H & C: R
0.50±0.20
0.85±0.15 (B); 0.80±0.20 (X)
A, X & B: R/W
(0603)
0402
(1005)
0603
(1608)
0805
2.00±0.20
1.25±0.20
(2012)
1.25±0.20 (C)
1206
3.20±0.30
1.60±0.30
(3216)
0.85±0.15 (B); 0.95±0.10 (I)
B: R/W
0.60±0.20
1.25±0.20 (C); 1.15±0.20 (J)
C, D, I, J & P: R
0.50±0.25
R
0.75±0.25
R
0.75±0.25
1.60±0.20 (D); 1.60+0.30/-0.10 (P)
1210
3.20±0.40
2.50±0.30
(3225)
1.25±0.20 (C); 1.60±0.20 (D);
2.00±0.20 (K); 2.50±0.30 (M)
1812
4.50±0.40
3.20±0.40
(4532)
0.50±0.25*
2.80±0.30 (U)
6/8/2023
3
PART CODE:
1206Y106Z100JC
GENERAL ELECTRONICAL CHARACTERISTICS
Dielectric
NP0
X7R
Size
0201, 0402, 0603, 0805, 1206, 1210, 1812
Capacitance
0.1pF to 0.1µF
100pF to
range*
Table 2
Y5V
X5R
X6S
0.01µF to 100µF
100pF to
0.1µF to
220µF
100µF
47µF
Capacitance
Cap.≦5pF (Note #1):
J (±5%),
M (±20%),
K (±10%),
K (±10%),
Tolerance
A (±0.05pF), B (±0.1pF),
K (±10%),
Z (-20/+80%)
M (±20%)
M (±20%)
C (±0.25pF)
M (±20%)
-25 ~+85°C
-55 ~+85°C
-55~+105°C
+30/-80%
±15%
±22%
5pF0.1µF; 0805/X7R>0.47µF; 1206≧2.2µF; 1210≧10µF;
50V
≦ 2.5%
35V
≦ 3.5%
≦10%
0603≧1µF; 0805≧2.2µF; 1206≧2.2µF; 1210≧10µF
25V
≦ 3.5%
≦5%
0201≧0.01µF; 0805≧1µF; 1210/X7R≧10µF
≦7%
0603≧0.33µF
≦10%
0201≧0.1µF; 0402/X7R≧0.056µF; 0603≧0.47µF; 0805≧2.2µF; 1206≧4.7µF;
1210≧22µF
16V
≦3.5%
≦12.5%
0402≧0.47µF
≦5%
0201≧0.01µF; 0402≧0.033µF; 0603≧0.15µF; 0805≧0.68µF; 1206≧2.2µF;
1210≧4.7µF
≦10%
0201/X7R≧0.022µF; 0402≧ 0.22uF; 0603>0.47µF; 0805≧2.2µF;
1206≧4.7µF; 1210≧22µF;
10V
≦ 5.0%
≦10%
0201≧0.012µF;0402≧0.22µF; 0603≧0.33µF; 0805≧2.2µF;
1206≧2.2µF;1210≧22µF
6.3V
≦ 10%
≦15%
0201≧0.1µF; 0402≧1µF
≦15%
0201≧0.1µF; 0402≧1µF; 0603≧10µF; 0805≧4.7µF; 1206≧47µF
1210 ≧100µF
4V
≦15%
≦20%
0402≧2.2µF
6/8/2023
5
PART CODE:
1206Y106Z100JC
X5R
Table 4
Rated vol.
D.F. ≦
Exception of D.F. ≦
≧100V
≦ 2.5%
≦3%
1206 ≧ 0.47µF
≦ 5%
0603 ≧ 0.068µF; 0805>0.1µF; 1206 ≧ 1µF; 1210 ≧ 2.2µF;
≦10%
0805>0.22µF; 1210 ≧ 3.3µF
≦3%
0201(50V); 0603≧0.047µF; 0805≧0.18µF; 1206≧0.47µF
≦5%
0201≧0.01uF; 1210≧4.7µF
≦10%
0402≧0.012µF; 0603>0.1µF; 0805≧1µF; 1206≧2.2µF;1210≧10µF;
50V
≦ 2.5%
35V
≦ 3.5%
≦10%
25V
≦ 3.5%
≦5%
0201≧0.01µF; 0805≧1µF; 1210/X5R≧10µF
≦7%
0603≧0.33µF
≦10%
0201≧0.1µF; 0402≧0.10µF; 0603≧0.47µF; 0805≧2.2µF; 1206≧4.7µF;
1210/X5R≧10µF;
16V
≦ 3.5%
≦12.5%
0402≧0.47µF
≦5%
1210≧4.7µF
≦10%
0201≧0.1uF; 0402≧ 0.22uF; 0603>0.47µF; 0805≧2.2µF; 1206≧4.7µF;
1210≧22µF
10V
≦ 5.0%
≦10%
0201≧0.012µF; 0402≧0.22µF; 0603≧0.33µF; 0805≧2.2µF; 1206≧2.2µF;
1210≧22µF
6.3V
≦ 10%
≦15%
≦15%
1210 ≧100µF
4V
≦15%
≦20%
0402≧2.2µF
6/8/2023
6
PART CODE:
1206Y106Z100JC
Y5V
Table 5
Rated vol.
D.F. ≦
Exception of D.F. ≦
≧50V
≦5%
≦7%
0603≧0.1µF; 0805≧0.47µF; 1206≧4.7µF
≦12.5%
1210≧6.8µF
35V
≦7%
25V
≦5%
≦7%
0402≧0.047µF; 0603≧0.1µF; 0805≧0.33µF; 1206≧1µF; 1210≧4.7µF
≦9%
0402≧0.068µF; 0603≧0.47µF; 1206≧4.7µF; 1210≧22µF
≦9%
0402≧0.068µF; 0603≧0.68µF
≦12.5%
0402≧0.22µF
≦9%
≦12.5%
0603≧2.2µF; 0805≧3.3µF; 1206≧10µF; 1210≧22µF; 1812≧47µF
10V
≦12.5%
≦20%
0402≧0.47µF
6.3V
≦20%
16V
≦7%
(C0.1µF; 0805≧1µF; 1206≧2.2µF; 1210≧10µF;
50V
≦ 2.5%
35V
≦ 3.5%
≦10%
25V
≦ 3.5%
≦5%
0201≧0.01µF; 0805≧1µF; 1210/X6S≧10µF
≦7%
0603≧0.33µF
≦10%
1210≧22µF;
16V
≦ 3.5%
≦12.5%
0402≧0.47µF
≦5%
1210≧4.7µF
≦10%
1210≧22µF
10V
≦ 5.0%
≦10%
1210≧22µF
6.3V
≦ 10%
≦15%
≦15%
0201≧0.1µF; 0402/X6S≧0.47µF; 0603≧10µF; 0805≧4.7µF; 1206≧47µF
1210 ≧100µF
4V
≦15%
≦20%
0402≧2.2µF
6/8/2023
8
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE - NP0 DIELECTRIC 0201, 0402, 0603 SIZES
Size
0201
Table 7-A
0402
0603
VDC (V)
16
25
50
10
16
25
50
100
10
16
25
50
100
0.1pF (0R1)
L
L
L
H
H
H
H
0.2pF (0R2)
L
L
L
H
H
H
H
0.3pF (0R3)
L
L
L
H
H
H
H
0.4pF (0R4)
L
L
L
H
H
H
H
0.5pF (0R5)
L
L
L
H
H
H
H
H
S
S
S
S
S
0.6pF (0R6)
L
L
L
H
H
H
H
H
S
S
S
S
S
0.7pF (0R7)
L
L
L
H
H
H
H
H
S
S
S
S
S
0.8pF (0R8)
L
L
L
H
H
H
H
H
S
S
S
S
S
0.9pF (0R9)
L
L
L
H
H
H
H
H
S
S
S
S
S
1.0pF (1R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
1.2pF (1R2)
L
L
L
H
H
H
H
H
S
S
S
S
S
1.5pF (1R5)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
H
1.6pF (1R6)
1.8pF (1R8)
L
L
L
H
H
H
H
H
S
S
S
S
S
2.0pF (2R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
2.2pF (2R2)
L
L
L
H
H
H
H
H
S
S
S
S
S
2.7pF (2R7)
L
L
L
H
H
H
H
H
S
S
S
S
S
3.0pF (3R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
3.3pF (3R3)
L
L
L
H
H
H
H
H
S
S
S
S
S
3.9pF (3R9)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
4.0pF (4R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
4.7pF (4R7)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
5.0pF (5R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
5.6pF (5R6)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
6.0pF (6R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
6.8pF (6R8)
L
L
L
H
H
H
H
H
S
S
S
S
S
7.0pF (7R0)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
8.0pF (8R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
8.2pF (8R2)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
9.0pF (9R0)
L
L
L
H
H
H
H
H
S
S
S
S
S
6/8/2023
9
PART CODE:
1206Y106Z100JC
Size
0201
Table 7-B
0402
0603
VDC (V)
16
25
50
10
16
25
50
100
10
16
25
50
100
10pF (100)
L
L
L
H
H
H
H
H
S
S
S
S
S
12pF (120)
L
L
L
H
H
H
H
H
S
S
S
S
S
15pF (150)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
18pF (180)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
22pF (220)
L
L
L
H
H
H
H/N
H
S
S
S
S/B
S
27pF (270)
L
L
L
H
H
H
H
H
S
S
S
S
S
H
30pF (300)
33pF (330)
L
L
L
H
H
H
H
H
S
S
S/B
S/B
S
39pF (390)
L
L
L
H
H
H
H
H
S
S
S
S
S
47pF (470)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
56pF (560)
L
L
L
H
H
H
H
H
S
S
S
S
S
68pF (680)
L
L
L
H
H
H
H
H
S
S
S
S
S
82pF (820)
L
L
L
H
H
H
H
H
S
S
S
S
S
100pF (101)
L
L
L
H
H
H
H/N
H
S
S
S
S/B
S
120pF (121)
L
L
L
H
H
H
H
H
S
S
S
S/B
S
150pF (151)
L
L
L
H
H
H
H
H
S
S
S
S
S
180pF (181)
H
H
H
H
H
S
S
S
S
S
220pF (221)
H
H
H
H
H
S
S
S
S
S
270pF (271)
L
H
H
H
H
S
S
S
S/B
S
330pF (331)
L
H
H
H
H
S
S
S
S/B
S
390pF (391)
L
H
H
H
H
S
S
S
S
S
470pF (471)
L
H
H
H
H
S
S
S
S
S
560pF (561)
L
H
H
H
H
S
S
S
S
S
680pF (681)
H
H
H
H
S
S
S
S
S
820pF (821)
H
H
H
H
S
S
S
S
S
1,000pF (102)
H
H
H
H
S
S
S/B
S
S
1,200pF (122)
X
X
X
X
X
1,500pF (152)
X
X
X
X
X
1,800pF (182)
X
X
X
X
6/8/2023
10
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE - NP0 DIELECTRIC 0603 SIZES
Size
Table 7-C
0603
VDC (V)
10
16
25
50
2,200pF (222)
X
X
X
X/B
2,700pF (272)
X
X
X
X/B
3,300pF (332)
X
X
X
X
3,900pF (392)
X
X
X
X
4,700pF (472)
X
X
X
X
5,600pF (562)
X
X
X
X
6,800pF (682)
X
X
X
X
8,200pF (822)
X
X
X
X
0.010µF (103)
X
X
X
X
CAPACITANCE RANGE - NP0 DIELECTRIC 0805, 1206 SIZES
Size
Table 7-D
0805
1206
VDC (V)
10
16
25
50
100
0.5pF (0R5)
A
A
A
A
A
0.6pF (0R6)
A
A
A
A
A
0.7pF (0R7)
A
A
A
A
A
0.8pF (0R8)
A
A
A
A
A
0.9pF (0R9)
A
A
A
A
A
1.0pF (1R0)
A
A
A
A
A
1.2pF (1R2)
A
A
A
A
A
B
B
B
B
B
1.5pF (1R5)
A
A
A
A
A
B
B
B
B
B
1.8pF (1R8)
A
A
A
A
A
B
B
B
B
B
2.0pF (2R0)
A
A
A
A
A
2.2pF (2R2)
A
A
A
A
A
B
B
B
B
B
2.7pF (2R7)
A
A
A
A
A
B
B
B
B
B
3.0pF (3R0)
A
A
A
A
A
3.3pF (3R3)
A
A
A
A
A
B
B
B
B
B
3.9pF (3R9)
A
A
A
A
A
B
B
B
B
B
4.0pF (4R0)
A
A
A
A
A
6/8/2023
10
16
25
50
100
B
11
PART CODE:
1206Y106Z100JC
Size
Table 7-E
0805
1206
VDC (V)
10
16
25
50
100
10
16
25
50
100
4.7pF (4R7)
A
A
A
A
A
B
B
B
B
B
5.0pF (5R0)
A
A
A
A
A
5.6pF (5R6)
A
A
A
A
A
B
B
B
B
B
6.0pF (6R0)
A
A
A
A
A
6.8pF (6R8)
A
A
A
A
A
B
B
B
B
B
7.0pF (7R0)
A
A
A
A
A
B
B
B
B
B
8.0pF (8R0)
A
A
A
A
A
8.2pF (8R2)
A
A
A
A
A
B
B
B
B
B
9.0pF (9R0)
A
A
A
A
A
10pF (100)
A
A
A
A
A
B
B
B
B
B
12pF (120)
A
A
A
A
A
15pF (150)
A
A
A
A
A
B
B
B
B
B
18pF (180)
A
A
A
A
A
B
B
B
B
B
22pF (220)
A
A
A
A
A
B
B
B
B
B
27pF (270)
A
A
A
A
A
B
B
B
B
B
33pF (330)
A
A
A
A
A
B
B
B
B
B
39pF (390)
A
A
A
A
A
B
B
B
B
B
47pF (470)
A
A
A
A
A
B
B
B
B
B
56pF (560)
A
A
A
A
A
B
B
B
B
B
68pF (680)
A
A
A
A
A
B
B
B
B
B
82pF (820)
A
A
A
A
A
B
B
B
B
B
100pF (101)
A
A
A
A
A
B
B
B
B
B
120pF (121)
A
A
A
A
A
B
B
B
B
B
150pF (151)
A
A
A
A
A
B
B
B
B
B
180pF (181)
A
A
A
A
A
B
B
B
B
B
220pF (221)
A
A
A
A
A
B
B
B
B
B
270pF (271)
A
A
A
A
A
B
B
B
B
B
330pF (331)
A
A
A
A
A
B
B
B
B
B
390pF (391)
B
B
B
B
B
B
B
B
B
B
470pF (471)
B
B
B
B
B
6/8/2023
12
PART CODE:
1206Y106Z100JC
Size
Table 7-F
0805
1206
VDC (V)
10
16
25
50
100
10
16
25
50
100
560pF (561)
B
B
B
B
B
B
B
B
B
B
680pF (681)
B
B
B
B
B
B
B
B
B
B
820pF (821)
B
B
B
B
B
B
B
B
B
B
1,000pF (102)
B
B
B
B
B
B
B
B
B
B
1,200pF (122)
B
B
B
B
B
B
B
B
B
B
1,500pF (152)
B
B
B
B
B
B
B
B
B
B
1,800pF (182)
B
B
B
B
B
B
B
B
B
B
2,200pF (222)
B
B
B
B
B
B
B
B
B
B
2,700pF (272)
C
C
C
C
C
B
B
B
B
B
3,300pF (332)
C
C
C
C
C
B
B
B
B
B
Size
Table 7-G
0805
1206
VDC (V)
10
16
25
50
100
10
16
25
50
100
3,900pF (392)
C
C
C
C
C
B
B
B
B
B
4,700pF (472)
C
C
C
C
C
B
B
B
B
B
5,600pF (562)
C
C
C
C
C
B
B
B
B
B
6,800pF (682)
C
C
C
C
C
I
I
I
I
I
8,200pF (822)
C
C
C
C
C
C
C
C
C
0.010µF (103)
C
C
C
C
C
C
C
C
C
0.012µF (123)
B
B
B
B
P
P
P
P
P
P
P
P
P
P
0.015µF (153)
0.018µF (183)
C
C
C
C
P
P
P
P
P
0.022µF (223)
C
C
C
C
P
P
P
P
P
0.027µF (273)
P
P
P
P
0.033µF (333)
P
P
P
P
0.039µF (393)
P
P
P
P
0.047µF (473)
J
J
J
J
0.056µF (563)
J
J
J
J
0.068µF (683)
D
D
D
D
6/8/2023
13
PART CODE:
1206Y106Z100JC
Size
Table 7-H
0805
VDC (V)
10
16
1206
25
50
100
10
16
25
50
0.082µF (823)
D
D
D
D
0.1µF (104)
D
D
D
D
CAPACITANCE RANGE - NP0 DIELECTRIC 1210, 1812 SIZES
Size
100
Table 7-I
1210
1812
VDC (V)
10
16
25
50
100
16
50
100
10pF (100)
I
I
I
I
I
C
C
C
15pF (150)
I
I
I
I
I
C
C
C
18pF (180)
I
I
I
I
I
C
C
C
22pF (220)
I
I
I
I
I
C
C
C
27pF (270)
I
I
I
I
I
C
C
C
33pF (330)
I
I
I
I
I
C
C
C
39pF (390)
I
I
I
I
I
C
C
C
47pF (470)
I
I
I
I
I
C
C
C
56pF (560)
I
I
I
I
I
C
C
C
68pF (680)
I
I
I
I
I
C
C
C
82pF (820)
I
I
I
I
I
C
C
C
100pF (101)
I
I
I
I
I
C
C
C
120pF (121)
I
I
I
I
I
C
C
C
150pF (151)
I
I
I
I
I
C
C
C
180pF (181)
I
I
I
I
I
C
C
C
220pF (221)
I
I
I
I
I
C
C
C
270pF (271)
I
I
I
I
I
C
C
C
330pF (331)
I
I
I
I
I
C
C
C
390pF (391)
I
I
I
I
I
C
C
C
560pF (561)
I
I
I
I
I
C
C
C
680pF (681)
I
I
I
I
I
C
C
C
820pF (821)
I
I
I
I
I
C
C
C
1,000pF (102)
I
I
I
I
I
C
C
C
1,200pF (122)
I
I
I
I
I
C
C
C
6/8/2023
14
1206Y106Z100JC
PART CODE:
Size
Table 7-J
1210
1812
VDC (V)
10
16
25
50
100
16
50
100
1,500pF (152)
I
I
I
I
I
C
C
C
1,800pF (182)
I
I
I
I
I
C
C
C
2,200pF (222)
I
I
I
I
I
C
C
C
2,700pF (272)
I
I
I
I
I
C
C
C
3,300pF (332)
I
I
I
I
I
C
C
C
3,900pF (392)
I
I
I
I
I
C
C
C
4,700pF (472)
I
I
I
I
I
C
C
C
5,600pF (562)
I
I
I
I
I
C
C
C
6,800pF (682)
I
I
I
I
I
C
C
C
8,200pF (822)
I
I
I
I
I
C
C
C
0.010µF (103)
I
I
I
I
I
C
C
C
0.012µF (123)
C
C
C
C
C
C
C
C
0.015µF (153)
C
C
C
C
C
C
C
C
0.018µF (183)
K
K
K
K
C
C
C
0.022µF (223)
K
K
K
K
C
C
C
0.027µF (273)
K
K
K
K
C
C
C
0.033µF (333)
K
K
K
K
C
C
C
0.039µF (393)
K
K
K
K
M
M
M
0.047µF (473)
K
K
K
K
M
M
M
0.056µF (563)
M
M
M
0.068µF (683)
M
M
M
0.082µF (823)
M
M
M
0.1µF (104)
M
M
M
Note: The letter in cell is expressed the symbol of product thickness.
6/8/2023
15
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE – X7R DIELECTRIC 0201, 0402 SIZES
Size
Table 8-A
0201
0402
VDC (V)
6.3
10
16
25
50
6.3
10
16
25
50
100
100pF (101)
L
L
L
L
L
H
H
H
H
H
H
120pF (121)
L
L
L
L
L
H
H
H
H
H
H
150pF (151)
L
L
L
L
L
H
H
H
H
H
H
180pF (181)
L
L
L
L
L
H
H
H
H
H
H
220pF (221)
L
L
L
L
L
H
H
H
H
H
H
270pF (271)
L
L
L
L
L
H
H
H
H
H
H
330pF (331)
L
L
L
L
L
H
H
H
H
H
H
390pF (391)
L
L
L
L
L
H
H
H
H
H
H
470pF (471)
L
L
L
L
L
H
H
H
H
H
H
560pF (561)
L
L
L
L
L
H
H
H
H
H
H
680pF (681)
L
L
L
L
L
H
H
H
H
H
H
820pF (821)
L
L
L
L
L
H
H
H
H
H
H
1,000pF (102)
L
L
L
L
L
H
H
H
H
H
H
1,200pF (122)
L
L
L
L
H
H
H
H
H
H
1,500pF (152)
L
L
L
L
H
H
H
H
H
H
1,800pF (182)
L
L
L
L
H
H
H
H
H
H
2,200pF (222)
L
L
L
L
H
H
H
H
H
H
2,700pF (272)
L
L
L
L
H
H
H
H
H
H
3,300pF (332)
L
L
L
L
H
H
H
H
H
H
3,900pF (392)
L
L
L
L
H
H
H
H
H
H
4,700pF (472)
L
L
L
L
H
H
H
H
H
H
5,600pF (562)
L
L
L
L
H
H
H
H
H
6,800pF (682)
L
L
L
H
H
H
H
H
8,200pF (822)
L
L
L
H
H
H
H
H
0.010µF (103)
L
L
L
H
H
H
H
H
0.012µF (123)
H
H
H
H
H
0.015µF (153)
H
H
H
H
H
0.018µF (183)
H
H
H
H
H
0.022µF (223)
H
H
H
H
H
6/8/2023
16
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE – X7R DIELECTRIC 0402 SIZES
Size
Table 8-B
0402
VDC (V)
6.3
10
16
25
50
0.027µF (273)
H
H
H
H
H
0.033µF (333)
H
H
H
H
H
0.039µF (393)
H
H
H
H
H
0.047µF (473)
H
H
H
H
H
0.056µF (563)
H
H
H
H
H
0.068µF (683)
H
H
H
H
H
0.082µF (823)
H
H
H
H
H
0.10µF (104)
H
H
H
H
H
0.22µF (224)
H
H
H
H
0.47µF (474)
H
H
1.0µF (105)
H
H
CAPACITANCE RANGE – X7R DIELECTRIC 0603, 0805 SIZES
Size
Table 8-C
0603
0805
VDC (V)
6.3
10
16
25
50
100
6.3
10
16
25
50
100
100pF (101)
S
S
S
S/B
S/B
S
B
B
B
B
B
B
120pF (121)
S
S
S
S
S
S
B
B
B
B
B
B
150pF (151)
S
S
S
S
S
S
B
B
B
B
B
B
180pF (181)
S
S
S
S
S
S/B
B
B
B
B
B
B
220pF (221)
S
S
S
S
S/B
S
B
B
B
B
B
B
270pF (271)
S
S
S
S
S
S
B
B
B
B
B
B
330pF (331)
S
S
S
S
S
S
B
B
B
B
B
B
390pF (391)
S
S
S
S
S
S
B
B
B
B
B
B
470pF (471)
S
S
S
S
S/B
S
B
B
B
B
B
B
560pF (561)
S
S
S
S
S
S
B
B
B
B
B
B
680pF (681)
S
S
S
S
S
S
B
B
B
B
B
B
820pF (821)
S
S
S
S
S
S
B
B
B
B
B
B
1,000pF (102)
S
S
S
S/B
S/B
S/B
B
B
B
B
B
B
1,200pF (122)
S
S
S
S
S
S
B
B
B
B
B
B
1,500pF (152
S
S
S
S/B
S
S
B
B
B
B
B
B
6/8/2023
17
PART CODE:
1206Y106Z100JC
Size
Table 8-D
0603
0805
VDC (V)
6.3
10
16
25
50
100
6.3
10
16
25
50
100
1,800pF (182)
S
S
S
S
S
S
B
B
B
B
B
B
2,200pF (222)
S
S
S
S
S/B
S
B
B
B
B
B
B
2,700pF (272)
S
S
S
S
S/B
S
B
B
B
B
B
B
3,300pF (332)
S
S
S
S
S
S
B
B
B
B
B
B
3,900pF (392)
S
S
S
S
S
S
B
B
B
B
B
B
4,700pF (472)
S
S
S
S
S
S
B
B
B
B
B
B
5,600pF (562)
S
S
S
S
S
S
B
B
B
B
B
B
6,800pF (682)
S
S
S
S/B
S
S
B
B
B
B
B
B
8,200pF (822)
S
S
S
S
S
S
B
B
B
B
B
B
0.010µF (103)
S
S
S
S/B
S/B
S
B
B
B
B
B
B
0.012µF (123)
S
S
S
S
S
X
B
B
B
B
B
B
0.015µF (153)
S
S
S
S/B
S/B
X
B
B
B
B
B
B
0.018µF (183)
S
S
S
S
S
X
B
B
B
B
B
B
0.022µF (223)
S
S
S
S
S/B
X
B
B
B
B
B
B
0.027µF (273)
S
S
S
S
S/B
X
B
B
B
B
B
C
0.033µF (333)
S
S
S
S
X/B
X
B
B
B
B
B
C
0.039µF (393)
S
S
S
S
X
X
B
B
B
B
B
C
0.047µF (473)
S
S
S
S
X
X
B
B
B
B
B
C
0.056µF (563)
S
S
S
S
X
X
B
B
B
B
B
C
0.068µF (683)
S
S
S
S
X/B
X
B
B
B
B
B
C
0.082µF (823)
S
S
S
S
X
X
B
B
B
B
B
C
0.10µF (104)
S
S
S/B
S/B
X
X
B
B
B
B
B
C
0.12µF (124)
S
S
S
X
B
B
B
B
C
C
0.15µF (154)
S
S
S/B
X
C
C
C
C
C
C
0.18µF (184)
S
S
S
X
C
C
C
C
C
C
0.22µF (224)
S
S
S/B
X/B
C
C
C
C
C
C
0.27µF (274)
X
X
X
X
C
C
C
C
C
0.33µF (334)
X
X
X
X
C
C
C
C
C
0.39µF (394)
X
X
X
X
C
C
C
C
C
X
6/8/2023
18
PART CODE:
1206Y106Z100JC
Size
Table 8-E
0603
0805
VDC (V)
6.3
10
16
25
50
6.3
10
16
25
50
100
0.47µF (474)
X
X
X/B
X/B
X
C
C
C
C
C
C
0.56µF (564)
X
X
X
C
C
C
C
0.68µF (684)
X
X
X
C
C
C
C
0.82µF (824)
X
X
X
C
C
C
C
1.0µF (105)
X
X
X
C
C
C
C
C
C
C
C
X
X
1.5µF (155)
2.2µF (225)
X
X/B
X
C
C
C
C
4.7µF (475)
X
X
X
C
C
C
C
C*
C*
C*
10µF (106)
C
C
CAPACITANCE RANGE – X7R DIELECTRIC 1206, 1210 SIZES
Size
Table 8-F
1206
1210
VDC (V)
6.3
10
16
25
50
100
10
16
25
50
100
150pF (151)
B
B
B
B
B
B
180pF (181)
B
B
B
B
B
B
220pF (221)
B
B
B
B
B
B
270pF (271)
B
B
B
B
B
B
330pF (331)
B
B
B
B
B
B
390pF (391)
B
B
B
B
B
B
470pF (471)
B
B
B
B
B
B
560pF (561)
B
B
B
B
B
B
680pF (681)
B
B
B
B
B
B
820pF (821)
B
B
B
B
B
B
1,000pF (102)
B
B
B
B
B
B
I
I
I
I
I
1,200pF (122)
B
B
B
B
B
B
I
I
I
I
I
1,500pF (152
B
B
B
B
B
B
I
I
I
I
I
1,800pF (182)
B
B
B
B
B
B
I
I
I
I
I
2,200pF (222)
B
B
B
B
B
B
I
I
I
I
I
2,700pF (272)
B
B
B
B
B
B
I
I
I
I
I
3,300pF (332)
B
B
B
B
B
B
I
I
I
I
I
6/8/2023
19
PART CODE:
1206Y106Z100JC
Size
Table 8-G
1206
1210
VDC (V)
6.3
10
16
25
50
100
10
16
25
50
100
3,900pF (392)
B
B
B
B
B
B
I
I
I
I
I
4,700pF (472)
B
B
B
B
B
B
I
I
I
I
I
5,600pF (562)
B
B
B
B
B
B
I
I
I
I
I
6,800pF (682)
B
B
B
B
B
B
I
I
I
I
I
8,200pF (822)
B
B
B
B
B
B
I
I
I
I
I
0.010µF (103)
B
B
B
B
B
B
I
I
I
I
I
0.012µF (123)
B
B
B
B
B
B
I
I
I
I
I
0.015µF (153)
B
B
B
B
B
B
I
I
I
I
I
0.018µF (183)
B
B
B
B
B
B
I
I
I
I
I
0.022µF (223)
B
B
B
B
B
B
I
I
I
I
I
0.027µF (273)
B
B
B
B
B
B
I
I
I
I
I
0.033µF (333)
B
B
B
B
B
B
I
I
I
I
I
0.039µF (393)
B
B
B
B
B
B
I
I
I
I
I
0.047µF (473)
B
B
B
B
B
B
I
I
I
I
I
0.056µF (563)
B
B
B
B
B
B
I
I
I
I
I
0.068µF (683)
B
B
B
B
B
B
I
I
I
I
I
0.082µF (823)
B
B
B
B
B
C
I
I
I
I
I
0.10µF (104)
B
B
B
B
B
C
I
I
I
I
I
0.12µF (124)
B
B
B
B
B
C
I
I
I
I
I
0.15µF (154)
I
I
I
I
I
D
I
I
I
I
C
0.18µF (184)
I
I
I
I
I
D
I
I
I
I
C
0.22µF (224)
I
I
I
I
I/B
D
I
I
I
I
C
0.27µF (274)
I
I
I
I
C
D
I
I
I
I
D
0.33µF (334)
I
I
I
I
C
D
I
I
I
C
D
0.39µF (394)
I
I
I
J
P
D
I
I
I
C
M
0.47µF (474)
J
J
J
J
P
D
I
I
I
C
M
0.56µF (564)
J
J
J
J
P
P
C
C
C
C
M
0.68µF (684)
J
J
J
J
P
P
C
C
C
C
K
0.82µF (824)
J
J
J
J
P
P
C
C
C
C
K
6/8/2023
PART CODE:
1206Y106Z100JC
Size
Table 8-H
1206
1210
VDC (V)
6.3
10
16
25
50
100
10
16
25
50
100
1.0µF (105)
J
J
J
J
P
P
C
C
C
C
K
1.5µF (155)
J
J
J
P
D
D
M
M
2.2µF (225)
J
J
J
P
D
D
M
M
3.3µF (475)
P
P
P
P
D
D
M
4.7µF (475)
P
P
P
P
K
K
K
M
10µF (106)
P
P
P
P
K
K
K
M
22µF (226)
P*
P*
P*
M
M
M
P
P
P
M
M
47µF (476)
CAPACITANCE RANGE – X7R DIELECTRIC 1812 SIZES
Table 8-I
Size
1812
VDC (V)
6.3
10
16
25
50
100
1,000pF (102)
C
C
C
C
C
C
1,200pF (122)
C
C
C
C
C
C
1,500pF (152
C
C
C
C
C
C
1,800pF (182)
C
C
C
C
C
C
2,200pF (222)
C
C
C
C
C
C
2,700pF (272)
C
C
C
C
C
C
3,300pF (332)
C
C
C
C
C
C
3,900pF (392)
C
C
C
C
C
C
4,700pF (472)
C
C
C
C
C
C
5,600pF (562)
C
C
C
C
C
C
6,800pF (682)
C
C
C
C
C
C
8,200pF (822)
C
C
C
C
C
C
0.010µF (103)
C
C
C
C
C
C
0.012µF (123)
C
C
C
C
C
C
0.015µF (153)
C
C
C
C
C
C
0.018µF (183)
C
C
C
C
C
C
6/8/2023
21
PART CODE:
1206Y106Z100JC
Table 8-J
Size
1812
VDC (V)
6.3
10
16
25
50
100
0.022µF (223)
C
C
C
C
C
C
0.027µF (273)
C
C
C
C
C
C
0.033µF (333)
C
C
C
C
C
C
0.039µF (393)
C
C
C
C
C
C
0.047µF (473)
C
C
C
C
C
C
0.056µF (563)
C
C
C
C
C
C
0.068µF (683)
C
C
C
C
C
C
0.082µF (823)
C
C
C
C
C
C
0.10µF (104)
C
C
C
C
C
C
0.12µF (124)
C
C
C
C
C
C
0.15µF (154)
C
C
C
C
C
C
0.18µF (184)
C
C
C
C
C
C
0.22µF (224)
C
C
C
C
C
C
0.27µF (274)
C
C
C
C
C
C
0.33µF (334)
C
C
C
C
C
C
0.39µF (394)
C
C
C
C
C
C
0.47µF (474)
C
C
C
C
C
K
0.56µF (564)
C
C
C
C
C
K
0.68µF (684)
C
C
C
C
K
K
0.82µF (824)
C
C
C
C
K
K
1.0µF (105)
C
C
C
C
K
K
1.5µF (155)
K
K
2.2µF (225)
M
M
Note: 1) The letter in cell is expressed the symbol of product thickness. 2) The letter in cell with “ * ” mark is for “M
tolerance" ( 20% ) only
6/8/2023
22
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE – Y5V DIELECTRIC 0402, 0603 SIZES
Size
VDC (V)
Table 9-A
0402
6.3
0603
10
16
25
50
0.010µF (103)
H
H
H
0.015µF (153)
H
H
0.022µF (223)
H
0.033µF (333)
6.3
10
16
25
50
H
S
S
S/B
S/B
H
H
S
S
S
S
H
H
H
S
S
S
S
H
H
H
H
S
S
S
S
0.047µF (473)
H
H
H
S
S
S
S
0.068µF (683)
H
H
H
S
S
S
S
0.10µF (104)
H
H
H
S
S
S/B
S/B
0.15µF (154)
H
H
S
S
S
S
S
S
S
S
0.22µF (224)
H
H
H
H
0.33µF (334)
H
H
H
S
S
S
0.47µF (474)
H
H
H
S
S
X
0.68µF (684)
H
S
X
1.0µF (105)
H
S
X
H
S
1.5µF (155)
2.2µF (225)
S
S
4.7µF (475)
X
X
CAPACITANCE RANGE – Y5V DIELECTRIC 0805, 1206 SIZES
Size
Table 9-B
0805
1206
VDC (V)
10
16
25
50
100
10
16
25
50
100
0.010µF (103)
A
A
A
A
B
B
B
B
B
B
0.015µF (153)
A
A
A
A
B
B
B
B
B
B
0.022µF (223)
A
A
A
A
B
B
B
B
B
B
0.033µF (333)
A
A
A
A
B
B
B
B
B
B
0.047µF (473)
A
A
A
A
B
B
B
B
B
B
0.068µF (683)
A
A
A
A
B
B
B
B
B
B
0.10µF (104)
A
A
A
A
B
B
B
B
B
B
0.15µF (154)
A
A
A
A
B
B
B
B
I
0.22µF (224)
A
A
A
A
B
B
B
B
I
0.33µF (334)
B
B
B
B
B
B
B
B
6/8/2023
23
PART CODE:
1206Y106Z100JC
Size
VDC (V)
Table 9-C
0805
6.3
1206
10
16
25
50
10
16
25
50
0.47µF (474)
B
B
B
B
B
B
B
B
0.68µF (684)
B
B
C
C
B
B
B
B
1.0µF (105)
B
B
C
C
I
I
I
I
1.5µF (155)
C
C
I
I
I
2.2µF (225)
C
C
I
I
I
3.3µF (335)
C
C
J
J
J
4.7µF (475)
C
C
J
J
J
6.8µF (685)
C
J
J
J
J
C
10µF (106)
C
C
P
22µF (226)
CAPACITANCE RANGE – Y5V DIELECTRIC 1210, 1812 SIZES
Size
VDC (V)
Table 9-D
1210
10
16
25
1812
35
50
100
10
16
25
50
100
0.010µF (103)
I
C
0.015µF (153)
I
C
0.022µF (223)
I
C
0.033µF (333)
I
C
0.047µF (473)
I
C
0.068µF (683)
I
C
0.10µF (104)
I
I
I
I
I
C
C
C
C
C
0.15µF (154)
I
I
I
I
I
C
C
C
C
C
0.22µF (224)
I
I
I
I
I
C
C
C
C
C
0.33µF (334)
I
I
I
I
I
C
C
C
C
C
0.47µF (474)
I
I
I
I
C
C
C
C
C
0.68µF (684)
I
I
I
I
C
C
C
C
C
1.0µF (105)
I
I
I
I
C
C
C
C
C
1.5µF (155)
I
I
I
C
C
C
C
2.2µF (225)
I
I
I
C
C
C
C
3.3µF (335)
I
I
I
C
C
C
C
D
6/8/2023
24
PART CODE:
1206Y106Z100JC
Size
VDC (V)
Table 9-E
1210
6.3
1812
10
16
25
50
10
16
25
50
4.7µF (475)
I
I
C
D
C
C
C
C
6.8µF (685)
I
I
C
C
C
C
C
10µF (106)
C
C
D
C
C
C
22µF (226)
K
K
47µF (476)
K
100µF (107)
M
D
K
M
CAPACITANCE RANGE – X5R DIELECTRIC 0201 SIZES
Size
VDC (V)
Table 10-A
0201
10
16
25
50
100pF (101)
L
L
L
120pF (121)
L
L
L
150pF (151)
L
L
L
180pF (181)
L
L
L
220pF (221)
L
L
L
270pF (271)
L
L
L
330pF (331)
L
L
L
390pF (391)
L
L
L
470pF (471)
L
L
L
560pF (561)
L
L
L
680pF (681)
L
L
L
820pF (821)
L
L
L
L
1,000pF (102)
L
L
L
1,200pF (122)
L
L
L
1,500pF (152
L
L
L
2,200pF (222)
L
L
L
2,700pF (272)
L
L
L
3,300pF (332)
L
L
L
4,700pF (472)
L
L
L
6/8/2023
25
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE – X5R DIELECTRIC 0201 0402 SIZES
Size
VDC (V)
Table 10-B
0201
6.3
6,800µF (682)
0402
10
16
25
L
L
L
L
L
50
6.3
10
16
25
50
0.010µF (103)
L
L
0.015µF (153)
L
L
H
0.022µF (223)
L
L
H
0.027µF (273)
L
L
H
H
0.033µF (333)
L
L
H
H
0.039µF (393)
L
L
H
H
0.047µF (473)
L
L
H
H
H
H
0.056µF (563)
L
L
H
H
H
H
0.068µF (683)
L
L
H
H
H
H
0.082µF (823)
L
L
H
H
H
H
0.10µF (104)
L
L
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H
H/E
H
4.7µF (475)
H
H
H*
10µF (106)
H*
H*
L
L
L
0.15µF (154)
0.22µF (224)
L
L
0.33µF (334)
L*
L*
0.47µF (474)
L
L*
0.68µF (684)
1.0µF (105)
L*
L*
2.2µF (225)
L*
L*
L*
CAPACITANCE RANGE – X5R DIELECTRIC 0603 SIZES
Size
Table 10-C
0603
VDC (V)
6.3
10
16
25
0.22µF (224)
X
X
X
X
X
X
X
X
X
X
0.39µF (394)
X
X
X
0.47µF (474)
X
X/B
X
0.27µF (274)
0.33µF (334)
X
6/8/2023
H/E
50
X
26
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE – X5R DIELECTRIC 0603 0805 SIZES
Size
Table 10-D
0603
0805
VDC (V)
6.3
10
16
25
0.68µF (684)
X
X
X
X
0.82µF (824)
X
X
X
X
1.0µF (105)
X
X
X
X/B
1.5µF (155)
X
2.2µF (225)
X/B
X
10
16
25
50
C
C
C
C
C
C
C
C
C
C
C
C
3.3µF (335)
X
X
C
C
C
C
4.7µF (475)
X
X
X
X
C
C
C
C
C
10µF (106)
X/B
X
X
X*
C
C
C
C
C
22µF (226)
X*
X*
C
C*
C*
C*
47µF (476)
C*
C*
100µF (107)
C*
X
50
6.3
X/B
X
X
CAPACITANCE RANGE – X5R DIELECTRIC 1206, 1210 SIZES
Size
VDC (V)
Table 10-E
1206
6.3
1210
10
16
1.5µF (155)
J
J
2.2µF (225)
J
J
P
3.3µF (335)
P
P
P
25
10
16
K
K
P
K
K
P
P
P
K
K
K
P
K
K
K
K
M
M
M
M
M
M*
M*
M*
4.7µF (475)
P
P
6.8µF (685)
P
P
10µF (106)
P
P
P
P/D
22µF (226)
P
P
P
P
47µF (476)
P
P
P*
100µF (107)
P*
220µF (227)
C
50
4
M*
6.3
25
50
M
M*
6/8/2023
27
PART CODE:
1206Y106Z100JC
CAPACITANCE RANGE – X6S DIELECTRIC 0201, 0402, 0603 SIZES
Size
0201
Table 11-A
0402
VDC (V)
4
6.3
0.10µF (104)
L
L
6.3
0603
10
16
25
H
H
H
H
H
H
H
4
6.3
10
16
25
X
X
L
0.22µF (224)
H
0.47µF (474)
L*
1.0µF (105)
2.2µF (225)
4.7µF (475)
X
10µF (106)
X*
X*
22µF (226)
X*
X*
X*
CAPACITANCE RANGE – X6S DIELECTRIC 0805, 1206, 1210 SIZES
Size
VDC (V)
0805
4
6.3
10
Table 11-B
1206
16
25
50
C
C
6.3
10
1210
16
25
6.3
10
16
25
0.10µF (104)
0.22µF (224)
0.47µF (474)
1.0µF (105)
2.2µF (225)
4.7µF (475)
10µF (106)
C
22µF (226)
47µF (476)
C
C
C
C*
C*
C*
C*
C
D
P
P
P*
M
M
M
M
M*
100µF (107)
6/8/2023
28
PART CODE:
1206Y106Z100JC
INSULATION RESISTANCE – Requirement - Class II (X7R, X5R, X6S, Y5V)
Table 12
Rated Voltage
IR
100V: All X7R
10GΩ or RxC≧100 Ω-F
50V: 0402>0.01uF; 0603≧1µF; 0805≧1µF; 1206≧4.7µF; 1210≧4.7µF
whichever is smaller
35V: 0805≧2.2µF; 1206≧2.2µF; 1210≧10µF
25V: 0402≧1µF; 0603≧2.2µF; 0805≧2.2µF; 1206≧10µF; 1210≧10µF
16V: 0201≧0.1µF; 0402≧0.22µF; 0603≧1µF; 0805≧2.2µF; 1206≧10µF; 1210≧47µF
10V: 0201≧47nF; 0402≧0.47µF; 0603≧0.47µF; 0805≧2.2µF; 1206≧4.7µF; 1210≧47µF
6.3V; 4V; Size ≧1812
All X6S items
RxC≧50 Ω-F.
100V: 1210≧3.3µF
50V: 0402≧0.1µF; 0603≧2.2µF; 0805≧10µF; 1206≧10µF
35V: 0603≧1µF
25V: 0201≧0.1µF; 0402≧0.22µF; 0603≧10µF; 0805≧10µF; 1206≧22µF
16V: 0201≧0.22µF; 0402≧1µF; 0603≧10µF
10V: 0201>0.1µF; 0402≧1µF; 0603≧10µF; 0805≧47µF
6.3V: 0201≧0.1µF; 0603≧4.7µF; 0805≧47µF; 1206≧10µF
4V: 0603≧22µF; 0805≧47µF; 1206≧100µF
TEMPERATURE COEFFICIENT- Test Condition Measurement voltage for Class II:
Measurement Voltage
Size
Cap≤0.01µF: 0.5V; Cap.> 0.01µF: 0.2V
01005
Cap 0.01µF
10-25V
C≥0.22µF
Y5V
16V
C≥4.7µF
Y7R
50V
C>1.0µF
25V
C=1.0µF
X5R
50V
C≥1.0µF
X5R/X7R/X6S
10V, 16V
C≥1.0µF
Y5V
16V
C≥2.2µF
X5R/X7R/X6S
100V
C≥0.47µF
50V
C≥1.0µF
35V
C≥2.2µF
10-25V
C≥4.7µF
Y5V
16V
C≥4.7µF
X7R
100V
C≥1.0µF
50V
C=4.7µF
100V
C>1.0µF
50V
C=4.7µF
50-100V
C≥2.2µF
0402
0603
0805
1206
X5R/X6S
1210
X5R/X7R/X6S
6/8/2023
Table 16
31
PART CODE:
1206Y106Z100JC
RELIABILITY TEST CONDITIONS AND REQUIREMENTS
Item
Test Condition
Requirements
Visual and
* No remarkable defect.
Mechanical
* Dimensions to conform to
individual spec. sheet.
Capacitance
Q/D.F
(Dissipation
Factor)
Class I: (NP0)
* Shall not exceed the limits
≦1000pF, 1.0±0.2Vrms, 1MHz±10%
given in the detailed spec.
>1000pF, 1.0±0.2Vrms,1KHz±10%
Class II: (X7R, X6S, X5R,Y5V)
C≦10µF, 1.0±0.2Vrms, 1KHz±10%
** C>10µF, 0.5±0.2Vrms, 120Hz±20%
** Test condition: 0.5±0.2Vrms, 1KHz±10%
X7R: 0805=106(6.3V), 0603/475(6.3V)
X5R: 0201≧ 224 (6.3V,10V,16V)*, 0402≧475 (6.3V,16V),
NP0:
Cap≧30pF, Q≧1000;
Cap0603);
removal of the terminations.
Termination
* Test time: 10±1 sec.
Vibration
Vibration frequency: 10~55 Hz/min.
* No remarkable damage or
Resistance
* Total amplitude: 1.5mm
* Test time: 6 hrs. (Two hrs each inthree
* No remarkable damage.
* mutually perpendicular directions.)
* Cap change and Q/D.F.:
* Before initial measurement (Class II only):
To meet initial spec.
To apply de-aging at 150°C for 1hr then set for 24±2
hrs at room temp.
* Cap./DF(Q) Measurement to be made after de-aging
a 150°C for 1hr then set for 24±2 hrs at room temp.
Bending Test
* The middle part of substrate shall be pressurized by
means of the pressurizing rod at a rate of about 1 mm
* Cap change:
per second until the deflection becomes 1 mm and
NP0: within ±5% or 0.5pF
then the pressure shall be maintained for 5±1 sec.
whichever is larger X7R, X5R, X6S:
*Before initial measurement (Class II only):
within ±12.5%
Y5V: within ±30%
hrs at room temp.
(This capacitance change means
Measurement to be made after keeping at room temp.
the change of capacitance under
for 24±2 hrs.
specified flexure of substrate
from the capacitance measured
before the test.)
6/8/2023
33
PART CODE:
1206Y106Z100JC
Item
Test Condition
Requirements
Resistance to
* Solder temperature: 260±5°C
Soldering Heat
* Dipping time: 10±1 sec
* Cap change:
* Preheating: 120 to 150°C for 1 minute before
NP0: within ±2.5% or 0.25pF
immerse the capacitor in a eutectic solder.
* Before initial measurement (Class II only): To apply
within ±7.5%
de-aging at 150°C for 1hr then set for 24±2 hrs at
Y5V: within ±20%
room temp.
* Q/D.F., I.R. and dielectric
* Cap. / DF(Q) / I.R. Measurement to be made after
strength: To meet initial
requirements.
room
* 25% max. leaching on each
edge.
Temperature
*Conduct the five cycles according to the temperatures
Cycle
and time.
* Cap change:
Time (min.): 30±3 @ Min. operating temp.+0/-3 °C
Time (min.): 2~3 @ Room temperture
Time (min.): 30±3 @ Max. operating temp.+3/-0 °C
within ±7.5%
Y5V: within ±20%
Perform150+0/-10°C for 1 hr and then set for 24±2
hrs at room temp.
requirements.
* Cap. / DF(Q) / I.R. Measurement to be made after deaging at 150°C for 1hr then set for 24±2 hrs at room.
Solder ability
* Solder temperature: 235±5°C
95% min. coverage of all
* Dipping time: 2±0.5 sec.
metalized area
6/8/2023
34
PART CODE:
1206Y106Z100JC
Item
Test Condition
Requirements
Humidity
* Test temp.: 40±2°C
(Damp Heat)
* Humidity: 90~95% RH
* Cap change:
Steady State
* Test time: 500+24/-0hrs.
whichever is larger
Perform 150+0/-10°C for 1 hr and then set for 24±2
X7R, X5R, X6S: ≧10V**,within
hrs at room temp.
±12.5%; 6.3V within ±25%;
* Cap. / DF(Q) / I.R. Measurement to be made after de-
** 10V: 0603≧4.7µF; 0402≧1µF;
0201 ≧0.1µF, within ±25%;
temp.
Y5V: ≧10V, within ±30%;
6.3V, within +30/≦ -40%
* Q/D.F. value:
NP0: More than 30pF Q≧350,
10pF≦C≦30pF, Q≧275+2.5C Less
than 10pF Q≧200+10C
X7R: See
X5R: See
Y5V: See
X6S: See
*I.R.: ≧10V, 1GΩ or 50 Ω-F
whichever is smaller.
See Table 14
6/8/2023
35
PART CODE:
1206Y106Z100JC
Item
Test Condition
Requirements
Humidity
*Test temp.: 40±2°C
(Damp Heat) Load
* Humidity: 90~95%RH
Cap change:
* Test time: 500+24/-0 hrs.
NP0: ±7.5% or 0.75pF
* To apply voltage: rated voltage.
whichever is larger.
±12.5%; ≦ 6.3V within ±25%;
room temp.
**10V: 0603 4.7≧µF; 0402 ≧1µF;
0201≧0.1 µF, within ±25%;
aging at 150°C for 1hr.then set for 24±2 hrs at room
Y5V: ≧10V, within ±30%; ≦ 6.3V,
temp
within +30/-40% Q/D.F. value:
NP0: C≧30pF, Q≧200; C
