CA42A010M476BA
CA42A010M476BA
    NEXTGEN
    CAP TAN 47UF 20% 10V 2.5MM BULK
CA42A010M476BA 数据手册
PART CODE: CA42A010M476BA SPECIFICATION SHEET SPECIFICATION SHEET NO. N0830- CA42A010M476BA DATE Aug. 30, 2021 REVISION A0 DESCRIPITION Dip Type Epoxy-Coated Solid Electrolytic Tantalum Capacitor CA42 Series, Case A, Lead Space 2.54mm (0.100”) Rated voltage 10 Vdc, Capacitance 47μF, Tolerance ±20% Operating Temp. Range -55°C ~+125°C, Package in Bulk, 1000pcs/polybag and inner box RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER CA42-10V47 PART CODE CA42A010M476BA VENDOR APPROVE Issued/Checked/Approved DATE: Aug. 30, 2021 CUSTOMER APPROVE DATE: 1 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A MAIN FEATURE • RoHS III Compliant • Wide Operating Temperature Range -55~+125℃ • Epoxy-coated and Radial- lead • Stable in electrical & storage performances APPLICATION • For TV sets, PC, Mobile Telephone sets Pickup camera Radar etc. • Instruments, Meters and more electronical equipment. RFQ PART CODE GUIDE Request For Quotation CA42 A 010 M 476 B A 1 2 3 4 5 6 7 1) CA42: Series code for Dip Type Epoxy-Coated Solid Electrolytic Tantalum Capacitors 2) A: Case size code for Lead space , A: 2.54mm(0.100”); B: 5.08mm (0.200”) 3) 010: Rated voltage Code, 010: 10Vdc 4) M: Capacitance Tolerance code, K: +/-10%; M: +/-20% 5) 476: Capacitance Code: 1st two digits represent Significant figures, 3rd Digit specifies number of Zeros. 476: 47μF 6) B: Package code, B: in Bulk, 1000pcs/polybag; A: In Paper Tape AMMO 7) A: Internal control or Customer’s Special Code (A~Z or 1~9) CROSS REFERENCE LIST for reference Our Series Code Other Brand Manufacturer Cross Product series CA42 AVX TAP Kemet T350~T356 NEC ND, NP NIC NDTM NICHICON S89 NEMCO/SUNTSU TB PANASONIC ECSF VISHAY 199D, 489D, ETPW, ETQW 2 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A MORE ITEMS AVAILABLE CA42A010M106BA CA42A010M226BA CA42A010M476BA CA42A016M106BA CA42A016M107BA CA42A016M156BA CA42A016M225BA CA42A016M226BA CA42A016M335BA CA42A016M336BA CA42A016M475BA CA42A016M476BA CA42A020M106BA CA42A025M105BA CA42A025M106BA CA42A025M156BA CA42A025M225BA CA42A025M226BA CA42A025M335BA CA42A025M336BA CA42A025M475BA CA42A025M476BA CA42A025M685BA CA42A035M104BA CA42A035M154BA CA42A035M224BA CA42A035M474BA CA42A035M684BA CA42A035M105BA CA42A035M106BA CA42A035M226BA CA42A035M335BA CA42A035M475BA CA42A004M687BA CA42A050M334BA CA42A050M684BA CA42A050M105BA CA42A050M335BA CA42A6R3M476BA PRODUCT STRUCTURE for reference 3 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A DIMENSION (Unit: mm) - _ Image for reference CA42 Case A Capacitance code: 22µF Dimension d 0.5±0.5mm _ _ Marking: 476/10 Item 476 10 + Polarity: Anode (+) Rate Voltage Code: 10V Long Lead : Anode (+) 4 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A ELECTRONICAL CHARACTERISTICS Item Unit Operating Temperature Range Symbol Characteristic Condition °C -55~+125 @>85℃ Applying Voltage Derating: 10V Rated Voltage Range V DC 10 Capacitance Tolerance % ±20 @25℃, 100Hz, V: 0.3+/0.02 Leakage Current μA I0 Measured after 1 Minutes Application of rated voltage reading, I 0≤ 0.02 CRUR or 1.0μA Max. whichever is greater @25 ℃ CR: (μF) Nominal Capacitance UR: (V) Rated voltage Capacitance μF CR 47 @25℃, 100Hz Dissipation Factor % tgδ 8.0 Max. @25℃, 100Hz, V: 0.3+/0.02 TEMPERATURE CHARACTERISTICS Item Unit Capacitance change Dissipation Factor (Max) Temperature Characteristics Leakage Current (I Max.) @Nominal Capacitance 47μF ℃ -55 +85 +125 % ±8 ±12 ±15 % -55 +20 +85 +125 ±8 ±8 ±10 ±10 μA +20 +85 +125 I 0≤ 0.002 CRUR or 1.0μA 10 Io 12.5 I0 5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A APPLICATION NTOE Storage Condition 1) Environmental temperature:10°C~ +40°C 2) Relative humidity no more than 70% 3) Storing period: No more than one and half year since the date of stocking. Application Guide 1) Ripple current and voltage If the ripple current is applied to the capacitor, the Joule heat (power dissipated) will be generated in the capacitor, so it will affect the reliability of the capacitor. (1) Power Dissipated The actual power dissipated can be calculated using the following formula: P=I² × ESR………Formula 1 P: Power dissipated (W); I: Ripple current (A); ESR: Equivalent series resistance (Ω) Power Dissipation for Case A 75mW Max. @+25°C (2) Ripple current Using the maximum power dissipation 65mW Max., the ripple current can be calculated using the following formula: I= ×K×F…………Formula 2 K: Temperature derating factor...... Table 1; F: Frequency derating factor........ Table 2 ESR: Refer to the ratings of each specific product Table 1: Temperature Drop Factor K Temperature Temperature Derating Factor K 25 °C 1 85 °C 0.9 125 °C 0.4 Table 2: Frequency Derating Factor F Frequency (KHz) 10 100 500 1000 MnO2 0.80 1.0 1.15 1.20 Using formula 3 to calculate corrugated voltage E: E=Z×I………. Formula 3 E: Ripple voltage; Z: Specific frequency impedance 6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A (3) Ripple voltage The ripple voltage applied to the capacitor is limited by three criteria. (a) The power dissipation in the ESR of capacitor must not exceed 65mW Max. @+25°C (b) The positive peak AC voltage plus the DC bias voltage must not exceed the DC voltage rating of the capacitor. (c) The negative peak AC voltage, in combination with the bias voltage, if any , must not exceed the permissible reverse voltage ratings presented . 2) Reverse voltage Solid tantalum capacitors are polarized devices , and applied reverse voltage can not be allowed . If the reverse voltage is unavoidable, a small degree of transient reverse voltage is permissible for short periods as follow. 25°C……. 10% of Max. rated voltage or 1V whichever is smaller 85°C……. 5% of Max. rated voltage or 0.5V whichever is smaller 125°C……1% of Max. rated voltage or 0.1V whichever is smaller Even under these restrictions, capacitors can not be used continuously in reverse voltage mode. 3) Working voltage (1) For general applications, using 50% of rated voltage of capacitors or less. (2) When used at the power circuit, low impedance circuit , coupling circuit or witching circuit which has leakage current problems, please design the circuit with voltage under 30% of the working voltage ( Max. 50%) to avoid the adverse effect of the surge current. (3) Derating voltage when temperature above 85°C. When the chip tantalum capacitor is used at 85℃ or more temperatures, the reduced voltage (UT) is calculated from the following expression, however, note that the ambient temperature is not more than 125℃. U T=V 0 (U R-U C)(T-85)/40 UR: Rated voltage (V); UC: Derating voltage at 125°C; T: Ambient temperature (°C ) 7 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A 4) Protective resistance In a circuit(switching circuit, charge / discharge circuit, etc.) that has an instantaneous current, series resistance is at least 3Ω/V, this can improve the reliability of tantalum capacitors. If the capacitor is in a low impedance circuit, the voltage applied to the capacitor should be half or one third of the rated voltage. 5) Redundancy MnO2 tantalum capacitors will heat, and may cause fire and burn in the short circuit . This is determined by the situation, time and other factors. When the circuit is designed, it is possible to provide the best possible space to keep the tantalum capacitor reliability. 6) Test Condition Ambient Temperature 25°C; Relative Humidity 60 to 70%; Air Pressure 800 to 1060mbar. Test and experiment, in order to make the test results not problems, it is necessary to will test the product after fully discharge. This product is a polar components, testing or when using it is strictly prohibited to will is negative pick back, in order to avoid performance failure 7) Soldering The SMD tantalum capacitor can be used for reflow soldering, which is not suitable for wave soldering and manual welding. The reflow temperature are ≤260°C, ≤ 5 seconds. If you must use manual welding, should use the melted solder to contact lead, and the electric soldering iron power should be less than or equal to 25W, temperature should be less than 300℃, welding time should be less than 3 seconds, can not use electric iron contact the product lead directly, and in particular, can not contact the product ontology directly. 8 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CA42A010M476BA DIP TANTALUM CAPACITORS CA42 SERIES CASE A % Working Voltage 8) Recommended Voltage Derating Guidelines Temperature °C Condition -55 °C ~ 85 °C -55 °C ~ 125 °C % Change in Working DC Voltage with Temperature VR 66% of VR Recommended Max. Application Voltage 50% of VR 33% of VR PACKAGE 1000pcs are packed in polybag and inner box. DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information. 9 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
CA42A010M476BA 价格&库存
很抱歉,暂时无法提供与“CA42A010M476BA”相匹配的价格&库存,您可以联系我们找货
