CM16M00000S022
CM16M00000S022
    NEXTGEN
    SMD3
    16 MHz 陶瓷 谐振器 内置电容 22 pF ±0.3% 40 Ohms -25°C ~ 85°C 表面贴装型
CM16M00000S022 数据手册
PART CODE: CM16M00000S022 SPECIFICATION SHEET SPECIFICATION SHEET NO. Q0501-CM16M00000S022 DATE May 01, 2023 REVISION A0 DESCRIPITION SMD Ceramic Resonator, 3731 Type, L3.7*W3.1*H1.5mm, Built-in Capacitance, 3 pads, CRTV Series 16.000MHz, Frequency Accuracy +/-0.5%, Operating Temp. Range -25°C ~+85°C, Reflow Profile Condition 260 °C Max. RoHS/RoHS III compliant, Tape/Reel CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS CRTV 16.0MX-22 TLF PART CODE CM16M00000S022 VENDOR APPROVE Issued/Checked/Approved DATE: May 01, 2023 CUSTOMER APPROVE DATE: 5/1/2023 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CM16M00000S022 SMD CERAMIC RESONATOR CRTV SERIES MAIN FEATURE • SMD Ceramic Resonator, L3.7*W3.1*H1.5mm, 3 pads • Low cost & Built-in Capacitance • Reflow Profile Condition 260 °C Max. • Wide Frequency Range • Cross more competitors part • RoHS III compliant APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation CM 16M00000 S 022 1 2 3 4 1) CM: Part Code for SMD Ceramic Resonator, Built-in Capacitance, L3.7*W3.1*H1.5mm, 3 pads, CRTV series 2) 16M00000: Frequency range code for 16.00000MHz 3) S: SMD type, Package Tape/Reel, 1000pcs/Reel 4) 022: Specification code for original part No.: TGS CRTV 16.0MX-22 TLF 5/1/2023 NextGen Components, Inc. 2 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CM16M00000S022 SMD CERAMIC RESONATOR CRTV SERIES DIMENSION (Unit: mm) Image for reference CRTV Recommend Pad Layout 5/1/2023 NextGen Components, Inc. 3 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CM16M00000S022 SMD CERAMIC RESONATOR CRTV SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Typical Condition Max. Original Manufacturer TGS TGS Crystals Holder Type CRTV SMD Ceramic Resonator, L3.7*W3.1*H1.5mm, 3 pads Frequency Range 16.0 MHz Withstanding Voltage MX V 50 @DC, 1 min MΩ 500 @AV, 1 min. Operation Temperance °C -25 +85 Storage Temperance °C -55 +85 Rating Voltage V Insulation Resistance 16.0 6 DC 15 p-p Frequency Accuracy % Resonant Impedance Ω 40 Temperature Coefficient of Oscillation Frequency % +/-0.3 Oscillation Frequency drift, -25℃~ +85℃) Oscillation Frequency Aging Rate (10 years) % +/-0.3 From initial value IC application 0.5 1/6TC74HCU04Px2 Design Mode Built-in Capacitance Other -22 pF 22pF (+/-20%) Package T Tape/Reel RoHS Status LF RoHS III compliant Add Value Internal Control Code * N/A Note: 1) Original Part Number: TGS CRTV 16.0MX-22 TLF 2) * Internal Control Code- 2 letter or digits; Blank: N/A 5/1/2023 NextGen Components, Inc. 4 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CM16M00000S022 SMD CERAMIC RESONATOR CRTV SERIES RELIABILITY Test Items Humidity Test Method And Conditions Performance Requirements Keep the resonator at 40℃±2℃ and 90%-95% RH for 96h. Then Release the resonator into the room Condition for 1h prior to the Measurement. It shall fulfill the specifications in Table 1. High Temperature Exposure Subject the resonator to -85℃±2℃ for 96h, then release the resonator into the room conditions for 1h prior to the measurement. It shall fulfill the specifications in Table 1. Low Temperature Exposure Subject the resonator to -55℃±2℃ for 96h, then release the resonator into the room conditions for 1h prior to the measurement. It shall fulfill the specifications in Table 1. Temperature Cycling After temperature cycling of blow table was performed 5 times, resonator shall be measured after being placed in natural conditions for 1h. Time: 30 min.@ -25 +/-3℃ ; Time: 30 min. @85 +/-3℃ It shall fulfill the specifications in Table 1. Vibration Subject the resonator to vibration for 2h each in x, y and z axis With the amplitude of 1.5mm, the frequency shall be varied uniformly between the limits of 10 Hz—55Hz. It shall fulfill the specifications in Table 1. Drop the resonator randomly onto a wooden floor from the height of 100cm 3 times. It shall fulfill the specifications in Table 1. Passed through the re-flow oven under the following condition and left at room temperature for 1h before measurement It shall fulfill the specifications in Table 1. Solder Ability Dipped in 245℃±5℃ solder bath for 3s±0.5 s with rosin flux (25wt% ethanol solution.) The terminals shall be at least 95% covered by solder. Board Bending Mount a glass-epoxy board (Width=40mm,thickness=1.6mm),then bend it to 1mm displacement and keep it for 5s. (See the following figure 1) Mechanical damage such as breaks shall not occur. Mechanical Shock Soldering Test Table 1 Item Specification after test Oscillation Frequency Change △Fosc/Fosc (%) max Resonant Impedance (Ω) max ±0.3 40 The limits in the above table are referenced to the initial measurements. 5/1/2023 NextGen Components, Inc. 5 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CM16M00000S022 SMD CERAMIC RESONATOR CRTV SERIES TEST CIRCUIT (For Reference Only) Note: Parts shall be tested under the condition ( Temp.: 20±15℃,Humidity 65±20% R.H.) unless the standard condition(Temp.: 25±3 ℃, Humidity :65±10% R.H.) is regulated to measure. SUGGESTED REFLOW PROFILE (For Reference Only) BOARD BENDING TEST- FIGURE 1 5/1/2023 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CM16M00000S022 SMD CERAMIC RESONATOR CRTV SERIES TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications., 1000pcs/Reel Symbol Dimension ɸA 180±3.0 ɸB 60.0 Min. W 12.4 Min. T 19.4 Max. DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 5/1/2023 NextGen Components, Inc. 7 sales@NextGenComponent.com www.NextGenComponent.com
CM16M00000S022 价格&库存
很抱歉,暂时无法提供与“CM16M00000S022”相匹配的价格&库存,您可以联系我们找货
