CR0201JM15RS01
CR0201JM15RS01
    NEXTGEN
    RES,SMD,0201,15,5%,1/20W
CR0201JM15RS01 数据手册
PART CODE: CR0201JM15RS01 SPECIFICATION SHEET SPECIFICATION SHEET NO. Q0211- CR0201JM15RS01 DATE Feb. 11, 2023 REVISION A1 DESCRIPITION Thick Film Chip Resistors, 0201 (0603 Metric), CR01 Series, Dimension L0.60*W0.30*H0.23mm, 2 Terminations Tolerance: ±5%, Resistance 15 ohm, Dissipation Max. 1/20W @ 70℃ Temperature Coefficient Rate (TCR) Max. ±200ppm/°C Operating Temp. Range -55°C ~+125°C Package in Tape/Reel, 15,000pcs/Reel RoHS/RoHS III compliant and HF CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER Aillen CR01JM15R PART CODE CR0201JM15RS01 VENDOR APPROVE Issued/Checked/Approved DATE: Feb. 11, 2023 CUSTOMER APPROVE DATE: 1 2/11/2023 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0201JM15RS01 THICK FILM CHIP RESISTORS CR01 SERIES DESCRIPTION The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal metal electrodes are added at each end and connected by a resistive paste that is applied to the top surface of the substrate. The composition of the paste is adjusted to give the approximate resistance required and the value is trimmed to within tolerance by laser cutting of this resistive layer. The resistive layer is covered with a protective coat. Finally, the two external end terminations are added. For ease of soldering the outer layer of these end terminations is a Tin (lead free) alloy. MAIN FEATURE • High Reliability And Stability • Reduced Size Of Final Equipment • Lower Assembly Costs • Higher Component And Equipment Reliability • RoHS III Compliant And Halogen Free Products APPLICATION • Consumer Electrical Equipment • EDP, Computer Application • Telecom Application RFQ PART CODE GUIDE Request For Quotation CR 0201 J M 15R S01 1 2 3 4 5 6 1) CR: Product code for Thick Film Chip Resistors 2) 0201: Size Code, 0201 (0603 Metric), CR01 Series, Dimensions L0.60*W0.30*H0.23mm, 3) J: Resistance Range Tolerance Code, P: Jumper; B: +/-0.1%; D: +/-0.5%; F: +/-1%; J: +/-5% 4) M: Package Code, A: 4Kpcs/7”Reel; B:5kpcs/7”Reel; C:10kpcs/7”Reel; M:15kpcs/7”Reel; D:10kpcs/10”Reel; E:20kpcs/10”Reel 5) 15R: Resistance value code. 0R: 0ohm; 1R2: 1.2ohm; 15R: 15ohm; 20R: 20ohm; 51R: 51ohm; 240R: 240ohm; 390R: 390ohm 1K: 1Kohm; 10K: 10Kohm; 15K: 15 Kohm;10K5: 10.5Kohm; 1K21: 1.21Kohm; 100K: 100Kohm; 226K: 226Kohm; 1M: 1.0Mohm; 1M2: 1.2Mohm 6) S01: Internal control code, digits and letter; Blank: N/A 2 2/11/2023 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0201JM15RS01 THICK FILM CHIP RESISTORS CR01 SERIES DIMENSION (Unit: mm) General Marking: Blank Image for reference CR01 series Item Dimension L 0.60±0.03 W 0.30±0.03 T 0.23±0.03 Tb 0.15±0.05 Tt 0.10±0.05 Item Dimension Resistors Construction For Reference Recommended Solder Pad (mm) 2/11/2023 NextGen Components, Inc. sales@NextGenComponent.com W 0.25~0.30 L 0.70~0.90 D 0.30~0.40 3 www.NextGenComponent.com PART CODE: CR0201JM15RS01 THICK FILM CHIP RESISTORS CR01 SERIES GENERAL ELECTRONICAL CHARACTERISTICS Item Unit Symbol Characteristic Product Name CR Thick Film Chip Resistors Size 0201 CR01 Series, Condition L0.60*W0.30*H0.23mm Resistance Range Ω Resistance Tolerance % TCR 10Ω~100MΩ 15 J +/-5.0 ppm/°C ≤±200 1Ω~9.76Ω -200~+600 Max. Dissipation W 1/20 @ Tamb=70°C Operating Temperature ℃ -55 ~+125 Max. Operation Voltage V 25 @DC or RMS Max. Overload Voltage V 50 @DC or RMS Note 1) This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8” 2) Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by RCWV = 𝑅𝑎𝑡𝑒𝑑 𝑃𝑜𝑤𝑒𝑟 × 𝑅𝑒𝑠𝑖𝑠𝑡𝑎𝑛𝑐𝑒 𝑉𝑎𝑙𝑢𝑒 or Max. RCWV listed above, whichever is lower. 3) Test condition for jumper (0 Ω) Item Unit Symbol Characteristic Power Rating At 70℃ W 1/20 Max. Resistance mΩ 50 Rated Current A 1.0 Peak Current A 2.5 Operating Temperature ℃ -55 ~+125 4 2/11/2023 NextGen Components, Inc. Condition sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0201JM15RS01 THICK FILM CHIP RESISTORS CR01 SERIES PRODUCT CHARACTERIZATION Standard values of nominal resistance are taken from the E24 & E96 series for resistors with a tolerance Of +/-1% & +/-5%, The values of the E24/E96 series are in accordance with “IEC publication 60063” DERATING The power that the resistor can dissipate depends on the operating temperature; see Fig.1 Fig 1 Maximum dissipation in percentage of rated power as a function of the ambient temperature for CR0402 MOUNTING Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs). Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable contact. 5 2/11/2023 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0201JM15RS01 THICK FILM CHIP RESISTORS CR01 SERIES REFLOW SOLDERING CONDITION The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260 ℃ for 10 seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235 ℃ during 2 seconds. The test condition for no leaching is 260℃ for 30 seconds. Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2. Fig 2. Infrared soldering profile for Chip Resistors 6 2/11/2023 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: CR0201JM15RS01 THICK FILM CHIP RESISTORS CR01 SERIES TEST AND REQUIREMENT (JIS C 5201-1 : 1998) TEST PROCEDURE / TEST METHOD REQUIREMENT Resistor Electrical - DC resistance values measurement Within the Characteristics - Temperature Coefficient of Resistance (T.C.R) specified tolerance JISC5201-1: 1998 Natural resistance change per change in degree Refer to “QUICK Clause 4.8 centigrade. REFERENCE DATA” 0Ω
CR0201JM15RS01 价格&库存
很抱歉,暂时无法提供与“CR0201JM15RS01”相匹配的价格&库存,您可以联系我们找货
