ESD0301BL
ESD0301BL
    MDD(辰达半导体)
    DFN1006
    夹子 1A(8/20µs) Ipp TVS - 二极管 表面贴装型 DFN1006
ESD0301BL 数据手册
ESD0301BL Ultra Low Capacitance ESD Protection Diodes DFN1006 Plastic-Encapsulate ESD Protection Diodes DESCRIPTION ESD0301BL is a low-capacitance Transient Voltage Suppressor (TVS) designed to provid electrostatic discharge (ESD) protection For high-speed data interfaces. With typical capacitance of 0.5pF, ESD0301BL is designed to protect parasitic-sensitive systems against over-voltage and over-current transsient events. It complies with IEC 61000-4-2 (ESD), Level 4 (±15kV air, ±8kV contact discharge), IEC 61000-4-4 (electrical fast transientt - EFT) (40A, 5/50 ns), very fast charged devicee model (CDM) ESD and cable discharge event (CDE), etc. ESD0301BL uses ultra-small DFN1006 package. Each ESD0301BL device can protect one high-speed data line. It offers system designers flexibility to protect single data line where space is a premium concern. The combined features of low capacitance, ultrasmall size and high ESD robustness make ESD0301BL ideal for high-speed data port and high-frequency line applications, such as cellular phoones and HD visual devices. Features          Peak Power Dissipation : 100W (8/20μs) Transient protection for high speed data lines IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC61000-4-4 (EFT) 40A (5/50ns) Cable Discharge Event (CDE) Package optimized for hingh-speed lines Protect one data, control line Low clamping voltage Low Capacitance :0.5pF(Typical) Low leakage current Applications        Serial ATA Desktops, Servers and Notebooks Cellular Phones MDDI Ports USB Data Line Protectioon Display Ports Digital Visual Interfacess (DVI) Pin Configuration Circuit Diagram Mechanical Characteristics Package: DFN1006 Flammability Rating: UL 94V-0 Packaging: Tape and Reel Terminals: Gold plated, solderable per MIL-STD-750, method 2026  Marking: 3BL     Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol VESD Value ± 20 ± 20 Unit KV Peak Pulse Power(tp=8/20us waveform) PPP 100 W Operating Temperature TOPT −55 to +125 °C Storage Temperature Range TSTG −55 to +150 °C The above data are for reference only. DN:T20418A0 http://www.microdiode.com Rev:2020A0 Page :1 ESD0301BL Ultra Low Capacitance ESD Protection Diodes Electrical Characteristics (TA=25°C unless otherwise specified) Symbol bol Param VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage IR Reverse Leakage Current VC Clamping Voltage CJ Junction Capacitance Test Condition IT = 1mA Min Typ Max Units 3.3 V 4.2 V VRWM = 3.3V 100 nA IPP = 1A, tp = 8/20μs 12 V IPP = 4A, tp = 8/20μs 25 V VR = 0V, f = 1MHz 0.5 pF The above data are for reference only. http://www.microdiode.com Rev:2020A0 Page :2 ESD0301BL Ultra Low Capacitance ESD Protection Diodes ELECTRICAL CHARACTERISTICS CURVE The above data are for reference only. http://www.microdiode.com Rev:2020A0 Page :3 ESD0301BL Ultra Low Capacitance ESD Protection Diodes Outlitne Drawing DFN1006 Package Outline Dimensions A DFN1006 Min Max Typ Dim A 0.50 0.45 0.55 b 0.45 0.55 0.50 D 1.05 0.95 1.00 E 0.55 0.60 0.65 e 0.40 L 0.20 0.30 0.25 R 0.07 0.17 0.12 All Dimensions in mm D R E b e L Suggested Pad Layout X1 Dimensions C G X X1 Y X Y Value (in mm) 0.90 0.40 0.50 1.10 0.50 Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. G C PACKAGE SPECIFICATIONS Package Reel Size DFN1006 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 10,000 210×210×205 100,000 445×445×230 400,000 7' http://www.microdiode.com Rev:2020A0 Page :4
ESD0301BL 价格&库存
很抱歉,暂时无法提供与“ESD0301BL”相匹配的价格&库存,您可以联系我们找货
